Old 06-18-2008, 03:52 AM   #286
Martin and Mark thanks for your advice. I'll take a stop watch to open practice on saturday and try gearing it about 9 like I would normaly and try it again at about 7.
Sean
sean0 is offline   Reply With Quote
Old 06-18-2008, 10:42 AM   #287
JevUK's Avatar
Originally Posted by Martin Hofer View Post
I have once teted a 3T y-wound
You can't have 3t wye it must be delta. Wye is always .5, delta whole numbers.
MRT, Novak, Spektrum, Sanwa, Tamiya, Alleven RC, Maxamps, CheapBatteryPacks, Duratrax Ice, Pro Peak PSU, Nuova Faor, McLarney Racing, Futaba, KO Propo, Team Associated, Enerland.
JevUK is offline   Reply With Quote
Old 06-18-2008, 11:12 AM   #288
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
sorry but wrong
you can do .0 winds star-style but not .5 ones delta-wound
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 06-18-2008, 11:48 AM   #289
JevUK's Avatar
sorry but wrong
If you put the grounding ring at the top you could but I don't think there are any legal motors built like that. I think lehner did something like that.
Old 06-18-2008, 12:10 PM   #290
no it is not illegal
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-18-2008, 12:34 PM   #291
JevUK,
Go on the BRCA electric board and in the homoligation list you will see it for yourself.
Quick question for martin again. I've been looking at the 6t delta that arrived and I can't change the timing on it. Is it meant to be fixed? Doesn't really matter cause i'll be running it sensorless. But just nice to know.
Sean
Old 06-18-2008, 12:37 PM   #292
A 3T delta would be very quick though.
Old 06-18-2008, 12:55 PM   #293
JevUK's Avatar
Originally Posted by sean0 View Post
JevUK,
Sean
No 3t on there http://www.brca.org/BRCA/elecboard/n...(Modified).pdf
So is the 4t wye wound?
Old 06-18-2008, 01:04 PM   #294
A 3T y-wind peak racing motor is BRCA legal and they exist cause i own one.
Sensored system. “Y” Wind Black Alum. End-Bell with TOP name. 5.0mm shaft reduced to 1/8 for bearings both ends. Black sintered magnet with or without fan. 7.5T, 6.5T, 5.5T, 4.5T. 4.0T, 3.5T & 3.0T. Rotors:- 12.0, 12.5, 13.0, 13.5.
Not sure about the 4T GM motor but i think it is also a y-wind.
Old 06-18-2008, 02:13 PM   #295
the 4T is Y wound but not sold anymore
the timing on the pro brushless 6T cannot be changed ... that's correct.
it is set to what fits best to the gm esc but as we never use sensors it does not matter anyway :-)
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-18-2008, 02:42 PM   #296
Thanks for that Martin. I look forward to testing the motor.
Old 06-19-2008, 03:17 PM   #297
Holmenkollen's Avatar
I run on a really big outdoor track (18s lap) and Im a little short on runtime. Using a 7T Delta geared at 6.3. Mode 1 on Genius 95.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 06-19-2008, 03:27 PM   #298
7T + 6.3 gearing is totally undergeared ... gearing longer will increase runtime in that case as you do not need to use that much throttle to do the same speed
I'd run a 6T with 6.0 - 6.3 on a 18sec/lap course!
just try to really lower the fdr and you will from some point on notice that you gain runtime
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-19-2008, 11:44 PM   #299
Kajman's Avatar
Where can I get Graupner GM 6T Delta PRO Brushless Motor technical data?
Kajman is offline   Reply With Quote
Old 06-20-2008, 01:08 AM   #300
Nominal voltage: 6 V
Operating voltage range: 4.8 ... 6 V
Revs. / Volt (kV) approx. 8800
Winding count: 6T delta tri-angular pattern
Current drain at max. efficiency approx. @7.2V: 90A @ 6V
Current drain at max. power approx. @7.2V: 150 A @ 6 V
Max. power at 7.2 V: -
Max. power at 6 V: 440 W
Max. power at 4.8 V: 270 W
Permissible direction of rotation: R and L
No. of poles: 2
Overall length approx. 70 mm
Case length approx. 52.5 mm
Diameter approx. 35.8 mm
Free shaft length approx. 15 mm
Shaft diameter at output: 3.175 mm
Weight approx. 165 g
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
