Old 08-01-2008, 06:46 PM   #346
Martin, my 85 wont run on a 4C lipo, just peeps all the time, I have it set in mode 3 ... what am I doing wrong ??
Had the same problem with 12 Nimh cells, so I just reduced it to 11 and it ran fine.
Rojna is offline   Reply With Quote
Old 08-02-2008, 02:15 AM   #347
Kajman's Avatar
It will not run, even on 4s liion will not, it is too high voltage, because at the end it is 4.2v x 4 = 16.8v, not 14.8, you need to use cells for a while in other model or undercharge them (don't know if reccommended). I have the same problem with my 85. On new software it works already...
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 08-02-2008, 09:01 AM   #348
Hey, a 4cell lipo is 4x 3.7 = 14.8V not 16.8V
The instructions for the GM 85 clearly state it will handle a 4C Lipo in mode 3
Operating voltage range: 4.8 ... 14.8 V
Cell count, NiCd, NiMH: 4 - 12
Cell count, LiPo, LiIo: 2 - 4 (Mode 3)
Old 08-02-2008, 10:04 AM   #349
lutach's Avatar
Fully charged lipos are 4.2v eah cell like stated above. The 3.7v rating is with a load.
lutach is offline   Reply With Quote
Old 08-02-2008, 10:22 AM   #350
Hey guys thanks for all the awesome info on how much Volt a charged, discharged, with load and without load a LIPO cell has.
BUT the question im asking is why my GM85 wont run on a 4C lipo in mode 3, the instructions dont say it has to be a disharged or only half charged for it to work
Old 08-02-2008, 11:00 AM   #351
Kajman's Avatar
you need new software
Old 08-11-2008, 08:40 AM   #352
Trader Rating: 139 (100%+)
I have a genuis 95 that marc fisher gave me to run in 1/12th scale. it is brand new pm me if anyone is interested in it
joerocket900 is offline   Reply With Quote
Old 08-13-2008, 03:47 AM   #353
MSB
MSB's Avatar
Send a message via Yahoo to MSB
Default Genius 120
Hi Martin,
Thanks for your help at the Euros (motor repair). The Evo3 is now working again!!
Do you know if we can manually change the switch on/off in the Genius 120? I could not enter that part of the program manually. I could only change the program Modes manually. Also, after I did the drives and software’s download at GM site, the pc doesn’t recognise the Genius 120.
Any tips are welcome
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
Old 08-13-2008, 08:24 AM   #354
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
1. have you installed the usb driver correctly? if so, the red led on the usb cable will flash red
2. have you picked out the right com port? (check for which comport the usb cable uses in system settings -> hardware manager)
3. check if one of the pins in the esc is bent, if so bent it back VERY CAREFULLY
4. have you downloaded the newest programming software and! have you picked the right com-port and activated it?
if everything of the following is correct, it must work
btw. programming of the genisu 120 is different
no battery is needed anymore
only the usb cable included
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 08-13-2008, 08:39 AM   #355
MSB
MSB's Avatar
Thanks for your tips Martin,
I'm going to try again this evening with your advices. As a matter of fact the usb drivers as a new version (5.3) and the AS software is a new version too (1.1.4).
cheers
Miguel S. Braga
Old 08-24-2008, 06:11 PM   #356
Send a message via MSN to afonsospt
MSB told me today that a new version (1.1.4) of As Genius tool was available.
I wonder if those new features on advanced tab are compatible with older controllers (genius 95 1yr old)
Theres nice new features like selectable cut-off voltage and new modes.
Im currently on v1.1.1 should I upgrade or its useless?
Thanks to GM Techs for improving what was near perfect.
PS:You should improve user manuals because those are a nightmare for first timers.I almost sold my genius95 when I first tried to config with set button
afonsospt is offline   Reply With Quote
Old 08-25-2008, 02:59 PM   #357
Send a message via MSN to mark34 Send a message via Yahoo to mark34
Default gm splashproof
Hi Guys
JUst got home from the KO gp in the uk where we had 2 wet rounds where one was for racing boats really most impressed with the gm 100 2 bits of blue tack and some gaffer tape on reciever and finished the runs no probs at all cant say that for all the lrp,nosram runners even with there little pots and mega water proofing
Yokomo BD
CEFX C12
Powered By Demon Batteries and GM Brushless and 2 thumbs
Mark Ashby
mark34 is offline   Reply With Quote
Old 08-25-2008, 04:50 PM   #358
to use the new features (who can be programmed with version 1.1.0 or newer already!) you need to update the ESC which has to be done by GM in Germany.
Send it to Kirchheim with a note that you want it to be updated and you'll get it back asap.
KOGP
very funny indeed.
As I don't own a wet car (neither was i prepared for the wet), I just used blue tack to make my car waterproof. used my Genius 120 ESC and it worked awesome. No failure whatsoever.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 08-26-2008, 06:19 AM   #359
Default GM 120
Hi Martin
Do you know of anywhere I can order a GM120 from in germany etc as doubt that I will be able to get one in the uk
Mark
Yokomo BD
CEFX C12
Mark Ashby
Old 08-26-2008, 01:29 PM   #360
Im afraid those are out of stock and will be back in September.If Im wrong let me know because I want one as well
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
