Old 01-11-2012, 08:58 AM   #2776
Originally Posted by M.Abramowicz View Post
Hi!
v13.1, modified engine, mode 3 without or with messing settings
It looks like, going for start, put car on track, then is 30sec to start,
some idiot find that he must repair carpet, then wait 2 mins and at start,
push th and car is in place ... servo works, but engine doesn't works ...
Sometimes it happens and made me f.....g angry, and same speedo 90 at
friends car and he has same problem ...
Sensor wire was changed, engine was changed ...
Don't know it is go without sensor cable must check it.
Any tip?
m
Might sound strange but check the shimming of the rotor and the soldering of the stator.
CPD Racing
chris_dono is offline   Reply With Quote
Old 01-11-2012, 11:19 PM   #2777
New GM engine from box, or Graupner (silver can with black label).
Used old GM engine.
Engines works with HW and LRP.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 01-13-2012, 01:41 AM   #2778
Used old GM engine.
For new motors out of the packet, shimming definitely is needed, new graupner.. check the soldering of the stator !
CPD Racing
Old 01-13-2012, 05:53 AM   #2779
Hi Chris, what's the best way to shim a new motor?
Bryan D is offline   Reply With Quote
Old 01-13-2012, 07:39 AM   #2780
you want the rotor closer to the sensor board (I normally make it about 0.5mm to 1mm using the shims that come in the motor)
9 times out of ten, it means taking one shim off the sensor board side and putting at the front of the motor
CPD Racing
Old 01-13-2012, 01:43 PM   #2781
Any help with fdr for a open track 80m straight motor x12 and V131
thank´s
pauper is offline   Reply With Quote
Old 01-14-2012, 07:55 PM   #2782
thank´s
anyone.....
Old 01-20-2012, 02:39 AM   #2783
thank´s
anyone.....
its modified or stock?
if modified, 4.5/5.0T/5.5T star engine, start from fdr ~8.2-8.3
read great Martin manual and test settings ;-) with HST
80 m long ... crazy
Michal Abramowicz
Old 01-20-2012, 02:46 AM   #2784
ghiro's Avatar
Send a message via Skype™ to ghiro
80 m long ... crazy
??? were at?
I need the same set up (90mt straight, 400mt track lenght) for a GmPro5.5/Genius 120V2
Capricorn TE01-Associated RC10R5.1-Atomic VM2-Serpent Cobra811 BE-Honcho-Losi MRC/RcBros-SandScorcher-MERV
DJI' F550-HubsanX4-Toy'sPort Zorro
ghiro is offline   Reply With Quote
Old 01-20-2012, 01:44 PM   #2785
thank´s
anyone.....
It´s for stock lrp 13.5 gm 75 v13.1
thank´s
Old 01-24-2012, 02:28 AM   #2786
scoyle's Avatar
First of sorry as this has probably all been covered before...
I have a GM90 that I would like to test against my Hobbywing 120 - I have always been afraid of the seeming complexity of the GM and so have never run it.
I have read the article here (http://www.racing-cars.com/pp/Manufa...g/GM97164.html) which I think is from an article by Martin Hofer on this thread. My understanding of these instructions is;
1. ensure that you speedo has v13 software on it
2. load up the V13_1_basic.gd2
3. set you mode (also sets transmitter settings)
4. adjust the 4 values for your motor type
My questions are;
I plan to run 10.5 on a track about the size of Ardent in the UK for those that race there. Should I be picking mode 8 or 9 instead of mode 3 as recommended by Martin?
For anyone running 10.5 (using a speed passion motor if possible) what settings should I look at for the additional 4 settings - with my Hobbywing I run pretty mush everything maxxed - DRRS mode 9, timing and turbo to the max 64 degrees timing and an FDR of 9.2
Thanks,
Stephen
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 01-24-2012, 04:23 AM   #2787
daleburr's Avatar
My questions are;
Thanks,
Stephen
Hi Stephen,
If you use Martins settings file the mode number doesn't matter, as the settings overwrite all the defaults for the mode. Just make sure you select the mode that you loaded the settings file into.
I've run an SP v3 10.5 so this should be a decent starting point...
FDR 6.5
Motor timing max (10deg)
Switchpoint 15000RPM
Fixed Timing 21deg
Current Limit 80A
Thats for an outdoor track with a 35m straight. For a smaller track maybe change the FDR to about 7.0 but the rest should stay about the same.
If the temperature is okay (I try to stay below 70deg with the SP v3) you may be able to add more Fixed Timing for more top speed, but always best to start on the safe side.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 01-25-2012, 05:37 AM   #2788
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Hello everyone.
I have updated my blog once again.
This time with a story how beeing late can make racing a lot more challenging.
Setup from the event should be up on the Schumacher homepage soon.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 02-08-2012, 09:22 PM   #2789
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default GM 75
just wanted to drop a quick question...
is a GM 75 a good option for Stock 17.5 Noboost or is intended more for Mod Racing?
just wanted to try something different from the norm in the US.
current motor choice is LRP X12 17.5
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 02-09-2012, 02:26 AM   #2790
daleburr's Avatar
I wouldn't recommend the GM for blinky (no boost) racing; if you read the past couple of pages of this thread you'll see there are lots of people (including myself) having issues. It seems that the GM doesn't like lots of motor timing, and in blinky you run more motor timing.
In boosted though it's #1
Team Xray
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
