Old 10-26-2012, 04:05 AM   #2911
Teddy's Avatar
Hi all,
next season i will switch to modified class and i want to try a GM 8T delta wound (with 12mm rotor) that i have in the box.
Someone can tell me the final ratio i have to start with, for a mid size track and using turbo software?(speed passion speedo)
thanks a lot
Teddy is offline   Reply With Quote
Old 10-26-2012, 05:48 AM   #2912
hana166's Avatar
Originally Posted by Tilky View Post
Hi Guys!
Was not racing for two years and decided to revive a bit of the past for this winter season.
I have GM Genius 120 controller with v7.2 firmware and GM Pro Motor 17.5T
Do you have any idea where I can get As-Soft for my Firmware?
Is there any possibility to upgrade firmware version in my speedo?
T tried to use current programming tool v 1.6.5 but it seems that I can't change a lot of functions with it.
Thnks for reply in advance.
I prefer 1.6.3 but have you checked 'Version' on top left? You can select for FW>=7.2 or FW>=10.0. Don't know how well it works though, but it should work.
Sadly GM site is gone so its not possible to download older PC software. I deleted all FW7.2 stuff unfortunately but maybe someone here has the software
hana166 is offline   Reply With Quote
Old 11-05-2012, 07:16 AM   #2913
Hi,
I have sometime a problem with my Genius 120.
If a stop my car on the track(waiting someone,grid start), when i put throttle, the motor doesn't start. But if someone push my car, all is working back...
Radio : Futuba
Servo : Savox
Motor : GM 4.5/10.5
LiPo : Nosram 6700
Team Awesomatix / Team Roche / Team Corally / Wild Turbo Fan
nicoo2k4 is offline   Reply With Quote
Old 11-05-2012, 08:15 AM   #2914
daleburr's Avatar
Originally Posted by nicoo2k4 View Post
Hi,
Radio : Futuba
Servo : Savox
Motor : GM 4.5/10.5
LiPo : Nosram 6700
This is a problem with the GM, particularly with the first 2010 120s. The solution is to move your throttle trim forwards as far as possible without the car actually moving fowards. This stops the ESC sitting in neutral and seems to prevent whatever the bug is.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 11-15-2012, 10:14 AM   #2915
Hi,
What is the bearing size of gm pro ? Like 97305 or 97350 with timing setting by screws
Manson is offline   Reply With Quote
Old 11-25-2012, 03:02 AM   #2916
Do anyone have setups (gearing and esc setup) for genius75 with timed 13.5 1:12 racing? Any setup, no matter what size track etc.
MickeB is offline   Reply With Quote
Old 08-19-2013, 11:19 AM   #2917
Default Graupner GM120
Hi, bought me this one recently.
http://hk-modellbau.com/default.asp?...734&kat_id=298
Using it for Pro10 235mm outdoor asphalt.
motor Corally Red Series Delta 7T sensorless
Done some testing.
But what puzzles me is how to work option 11 Amp Limit (current drain limitation).
I hear and read all sort of things as to the preferred setting.
What setting best to use?
Is it: the less grip the tires have on the surface the lower the setting should be? Or not?
Do I have to take into consideration the amp draw of the motor?
Should the setting be equal or lower than the max Amp of the motor? Or not?
This is from the manual option 11 "AMP LIMIT"
"The current limitation can have an influence on the torque of the motor. AMP LIMIT should
be set so as to avoid that for instance the wheels of a car do not or only slightly grind on the ground."
This second sentence I don't understand. I think what is said here is that it's ones aim to avoid the wheels of the car to not or only slightly grind on the ground. I thought that it was a good thing that the wheels don't or just slightly grind on the ground. Because than there would be no wheelspin. Me no understand..... :-(
What is the influence of the amp limit on the torque of the motor?
Kensei is offline   Reply With Quote
Old 08-21-2013, 05:03 AM   #2918
We are a couple of guys having trouble with some throttle glitches... When we drive it gives max current to the motor, even more than full throttle on the transmitter. One guys is running Genius 120 and Spectrum, i am running Genius 90 and Futaba and we have the same glitches. I have changed reciever and moved it further away from ESC with no luck...
Have anyone heard of these glitches before? If yes how do we correct it?
Foodie is offline   Reply With Quote
Old 09-09-2013, 09:50 AM   #2919
NItrox416's Avatar
Yes I have a sort of cogging at high speed, I correct partially it trying to separate the wires of the servo from the esc one as much as possible.
NItrox416 is offline   Reply With Quote
Old 09-09-2013, 09:55 AM   #2920
NItrox416's Avatar
I have lack of top speed in every boosted situation whatever the motor is (10.5,5.5t) reaching high temperatures from esc and motor, I have enabled the high speed timing, someone have some setup tips or should I buy some cheap chinese esc with double top speed?
thank for help
Old 09-11-2013, 04:00 PM   #2921
chasingthepack's Avatar
thank for help
i think your fdr is too low try raising it to around 6.5 and work from there
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 01-18-2014, 11:00 AM   #2922
How do you control "Punch" on this esc? I have CS Rocket Comp 120A but its relabeled GM Genius 120.,
I have shortcourse car and 6,5t 2 pole motor and 4 pole motor. Both have way too much power on beginning. I know that it is esc problem because I have tried same motor/car with different esc and they are way smoother.
Bigbearfin is offline   Reply With Quote
Old 01-18-2014, 03:08 PM   #2923
NItrox416's Avatar
Try to reduce the frequency or the soft start value
Old 07-08-2016, 09:27 AM   #2924
Kajman's Avatar
Ok guys, years have passed, I came back to hobby with my kid, but infortunatelly I can't find AS Genius Soft for USB interface anywhere! Can somene help me with install file download link?
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 08-09-2016, 06:59 PM   #2925
Trader Rating: 21 (100%+)
I'm having some crazy problems with a GM 120 Pro esc I recently picked up.
I'm using a Graupner X-8N radio, and a Fantom brushless motor.
It seems like the ESC thinks it's connected to a sensorless motor or something....it just stutters my motor back and forth. The car just stutters, doesnt go forward or backwards.
Any idea what's going on? Also, when I connect it to the programming box, it's saying "Connection Fail", and doesnt seem to be saving the changes I'm making.
xjwolfpacker is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
