Old 06-01-2008, 05:15 AM   #256
Send a message via MSN to mark34 Send a message via Yahoo to mark34
Hi Martin
quick question can you use the rotor from the evo 3 delta (7T) in the brushless pro 6t delta 6 as it has a fan and the pro one does not
TIA
Mark
Yokomo BD
CEFX C12
Powered By Demon Batteries and GM Brushless and 2 thumbs
Mark Ashby
mark34 is offline   Reply With Quote
Old 06-01-2008, 09:12 AM   #257
V12
V12's Avatar
I was told the EVO3 rotors wont fit in the Pro motors because of the fan, maybe Martin can confirm this later.
Another question is, if its possible using a Pro rotor in the EVO3. I would like testing a 12mm rotor in the EVO3 4.5T but I just have a 12mm rotor from the Pro series here.
V12 is offline   Reply With Quote
Old 06-03-2008, 12:06 AM   #258
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
The pro-motors magnets fit into the evo 3 series motors, but not vice versa.
regarding the throttle position wandering
who often do you have to reset it? every month or so it should be done anyway
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 06-03-2008, 08:05 AM   #259
Thanks for the reply Martin BTW do you know who is going to ditribute GM in the uk as I believe that Schumacher no longer do
Mark
Yokomo BD
CEFX C12
Mark Ashby
Old 06-03-2008, 11:27 AM   #260
Send a message via ICQ to MattW
Well it was Schumacher that submitted the Pro 6T Delta as distributor, and i was talking to them about that very motor this afternoon, so i'd guess they still do.
MattW is offline   Reply With Quote
Old 06-03-2008, 01:03 PM   #261
Well wrong again then Matt lol do you know how I would go about getting a spare speedo ie can I order thru a shop or direct from schumacher also pro 6t awsome motor better power delivery than than the evo 3.5 and cheaper what more could you ask.
Yokomo BD
CEFX C12
Mark Ashby
Old 06-03-2008, 02:10 PM   #262
Mark, i'd guess either should be possible. It is listed on Schumacher's site, but does show out of stock. I'd gues your best bet might be to give them a call and see what they say.
Yes i think 6 turn is a very nice wind. However, i can't run properly as i run with LRP speedo, so will have to stick to evo 3 3.5 turn.
Old 06-03-2008, 05:59 PM   #263
V12
V12's Avatar
why do you cant run the 6T Delta with the LRP speedo?
Old 06-03-2008, 11:21 PM   #264
Does anyone know what the difference between mode 1 and 2 on the GM100?
I know in the manual it say 1 is for normal grip and 2 is for high grip, but what settings have changed between the two?
stuartb is offline   Reply With Quote
Old 06-04-2008, 07:58 AM   #265
we usually use mode 1 as it is the best allround setting
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-05-2008, 11:12 PM   #266
Born2Run's Avatar
Hi Martin
I have a GM EVO III 7T delta and i want to change the sintered magnet to get some more RPM.Do i have to go to the 12,5mm or 12mm magnet? Im running on 2S lipo.Also,can i use the 12,5 magnet from Speed Passion as they look very similar.
Whatever
Born2Run is offline   Reply With Quote
Old 06-06-2008, 01:26 AM   #267
yes you can use sp magnets
12mm = max rmp
12,5mm = best mix between bottom and top end performance
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-07-2008, 01:35 PM   #268
Send a message via MSN to afonsospt
Today I run my second hand 4t evo3 with 12,5mm sintered magnet.
Genius95 temp after runs was around 89C,it never been so hot,motor temp was 80C.
Temp shut down never kicked,but to be on safe side and summer is comming.
What is temp limit for Genius95 esc?
afonsospt is offline   Reply With Quote
Old 06-08-2008, 12:41 PM   #269
temp cut kicks at 95C so you are close to shutdown
rather recommend to set an odd reserved value
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-08-2008, 03:02 PM   #270
Im on reserved 22.Is this fine?
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
