Old 04-11-2009, 05:53 PM   #586
Hi
im here just to tell you this, a few months ago i asked about using Lipo and GM Pro 6T Delta, and Martin told me to use 7T and if i want to use 6T to be very carefull with it.
Now i can tell you that on the first round of the Portuguese National Championship my son used a GM Genius 120 + GM Pro 6T Delta + Lipo and he finished in 2nd place overall on its first appearance on modified class.
So you can use Lipo and 6T Delta with no problems, even if says on specifications that it should be used between 4,8...6V
Here you can see a video of my son winning the 3rd final with that configuration
http://www.youtube.com/watch?v=TjmcP0Coe6Q
jopor is offline   Reply With Quote
Old 04-11-2009, 06:27 PM   #587
Slideaway's Avatar
Hi you all,
I just would like to react on Jopor latest post.
Jopor told us "So you can use Lipo and 6T Delta with no problems, even if says on specifications that it should be used between 4,8...6V"
Using this configuration sounds to be ok IF AND ONLY you race on such very large track.
According to the linked video, the track sounds designed for Gas cars and I'm sure it's the ideal track for 1/8 Onroad GP.
So, to my humble opinion, Jopor should not openely certify there's no problem at all using Lipo/6t Delta as it might be ok only for this very particular case.
Large track doesn't request the same brake stress for the motor than the narrow/small track on which the motor has to support a lot more of acceleration/brake stressful phases, and gets more heat by consequences.
So Martin's and the GM's specs would be highly considered if you don't want to meet any unreversible issues.
Once again, it's only my personal feeling but I'm quite sure people around will share this.
Keep it up.
Slide
Ludo
Thai Ride Tech Support.
Slideaway is offline   Reply With Quote
Old 04-14-2009, 06:24 AM   #588
MSB
MSB's Avatar
Send a message via Yahoo to MSB
Originally Posted by Slideaway View Post
Hi you all,
Keep it up.
Slide
I totally agree!
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
Old 04-19-2009, 11:21 AM   #589
alan1467's Avatar
Hi Martin
Need some help. I have a GM120. It was great indoor with a 10.5T. I connected to my laptop and changed it from mode 7 to mode 1 to run a 3.5T mod on 5 cell outdoor. when I went out to practice the speedo had no punch or top end it was like the cells were flat but they weren't, I even changed motor just incase!!! I tried several other modes but all the same. I reloaded the saved setting I ran on the 10.5 but again the same. Any ideas??
I fitted a spare 120 and changed that to the saved 10.5 from my laptop and it's perfect!!!
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 04-19-2009, 12:00 PM   #590
Kajman's Avatar
Originally Posted by alan1467 View Post
Hi Martin
Alan
Did you try reset to factory settings?
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 04-19-2009, 12:01 PM   #591
alan1467's Avatar
No how do you do that?
Tamiya TRF - Tekin
Old 04-19-2009, 12:04 PM   #592
Kajman's Avatar
Just after programmin TX ways/choosing mode with transmitter please push the button on ESC, one longer beep after programmed mode indication says you've done it. Read manual Do not change modes with PC as its interacts with preset data.
Old 04-22-2009, 03:24 PM   #593
Hello! Sorry for my bad english
New here in this forum and one year old in rc-racing.
I need some help pleace!
I need a new motor and have locking at GM motors sport 9,5T blue (6552), and DR.Speed 9,5T (97266) and the pink 9,5T (97289). I dont know witch one to chose. I have an Associatede B4 and uses 2s intellect lipo, 5000 mah with an Mamba Sidewinder esc.
I will do some races with the new motor. I did some races with an Orion Vortex 5.5T, 5cell nimh, indoor and will soon do my first outdoor race ever.
Any other suggestions?
Thanks// Thomas
Edit: Wrong forum. Sorry. Didnt se it was on road. Maby get some answers anyway!
Tajpan is offline   Reply With Quote
Old 04-22-2009, 03:38 PM   #594
steveonamission's Avatar
Martin,
Can the new GM Genius 90 (120's smaller brother) handle a 6t delta? Or is a 7t delta better for it?
Thanks in advance
Steven
steveonamission is offline   Reply With Quote
Old 04-22-2009, 03:58 PM   #595
Send a message via ICQ to MattW
Steve, based on what i've been told, yes 90 should be ok with 6T. 120's are in stock over here now as well. Mine should be here any time!
MattW is offline   Reply With Quote
Old 04-22-2009, 04:28 PM   #596
Ok cheers Matt
Old 04-22-2009, 05:31 PM   #597
Just a question for Slideaway
id like to know your opinion about worlds track layout?
is it stressfull for motor?
meanwhile its time for the electric guys to think that the tracks used for touring were done for less power motors (like 27T).
Today you can run on gas tracks as you say, because now you have motor for that and have no problem with runtime as well,
cheers
Old 04-23-2009, 03:49 AM   #598
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Right we do have the power to keep up with Nitro cars ...
we actually can go faster
but we are very close to the limit of ESCs/batteries/motors
and the limit is greatly influenced by the Voltage
So even though it might work with Lipo and 6T delta I still have to warn you that this is beyond the "save operating area"
Which means if you blow up the esc you will most likely not have any warrianty left
there are enough drivers here in germany using a 4T or 7T delta with 5 cells and it'S fast enough ... and easy on the electronics
so I cannot understand why a 7T delta with LIPO would not be fast enough ...
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 04-23-2009, 05:21 AM   #599
Kajman's Avatar
It's a pity that GM does not support higher voltages with their motors and esc, 3S and 4S will come to our cars sooner than we think. Lucky that ESC already work on 3S Lipo/ 4S LiFe, but still not enough number of motors.
BTW, Martin, do you know what is with GM forum?
Old 04-23-2009, 05:23 AM   #600
Slideaway's Avatar
cheers
Hi Jopor,
I'm not sure which worlds track are we talking about. If you mean the last ISTC Worlds track in Bangkok Thailand so yes, this track was actually very stressful for modified class. Not so long straight line and many rythm changes in the corners section.
At that time, the IFMAR rule was to use 6 cells SUB-C only. So mostly, the modified class drivers used 4.0t or 4.5t with a secured ratio.
Combined with the air and track temperatures, it was really like hell. Some motors could reach 110C after 5 min. The limits were reached and beyond sometimes.
Slide
Ludo
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
