Old 11-07-2008, 04:55 AM   #481
Martin,
Do you have a profile for 13.5 motor for the Genius95?
Dan
Dan Hughes is offline   Reply With Quote
Old 11-07-2008, 05:17 AM   #482
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
it is normal at the first launch ... when the car did some meters it should start smoothly
the back and forth motion is also caused by that
you won't have this at race starts if you drive your car a few meters before you start (which basicly every one does anyway) and then roll to the startline and make sure your car is not pushed back!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 11-07-2008, 05:19 AM   #483
Originally Posted by Dan Hughes View Post
Martin,
Dan
make sure you have an updated esc (firmware 0.6/0.7 or 4.6/4.7)
if you know what firmware is on your esc then i can give further advice
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 11-07-2008, 05:22 AM   #484
Not sure, i believe that it is one of the newer ones similar to the genius 100. Is there an easy way to tell? Bought it beginning of the year if that helps.
Old 11-07-2008, 07:04 AM   #485
If it helps I got it when they started shipping with the capacitor PCBs.
http://shop.graupner.de/webuerp/servlet/AI?ARTN=2898
Old 11-07-2008, 07:24 AM   #486
then i guess it one with the old Software. I recommend sending it to gm for an update if u race wth Stock motors regularly
General Info:
There are new all-black sensor wires with thicker wires which makes it last longer and look bettet
Part number 2894.4
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 11-07-2008, 07:38 AM   #487
When I look at the parameters with the handheld programmer I can change the timing of the ESC. I have 17 options that I can adjust. I will send for an update but only when I get a break in racing in December. It has the 4 modes and beeps on startup to tell you what mode its in.
Is there any other differences between the two software versions that I could see?
Old 11-07-2008, 08:25 PM   #488
fifi's Avatar
fifi
which magnet did u use before the 12?
It was the original one in 5.5.
15.1mm but don t know more about it
fifi is offline   Reply With Quote
Old 11-08-2008, 05:32 AM   #489
General Info:
Part number 2894.4
Is this the same for the Genius 95? Where do I send it and how long will the update take?
TIA
Ian
fatboy_coach is offline   Reply With Quote
Old 11-08-2008, 05:54 AM   #490
4 modes = old
5,5T standard rotor is bonded
gearing shouldbe similar when using a 12mm mag
btw: the new software (stock modes) needs the pc interface + software to be changeable .. the handheld can only be used for mode 0 - 5
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 11-30-2008, 03:33 AM   #491
alan1467's Avatar
Hi martin
Just had to buy a new laptop. I have the lead for programming my speedos but it serial (comm) and my new laptop is only USB, I can not get a convertor (USB-COMM) to work on Vista. Is there ?
a) a USB lead
b) or can I get my comm port lead converted to USB?
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 11-30-2008, 05:58 AM   #492
Send a message via MSN to afonsospt
Usually big computer stores sells com->usb adaptors.I bought mine on staples.
Genius 120 is bundled with an usb cable not sure if it works on older ESCs without software upgrade but Martin will let us know soon.
I wonder also if genius95 is still on production and if those are loaded with the new software with those new stock modes available on 120.
afonsospt is offline   Reply With Quote
Old 11-30-2008, 06:44 AM   #493
the usb interface needs the software update to work
all left genius 95 are sold with the old software unless they are specially ordered with the update installed
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 11-30-2008, 06:44 AM   #494
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 11-30-2008, 10:21 AM   #495
Born2Run's Avatar
It's time to replace the bearings on my GM EVO3 but i don't know how to do it on the sensors side.I assume i have to take out the sensors board but i don't want to damage it.Any help please?
Whatever
Born2Run is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
