Old 10-01-2008, 04:01 PM   #406
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by fatboy_coach View Post
Hi Martin,
I think so, how do I tell?
Ian
did you buy it new and sent it to gm for an update or did you buy it used?
if so, how many modes does taht esc have? 4 or 8?
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-02-2008, 01:07 PM   #407
I got it used, I think it only has 4 modes as that is all I seem to be able to access. Does that mean that it needs an update?
My instructions only cover getting up to mode 4, how do you get to the higher modes? Is it just a case of moving the throttle more times?
fatboy_coach is offline   Reply With Quote
Old 10-07-2008, 02:49 AM   #408
Holmenkollen's Avatar
How should I set the timing on a GM 7t Delta motor with a Nosram ISTC speedo?
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 10-07-2008, 05:00 AM   #409
Send a message via MSN to mark34 Send a message via Yahoo to mark34
Leave as is the nosram will not cope to well if you adjust the settings.
Yokomo BD
CEFX C12
Powered By Demon Batteries and GM Brushless and 2 thumbs
Mark Ashby
mark34 is offline   Reply With Quote
Old 10-07-2008, 05:23 AM   #410
Timing has to be set as following:
the "B" marking has to be inline with the middle of the "C" soldertab or even turned slightly more clockwise ...
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-07-2008, 09:13 AM   #411
Originally Posted by Martin Hofer View Post
never! Run without caps
Martin,
your advise above is to run 1/12, 10.5 with 4 cells without caps.
Is it so because of
-1/12
-4 cells or
-10,5T ?
I just got a new shrink wrap version of Genius 95 to put in my 1/12 with 4 cells and a Speed Passion 5,5T.
Is your recommendation "no caps" here too?
Another question, which GM motor is used by the top 1/12 guys in Mod?
-jarkko
jarkko is offline   Reply With Quote
Old 10-07-2008, 09:21 AM   #412
I think Martin wanted to say " never run without power caps !!! "
Rojna is offline   Reply With Quote
Old 10-07-2008, 10:06 AM   #413
exactly
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-12-2008, 05:39 PM   #414
fifi's Avatar
I was running 17 pinion with 5.5 evo3 offroad with lipo
Now I have a pro 9 and 7.
What pinion should I put?
Is there a general rule from old GM evo 3 to the pro serie?
for 4WD 1:12 1:14 mean that the final ratio should be between 12 and 14?
Some drivers had thermal issues today and put their evo3 back in the car.
fifi is offline   Reply With Quote
Old 10-13-2008, 05:08 AM   #415
gear ratios are always 1:x so yes gearing should be between 12.x and 14.x
as for your gearing request ... I cannot make any use of the information that you use a 17T pinion ....
if you give me a fdr I might be able to help
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-13-2008, 07:18 AM   #416
alan1467's Avatar
Hi Martin
I'm in the UK and my GM100 Speedo has died can I get it repaired?
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 10-13-2008, 08:39 AM   #417
of course you can .. send it to gm with a failure description and you'll get it repaired/relaced
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-13-2008, 08:29 PM   #418
fifi's Avatar
It s to use on a yokomo MR4BX. spur 87 internal 2.2
It would be a 15 pinion?
In general with the GM pro you need to lower in pinion than with the evo 3.
Old 10-14-2008, 11:04 AM   #419
5.5T star equals a 9T delta ... gearing therefore is similar
with 8T you of course have to gear it shorter ... as it's more powerfull
when changing from you can calculate what deltawind your star wind motor is equal to
in your case 9T
so you take your gearing (from nowon called X)
x divided by the wind you WANT! to run (for example 8T) multiplied with the wind you USED!
means (X/8)*9= new gearing for the 8T
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-14-2008, 05:27 PM   #420
fifi's Avatar
With 9T delta with LipoI tried
10.98 final ratio the - on the battery unsolder after 2mn
13.26 final ratio same thing after 4mn.
What is the problem when the cable to the battery unsolder?
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
