Old 10-29-2008, 06:57 AM   #451
Nuno Gancho's Avatar
No, should i? with what value?
You can see the track size in this link
http://gatekracing.forumeiros.com/ar...10-75.htm#4652
, and some video, i was using final ratio 10.3, the fastes lap was 9.06, 32 laps in 5 minuts.
Give me any idea of what i could do better, in speedo or motor, thanks
Nuno Gancho is offline   Reply With Quote
Old 10-29-2008, 08:38 AM   #452
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
the value of adding caps:
- The esc was designed to be used with 5 cells (therefore 3 caps). With lipo you get a lot more stress for the motor and chances are high to blow up the caps. You should add 1 or 2 just for safety matters
- Once the caps broke the Esc really has to suffer!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-29-2008, 09:14 AM   #453
Ok i will add more 1 or two caps, what voltage should they have, 16V?, and capacity. Should it be place in parallel with the feeding, of the battery? Thanks.
Old 10-29-2008, 11:51 AM   #454
add exactly the same caps that are already soldered to the esc
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-31-2008, 03:47 AM   #455
Ok Thanks, Martin
Old 11-01-2008, 06:00 AM   #456
where do you put the additional caps
please post a foto or a diagram to explain.
thanks
jopor is offline   Reply With Quote
Old 11-01-2008, 06:13 AM   #457
hope that helps
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 11-01-2008, 11:42 AM   #458
DHMOTORSPORTS's Avatar
Trader Rating: 19 (100%+)
Hey guys Looking to get the GM Genius 120. Who will ship to the usa or is there someone in the usa I havent found yet?
Trinity / Team Epic / ReVtech Batteries / TRC / F-Bomb Graphix
DHMOTORSPORTS is offline   Reply With Quote
Old 11-01-2008, 11:50 AM   #459
I will be ordering one soon, shoot me a PM if interested.
Rojna is offline   Reply With Quote
Old 11-01-2008, 02:26 PM   #460
Excelent diagram, wont you agree Jopor hehe, you should get one GM 120 and a new car hehe so we can work as a team, with your excelent young son as we saw in the indoor race...
Old 11-01-2008, 03:52 PM   #461
Thanks Martin
Nuno Ive got one GM 120 already.
Old 11-02-2008, 01:21 AM   #462
Born2Run's Avatar
Martin
My car sounds very louder when i use my GM EVO III 7T.Is it normal with the GM motors? I haven't this problem with my other motors (MM7700 and Orion 2008 3T).
Whatever
Born2Run is offline   Reply With Quote
Old 11-02-2008, 12:08 PM   #463
it's because of the fan that is attached to the rotor
it makes the motor sound a little like a 7T brushed
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 11-03-2008, 05:31 AM   #464
heretic's Avatar
Martin; I have several questions for you ;
I am going tu use a 13.5 stock motor from Orion, with my genius 95. What programming would you recommend, for a short and slippery indoor carpet track? In a touring car. ( drag brake,etc...)
Also, i have difficult in understanding how to set the timing properly ( I'm new to BL) Do I set it up on the speedo or on the motor? or on both? What is the recommended position of the "head" of the motor? what is the recommended programming for the timing ? I was told that the timing is set diffrently from sensored to sensorless... could you explain ?
( On my GM modified, the " B " letter is placed just under the " C" solder tab. Hope it makes sense.)
I have another problem : Among all the sensor wires given with my speedo + the one given with the motor, I can't find one that fits both my orion motor and my Gm speedo. BUT i found a way to plug one of the GM wires to the orion wire, which is then plugged on the motor. Is it going to work ? On the orion wire, all tiny wires are black + there is heat shrink wrap around them, so it's impossible to check the correspondance between the colors of the wires... I hope i make myself clear, my english is pretty poor...
thanks in advance, and sorry for the long post.
heretic is offline   Reply With Quote
Old 11-03-2008, 11:43 AM   #465
see below
There should be a setup posted by me a few pages back but you can drop me an email and I'll send you some setups
esc timing and motor timing is basically the same but totally different *g*
in Stock we run 30 motor timing (b marking to the middle of the b solder tab) and 30 of additional ESC timing (Updated firmware atleast 0.6 or 0.7 required!)
if it's an evo 3 delta wind motor then the placement is correct ... if it's star wound turn it back to b - b
but as long as you don'T use sensors the motor timing doesn't matter at al
the gm esc does have a 8pin socket whilst the motors do have a 6pin socket .... this is why speedpassion/orion/lrp sensor wires won't fit
there's an adaptor cable delivered with the escs in which you can plug in any aftermarket sensorwire and then plug the adaptor into the esc
but that connection is not very safe so I'd recommend to order gm sensor wires which do have a 8pin connector at one end and an 6pin connector at the other
part number 2894.4
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
