Old 11-03-2008, 12:48 PM   #466
MSB
MSB's Avatar
Send a message via Yahoo to MSB
Hi Martin,
I send you a PM some days ago, not quite sure if you received.
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
Old 11-03-2008, 01:12 PM   #467
heretic's Avatar
thanks Mr Hofer ! I sent you an email. NO, two emails.
heretic is offline   Reply With Quote
Old 11-05-2008, 07:03 AM   #468
Hi there,
I've just bought the GM120 esc and it looks really nice. I never saw so thick PCB board, neither a esc in which both the top/bottom FETs are directly attached to the heatsink. Great work done here!
However the motor cables seem to be too thin... Won't they cause too much voltage drop at high currents?
I'm going to use this esc with a LRP X11 9.5T motor not using the sensor cable with a LiPo battery. Do I need to add additional caps to the esc?
I have one cap, 5600uF but only 10V, which I can add. As I'm only going to use 2s LiPo, 10V should be safe, right?
Will this configuration work Ok with the LRP motor?
0) Receive First Byte11/5/2008 1:45:19 PM
1) AMP Limit : 250; TimeDiff : 0.1464 s
2) Turbo : 9; TimeDiff : 0.1083 s
3) BrakeMin : 30; TimeDiff : 0.1289 s
4) BrakeMax : 80; TimeDiff : 0.1463 s
5) Start Amp : 120; TimeDiff : 0.1108 s
6) Auto Brake : 30; TimeDiff : 0.1468 s
7) Frequency : 1; TimeDiff : 0.1108 s
8) PowerCurve : 0; TimeDiff : 0.1291 s
9) Autogas : 0; TimeDiff : 0.1270 s
10) FullBrake : 100; TimeDiff : 0.1280 s
11) MaxReverse : 0; TimeDiff : 0.1282 s
12) Switch : 134; TimeDiff : 0.1272 s
13) ABS : 1; TimeDiff : 0.1262 s
14) RPMLimit : 0; TimeDiff : 0.1274 s
15) Reserved : 50; TimeDiff : 0.1264 s
16) Timing : 19; TimeDiff : 0.1454 s
17) Softgas : 100; TimeDiff : 0.1080 s
18) Reserved1 : 128; TimeDiff : 0.1264 s
19) Softbrake : 100; TimeDiff : 0.1271 s
20) FullThrottle : 89 (HighByte); TimeDiff : 0.1264 s
20) FullThrottle : 16 (LowByte); TimeDiff : 0.1266 s
20) FullThrottle : 22800; TimeDiff : 0.1266 s
21) NeutralPoint : 63 (HighByte); TimeDiff : 0.1216 s
21) NeutralPoint : 172 (LowByte); TimeDiff : 0.1262 s
21) NeutralPoint : 16300; TimeDiff : 0.1262 s
22) FullBrakePoint : 39 (HighByte); TimeDiff : 0.1197 s
22) FullBrakePoint : 16 (LowByte); TimeDiff : 0.1249 s
22) FullBrakePoint : 10000; TimeDiff : 0.1249 s
23) Neutral Point Width : 80; TimeDiff : 0.1198 s
24) Controller Mode : 32; TimeDiff : 0.1246 s
25) VoltageCutOff : 250; TimeDiff : 0.1253 s
26) PWMStartNoSensor : 128; TimeDiff : 0.1229 s
27) LimStartNoSensor [A] : 30; TimeDiff : 0.1387 s
28) ProgramNumber : 0; TimeDiff : 0.1175 s
29) Aktive Diode Mode : 0; TimeDiff : 0.1450 s
30) Switch StartMode : 143; TimeDiff : 0.1279 s
31) DelayTimeComp : 15; TimeDiff : 0.1233 s
32) AktiveDiodeMaxDiff : 1 (HighByte); TimeDiff : 0.1061 s
32) AktiveDiodeMaxDiff : 44 (LowByte); TimeDiff : 0.1230 s
32) AktiveDiodeMaxDiff : 300; TimeDiff : 0.1230 s
33) AktiveDiodeMaxTime : 110; TimeDiff : 0.1111 s
34) AktiveDiodeMinTime : 90; TimeDiff : 0.1195 s
35) Dead Time Fets : 205; TimeDiff : 0.1187 s
36) MaxRPM : 255; TimeDiff : 0.1197 s
37) Firmware : 46; TimeDiff : 0.1210 s
38) MaxCurrent : 0 (HighByte); TimeDiff : 0.1192 s
38) MaxCurrent : 0 (LowByte); TimeDiff : 0.1182 s
38) MaxCurrent : 0; TimeDiff : 0.1182 s
Can you please explain how the esc is configured to the radio? I mean, full throttle range, brake, idle band, etc... is it done manually through the usb port only?
Concerning the "turbo" function, can you please a little bit how this works?
