Old 04-26-2009, 03:18 PM   #616
John_S's Avatar
What class of racing is the new setting for? Also what does it have new compared to the original settings? Is it worth sending the speed controller to get this update done?
John_S is offline   Reply With Quote
Old 04-26-2009, 04:59 PM   #617
Send a message via MSN to afonsospt
Is there any plans for a software where users can update Genius firmware?
I know I can send it to GM if a major update is available,but a do it yourself would be great
Im currently on fw 4.7 and I do 9.5 stock racing,is it worth updating to 6.2?
afonsospt is offline   Reply With Quote
Old 04-27-2009, 01:44 AM   #618
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Mode 6 copied to Mode 3 works very well in Stock (fw 4.x)
With fw6.x you now got the possibility to set the softwarebackground independent of the mode used
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 04-27-2009, 10:34 AM   #619
Send a message via MSN to AMRH
Hi Martin
When you said to copied mode 6 to mode 3 for stock classe racing, what motor do you recomended ?
The purple 9,5T or the new one Pro-stock 9,5T ,or the Blue one ?
AMRH is offline   Reply With Quote
Old 04-27-2009, 02:48 PM   #620
we always either use the purple one, or the blue one with a 12.5mm mag which equals the purple one but fits our car better :-)
I have not tested the grey one yet as it is not DMC legal and thus testing it would not help our german teamdrivers
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 04-27-2009, 03:53 PM   #621
Thank you Martin ,for the same factor as you i prefer the purple ,it looks better in my car (Cyclone)
Grey is a great motor,is the most used in the national in Portugal.
Old 04-27-2009, 04:29 PM   #622
MSB
MSB's Avatar
Send a message via Yahoo to MSB
Is it?
The factory Team used the purple!
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
Old 04-28-2009, 01:54 AM   #623
I think when track/air temp goes up to like 40 degrees the grey one will have some advantage over the purple one, as it will run cooler and therefore little more consistant/efficient due to the inbuilt fan
We usually don't use the blue one (with standard 12mm mag) as it might fade to the end of the run
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 04-28-2009, 03:47 AM   #624
Hi all,
I've recently bought a GM 6.5 to use with Lipo and would like some advice on gearing if possible ?
I currently use a speed passion motor and know the gearing for that, so a comparison to that would be great if possible ?
If not, I'm running on asphalt and the next track will be a very large one (normally used for 8th scale on road)
Chris
CPD Racing
chris_dono is offline   Reply With Quote
Old 04-28-2009, 03:54 AM   #625
Start with the same gearing as used with the sp and then test from there
Temp should be below 80 degrees
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 04-28-2009, 04:19 AM   #626
thanks Martin, I'll try it and let you know.
CPD Racing
Old 04-29-2009, 03:56 PM   #627
Holmenkollen's Avatar
How should I gear a 7T delta (std rotor) with Nosram ISTC and Lipo 7.4V? Big track.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 05-02-2009, 11:19 AM   #628
alan1467's Avatar
I have a GM120 brushless speed controller that is 3 months old that the set button has stopped working on anyone else had this problem?
Also can I remove the fan for 4 cell 10.5T World GT car so i can fit the speedo easier my my CRC Gen X10 in the new position behind the cells?
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 05-02-2009, 03:55 PM   #629
John_S's Avatar
Removing the fan shouldnt be a problem as i run 10.5 tourer with no fan and the speedos not even hot when i bring the car in. If you are at carlisle tomorow i will show you.
Old 05-02-2009, 04:50 PM   #630
I had that issue also.I've sprayed a bit of electronic cleaner,let it dry and it should work again,at least mine did.
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
