Old 04-19-2012, 07:08 AM   #2836
Jonnydb's Avatar
Send a message via MSN to Jonnydb Send a message via Skype™ to Jonnydb
Originally Posted by Dom B View Post
Hello everybody
I have a GM Genius 120, it is excellent and works well on my KO Vantage Esprit II radio gear (40MHz).
I tried to connect it to my Futaba 3VCS radio gear (running 40MHz) and am having a problem.
The radio gear works on other brands of speed controllers (team wave and losi), the Genius works perfectly on other radios.
With the Futaba I can do the setup mode select sequence puching the stick back and forth etc, the red and yellow lights and the motor noise all work as they should in the manual and the speedo confirms I have picked mode 4 for example by flasing and beeping 4 times after.
However when the controller is out of set up mode or turned off and on the motor pulses on and off twice a second at neutral spinning the wheels, if I throttle up the pulsing it there all the way through the power and I have to hold brakes to stop the car moving.
The lights are also flasing in time with the power pulsing.
I have conected the Genius to the computer and the pulse widths are all looking good with full throttle at 1.9ms and full brake at around 1.2ms. (throttle channel reversed as the manual states)
I reconnect and re setup to the KO radio gear and it all works perfectly again.
Any ideas or has anyone seen this before with Futaba radios???
i don't know if i'm right it's looks like sub trim on radio
reset the configuration and try again
T.O.P Racing Brazil
Jonnydb is offline   Reply With Quote
Old 04-19-2012, 07:31 AM   #2837
Thanks Jonnydb, I will try that tonight.
Dom B is offline   Reply With Quote
Old 04-19-2012, 12:46 PM   #2838
The subtrim did nothing, still the motor pulsing problem. While the motor is pulsing the yellow light is on solid and the red light flashes on and off in time with the motor pulsing on and off.
Old 04-19-2012, 03:44 PM   #2839
Jonnydb's Avatar
like cogging? if yes is to much timming
did you make the esc reset also?
T.O.P Racing Brazil
Old 04-19-2012, 06:21 PM   #2840
Hi yes speedo reset, no change.
It is not cogging it is pulsing with no stick input at all, if you put the car on the track it would drive off on its own.
I am running the KO radio gear for now until the problem can be solved as I am racing tomorrow.
Old 04-20-2012, 02:19 AM   #2841
Does anyone got experience with the GM Race BL Motor 13.5T (fdr and timing) for blinky TC class?
The best way is gear low and load on the timing, or go the other way?
My track is 40 meters straight.
andrease is offline   Reply With Quote
Old 04-20-2012, 03:27 AM   #2842
*SBH*'s Avatar
I would gear around 4,0 FDR and set the timing to max. Off course it also depends on the layout of the track. Use the temp protection in the speedo and look at the telemetry after Your race. If the temp is to high, try to time down a little bit.
*SBH* is offline   Reply With Quote
Old 04-20-2012, 03:48 AM   #2843
Thanks SBH!
How many degrees is each graduation?
The first sign is the zero timing?
Old 04-20-2012, 07:29 PM   #2844
Nuno Gancho's Avatar
Hello to all any site were I may purchase a gm120 and a Graupner Sport motor 9.5
Nuno Gancho is offline   Reply With Quote
Old 04-22-2012, 02:48 PM   #2845
NItrox416's Avatar
Hi all,
I have a problem with the brakes with my gm 120 gen II with x12 13.5 blinky.
min brake: 15
max 100
full 100
autobrake 0
Any advice to increase brake power?
Thanks all.
NItrox416 is offline   Reply With Quote
Old 04-22-2012, 04:31 PM   #2846
Originally Posted by NItrox416 View Post
Hi all,
min brake: 15
max 100
full 100
autobrake 0
Thanks all.
try 'softbrake' with a higher value, also, do you have 'new brake software' activated ? If so, try a lower value on the 'effect new brake software' setting
CPD Racing
chris_dono is offline   Reply With Quote
Old 04-23-2012, 01:42 AM   #2847
*SBH*'s Avatar
Thanks SBH!
Hi again
There are 5 holes, the motor comes standard in the middle hole, consider that 30 degrees. 1 hole up (if You look from behind on the holes in the right side) will add app. 15 degrees more. The top hole will add 15 more = app. 60 degrees motortiming.
If You use the 2 lower holes, You will time down. Dont do that
Old 04-23-2012, 02:30 AM   #2848
No, you're referring to older models.
The Race has a graduated scale for the adjustment of the timing.
The support of the sensors can be rotated by loosening two screws.
demonpowerproducts.co.uk/images/GM-timing.JPG
On this site they say that each bar corresponds to 5 , but can not tell which is the maximum timing
Old 04-23-2012, 02:38 AM   #2849
Max timing is when u turn the sensor all way to the left, which white knockles and all.
Should look like this.
Markings I
Markings IIIIIII
U can mode it to look like this though
I
---IIIIIII
Cp Grafix is offline   Reply With Quote
Old 04-23-2012, 03:24 AM   #2850
Well, then timing to the max!
FDR for 13.5 blinked, always around 4?
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
