Old 02-08-2009, 03:08 PM   #541
Send a message via MSN to afonsospt
Hey Martin,
I've noticed that theres new brushless motors on GM website.GM Pro Stock 9.5 and 10.5
http://shop.graupner.de/webuerp/serv...11&language=de
Would you please comment on them,improvements over Sport series,and so...
afonsospt is offline   Reply With Quote
Old 02-09-2009, 04:45 AM   #542
alan1467's Avatar
Default GM are great
Originally Posted by fatboy_coach View Post
How did they contact you last time about payment, was it email?
Just had an email off GM and offered me a GM120 to replace my GM100 for 92euros shipped so very happy
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 02-19-2009, 11:01 AM   #543
Kajman's Avatar
Hello!
Is copying modes reversible? I think I have by mistake in my old Genius 95 copied mode 4 to mode 5 with pc What can I do? Software 0.9.
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 02-19-2009, 02:15 PM   #544
I believe the only way to reverse is doing a factory reset.
Check manual on how to do it.
Old 02-19-2009, 02:17 PM   #545
Kajman's Avatar
Ralf sais I should reverse the operation, but I don't really understand how to do it...
Old 02-19-2009, 05:32 PM   #546
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
9.5/10.5 T motors
they are designed to meet efra regulations -> changed magnet + the 9.5T features a fan on the magnet to bring down temps
the 9.5 is between the blue sport 9.5 and the purple sport 9.5T in matters of feeling and power
the 10.5 seems to be pretty good but i have not tested that one myself
regarding the reversibility of the mode changes, please do a factory reset -> have a look into the manual how to
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 03-01-2009, 04:42 PM   #547
Jesper Jacobsen's Avatar
Default Graupne sport 9,5
Martin is there any other differences between the blue and purpla 9,5 motors beside the different rotor sizes... blue 12mm purple 12,5mm
the reason is that i denmark in the series we run only the Graupner blue is allowed in 9,5 and not the GM purple... you are allowed hower to change the rotor?
the same goes for 13,5 where it is only the red graupner version allowed, but it allready has the 12,5mm rotor, so i guess it is the optimal motor from gm so far..
Jesper Jacobsen is offline   Reply With Quote
Old 03-01-2009, 05:14 PM   #548
Yes the magnet is the only difference
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 03-02-2009, 12:02 AM   #549
Kajman's Avatar
Martin, how about dr speed series and sport? magnets too or something more?
Old 03-02-2009, 05:54 AM   #550
De Speed differs in a lot of things
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 03-02-2009, 05:57 AM   #551
Kajman's Avatar
So it's efficiency and temperatures are not very similar to Evo3 and Pro series? There are quite a lot of old dr speed motors in our shops whith old, low prices, but I'm not sure if one should not pay extra and buy Pro with Evo3 rotor(because of fan)?
Old 03-03-2009, 06:43 AM   #552
Send a message via MSN to AMRH
Hi
I need some help ,im runing in Stock classe in portugal with a Genius 90,GM sport purple motor 9,5T and lipo.
I already try the modo 8 ,but temperature goes to 90 and more ,in portugal tracks are to big ,what ratio did you guys recomended to lower temperature and to get a good performance without burn the motor?
Regards
Anibal
AMRH is offline   Reply With Quote
Old 03-03-2009, 08:39 AM   #553
Originally Posted by AMRH View Post
Hi
Regards
Anibal
Look back a few pages. Martin has posted his setups for speedo and which programs he runs for what...
program 8 i think is not suitable for a touring car regardless of gearing
i use program 6 and 3 for stock racing with 5 cells and offroad with lipo.
but again take 5 mins and read through the earlier pages.. it's all there for you
TEAM MORFARS.DK Associated RC8B + Novarossi PLUS 4 + Savox servoes + Merlin Fuel.
Old 03-04-2009, 03:35 AM   #554
MSB
MSB's Avatar
Send a message via Yahoo to MSB
Hi Anibal,
Here you have some important information given by M. Hofer:
Originally Posted by Martin Hofer View Post
Hey guys.
Stock racing HOW-TO
firmware 0.x
Most likely you will want to use mode number 6 with the following important values:
amplimit: 200 - 250
brakemin: 5%
brakemax and fullbrake should be set to the same value! (I use 95%)
frequency: #3 (16kc'/adj. current..)
reserved: 22 (new brake software feels a lot nicer)
maxreverse: 100
softstart: 50
powercurve: linear
auto throttle / brake: 0
timing w/o sensors: 30°
timing with sensors: 30°
voltage cut-off: 3.6V
firmware 4.x
amount of timing
least: mode 6/7, mode 3, mode 8 :most
even though all modes are programmed with timing set to 30/+30
mode 6/7 should be programmed as mentioned above
mode 8 has A LOT of timing an thus huge amounts of RPM
BUT most motors drop of after 3 laps or even less when using this mode, so be careful!
mode 3 is originally a modified mode
to make it Stock-ready do the following:
- pick mode 8 via transmitter
- read out the esc data with the PC-software (v1.1.5 or higher required)
- go to advanced settings
- pick mode 3 in the "controler mode" flipdown
There will be a window showing up saying: sure you want to copy the
background information?
click "yes",
then klick "no" when it asks you if you want to set the standard values
finally click ok as you know you will use the same batteries as before :-)
- send data to the esc
- read out the data once again
- read through the log-window (just received data of course) and check if
value 33, activediodemaxtime is now set to 110 (original value is 50)
if you successfully set the new value: congratulations
if you still have the value set to 50, simply try again
Some general information:
Brushless is opposite to brushed:
less frequency = softer, less precision and power
more frequency = more punch/precision
I usually use 8kc, but or stockracing 16kc sometimes gives you just the little extra bit :-)
I personally always use mode 6 or 3
mode 8 is too much for 9.5T racing
5cell with 9.5T GM Purple motor geared to 5.1 - 5.6 on any track (indoor carpet of course, as it's the indoor season right now) using mode 6
for mode 3, multiply your gearing with 1.2!
i.e mode 6 gearing = 5.1
mode 3 gearing = 6.1
of course all stock modes require sensor wires to make use of the software timing
the speedpassion motor can be geared pretty similar to the gm purple
gm blue need to be geared around 0.2 shorter
lrp 9.5 needs to be geared around 1.1 shorter
cs 9.5T needs the motortiming to be turned clockwise to nearly middle of the c-solder tab
I hope this helps all them stockracers out there to do it like me and my teammates do :-) rule the straightaway and try to not lose too much in the infield *g*
one more VERY IMPORTANT thing:
you can see your transmitter values in the "advanced settings"
fulltrottle should be around 1.9xxx ms
neutral around 1.4xxx ms
fullbrake around 1.1xxx ms
if your values are far off, you need to do a new transmitter setup!
and use the transmitter to switch between modes, not the pc software if not specificly mentioned (like above)
otherwise you'll copy program data from one mode to another
Anyway, some careful with the chose ratio should be take. Otherwise, you may notice some “Ampere” smelling from motor…
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
Old 03-04-2009, 05:24 AM   #555
Thumbs up
Thanks Miguel
I will try 3 and 6 mode, i think it is the most friendly for the motor.
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
