GM Brushless
#2686
If i need a bit more wot should try as the 75 is all new to me!!!
#2687
Thank you for the reply i am running mod 2 with no timing but my gearing is well out i was running 35mm as it was the first time out with it then i went up to 37mm so will have to try yours and see how i get on
#2688
#2689
Do you run a sensor wire? As some say you should and some say not to
Ya i found that it feels like the car is more stable and consistent thought the power curve.
can't wait till next weekend meeting in Plymouth.
Are you running in the nats this year??
#2691
#2692
Hiya, yes i run it sensored
#2693
#2694
there is 2 different 12.5 rotors! the ones with the red faceplate with a smaller inner diameter and therefore a stronger magnetic feel than the ones with a purple or silver-greyish faceplate, that have a bigger inner diameter (Efra Stock). The purple ones are super smooth and keep the motor temperatures a bit lower but overall also give you a bit less power
#2696
#2697
No.
Basically, if you need power, don'T use it unless you are force to, by regulations
#2698
Thank you all i was getting a bit lost with it all just need to get some track time in now
#2699
Hi need a guide as to what gear ratios people are running there 17.5s at?
I am using the GM75 speedo with Martins basic setup on, on a small to medium high grip carpet track
My motor is the GM 97357 17.5?
#2700
