Old 09-11-2008, 12:28 AM   #391
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
ah yeah sorry, you still set the exakt amout of amps
90 is about the same a 95, 120 is better
you can get the software on your 95 updated, then you can set the cutoff voltage to whatever value you want it to
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-11-2008, 12:34 AM   #392
Kajman's Avatar
I've already done it Great update, now I have to do it in my G85 as it doesn't arm with fresh charged 4S liion
Frankly speaking I want to buy some ESC for my emaxx up to 6s and after your speedos any other are so god damn poor...almost no features which I want, such a loss that you don't make one strong ESC up to 6s with your software, it would be a hit worldwide as no one makes something so reliable and full of setup possibilities.
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 09-28-2008, 10:22 AM   #393
Giorgio's Avatar
It might be an old question, as well, but worth to ask....
Our rules allows foam on asphalt, lipo (Trakpower 4900 - SMC...) and BL (Vector 4.5)
This season I toast 3 Blue TC ones....
Does the Genius 120 withstand those factor?
I'm sick about toasting ESCs....
Let me know
Giorgio is offline   Reply With Quote
Old 09-29-2008, 02:40 AM   #394
MSB
MSB's Avatar
Send a message via Yahoo to MSB
Same happens to me. One Red one with only 3 races and some practices toasted too. With a Genius 95 that I have for 1 and a half year is still working nicely. My 120 as only some practices but I'm sure that it will be the same as the 95!
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
Old 09-29-2008, 07:26 AM   #395
it will last yes
but please add 2 small (same as built in at the esc) or one big (4700microF) cap just for saftey matters as due to the high voltage of 6 cells and the ampraw the 3 caps might break (the top part with the cross on it bends slightly) and you will loose a lot of power ...
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-29-2008, 04:58 PM   #396
Hi Martin
GM PRO 5T or 6T says
Operating voltage range: 4,8V...6V
Im going to use a lipo battery 7,4V, so my question is
it will be better to use a GM PRO 7T or can i use 5T and 6T also
which will be more efficient?
If i can use 5T or 6T do i have to have any additional precaution?
thanks
jopor is offline   Reply With Quote
Old 09-29-2008, 05:17 PM   #397
stick with a 7
6t might be still ok if you are careful enough but 5 is only dedicated for 5cell racing and actuallly there are very few people using it as it is already too fast using 5 cells....
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-01-2008, 12:12 AM   #398
Default Genius 95 Problem
Hi Martin,
I'm having a problem with my Genius 95, it keeps cutting out. Last weekend I ran GM 6t on an open track geared at 6.8 (recommended by another GM user).
Initially the car was sluggish, but I put this down to my cells as they're not the best and also altered softstart from 100 to 50 as it says in the manual. This got the car flying, but after 3 laps or so the car would cut out. It would restart after a little while (30+ secs) so I changed reserved to 23 but had exactly the same problem. When I got to the car the motor and the speedo were warm (35deg C), but not hot. All of the other settings are as per your posting on here and I'm running the capacitor bank. I don't run a motor or speedo fan, could this be the cause? Or should I send the speedo to GM for investigation? Could it be the cells dipping in voltage and cuasing the speedo to reset?
TIA
Ian
fatboy_coach is offline   Reply With Quote
Old 10-01-2008, 01:41 AM   #399
Do you have a Esc with the new or old Software?
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-01-2008, 03:38 AM   #400
Send a message via MSN to mark34 Send a message via Yahoo to mark34
Quick quetion when running 4 cell 10.5 in my 12th scale do i need to run any caps. Believe it or not the the gm 100 does fit lol
Yokomo BD
CEFX C12
Powered By Demon Batteries and GM Brushless and 2 thumbs
Mark Ashby
mark34 is offline   Reply With Quote
Old 10-01-2008, 04:41 AM   #401
never! Run without caps
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-01-2008, 09:03 AM   #402
Send a message via MSN to afonsospt
Hi,
Any of you guys have tried a Genius esc with a LRP x11 without sensors?
If yes which timming did you setup on esc?
I know this is GM thread,but Im on a 2wd offroad project using my old genius80,I know I could use one of my GM Evo3 on it,but since its case is opened I dont wanna trash it on offroad.
Thanks in advance
afonsospt is offline   Reply With Quote
Old 10-01-2008, 09:09 AM   #403
Hey, I am using a X11 13.5 in 2wd without the sensors with my Genius 80 ... no problems
Timing is set to 30*
Rojna is offline   Reply With Quote
Old 10-01-2008, 01:03 PM   #404
Hi Martin,
I think so, how do I tell?
Ian
Old 10-01-2008, 01:09 PM   #405
Thanks Rojna
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