Thanks in advance,
Helder.
hhsilva is offline   Reply With Quote
Old 11-05-2008, 07:20 AM   #469
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by hhsilva View Post
Hi there,
wrong, set 1 and leave it that way, more doesn't feel good when driving
use 0 - 10% not more
Fullbrake should always be the same as maxbrake
switch either always on or short press on/off
abs off!
reserved 22!
set 30 / +30 in mode 7
wrong! progam 7 or 8
Thanks in advance,
Helder.
1. when running 9.5T use a sensor wire and mode 7 or 8, then it will be A LOT faster
2. you set the mode you want to use via the throttle of your radio, while doing so the esc saves fullthrottle/fullbrake/idle band etc.
in your case you will want to use mode 7 or 8
means
mode 7: connect to batt, wait for the esc to boot, press button till you hear a long beep
then fullthrottle (1beep),
fullbrake (2beeps),
fullthrottle (3beeps),
fullbrake (4beeps),
fullthrottle (5beeps),
fullbrake (6beeps),
fullthrottle (7beeps) -> mode 7 -> leave trigger in fullthrottle position till the esc does one long beep and 7 short beeps, then mode 7 is set correctly
or if you do
fullbrake (8beeps) once more you'll have mode 8 set -> leave trigger in f-brake pos. till you hear 1 long and 8 short beeps
Important: always wait for the esc to finish beeping between trigger position changes! and when you reached the mode wanted leave the trigger in last positon
the wires are thick enough ...
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 11-05-2008, 08:09 AM   #470
Thanks a lot Martin.
So, this means that you can only change modes through the radio and through the usb cable the only thing you can do is to personalize each mode (and not change modes). Is this correct?
And if I do some change through the PC and then switch between modes using the radio, the PC configuration is lost and when I go back to that mode it will have the default values, right?
Unless I use the mode option when programming through the PC, right?
And about the extra capacitor? Do I need one?
Cheers,
Helder.
Old 11-05-2008, 08:28 AM   #471
see below
you can do it with the pc software too, but then background information gets transfered too and can mess up the modes so I recommend to use the transmitter to switch between modes, this way you also get a fresh tranni setup too :-)
once you changed a mode it stays that way .. you can switch between modes as often as you want ... the modes themself are not unfluenced by that
you don't need an extra cap
Cheers,
Helder.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 11-05-2008, 08:36 AM   #472
More question... (being a pain in the a**),
If using mode 8 with sensor cable with the LRP X11 9.5T it will have +30 of timing in the GM120. Normally I use 0 timing in the motor. Do you advice to increase the timing also in the motor (rotating the sensor board)? If yes, how much?
After changing a mode configuration through the PC USB cable is there any way to revert the esc to the factory values in all modes?
Old 11-05-2008, 08:45 AM   #473
1. mode 8 doesn't have 30 ... but more
2. the gm motors do feature a 30 hardwaretiming the lrp do have hardware timing too
3. yes there's the possibility to do a factory reset ... please see instruction manual ..
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 11-05-2008, 09:56 AM   #474
Found the factory reset! Thanks for the great support!
Old 11-05-2008, 10:18 AM   #475
glad I was able to help you
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 11-05-2008, 03:56 PM   #476
Hi again Martin,
I've intalled the GM120 in the car. It's a little big but it fits quite nice in the Mi3.
As you said, the 9.5T motor is a lot faster with the sensor cable than without it.
I used to use the LRP TC with it. Because the controller is different, do you thing I need to change the FDR or should I use the same as used with the previous esc?
I also noticed that it doesn't slip. Starting from stop with full throttle or hitting the brakes hard it doesn't slip at all, behaving very smooth (when compared with other escs). Is this something expected?
Thanks,
Helder.
Old 11-05-2008, 06:05 PM   #477
Send a message via ICQ to piorc
Hey guys, where could i buy the new Gm esc , the 120A one?
i need a on line store, unless graupner.
tks
piorc is offline   Reply With Quote
Old 11-05-2008, 06:20 PM   #478
fifi's Avatar
In 4WD offroad 6cells. 5.5T evo 3
I was gearing 18/87
Now I put a 12mm sintered.
Should I keep the same gearing, go up or down?
(It s rainning can t test yet)
fifi is offline   Reply With Quote
Old 11-06-2008, 02:55 AM   #479
hhsilva
when using the sensor wire and mode 6 or 7 you can use the same gearing
when using mode 8 multiply the gearing by 1,5!!!!!!
fifi
which magnet did u use before the 12?
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 11-07-2008, 04:53 AM   #480
Hi Martin,
I did some tests with the GM120, just smalls start/stop tests in my kitchen floor.
I'm using the sensor cable.
Then, when I do full throttle (as quick as I can) there is a delay around 0.3s (in which the car remains stopped) and only then the car starts. Is this normal? This can be an issue at the start grid (being a disadvantage). Is there any config I can change to reduce this time?
Also, sometimes the car doesn't start smoothly but rather pulsed sometimes moving backward and forward (just for a very short time), like trying to find the correct motor phase (but it starts moving forward after this). This is weird because I'm using the sensor cable. Should I change something in the configuration?
Thanks,
Helder.
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
