Old 09-26-2011, 12:32 AM   #2671
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by 008-Racer View Post
Looking to do a little 2WD buggy racing soon and i was hoping to use my spare GM75
Can it be used with a 7.5 Turn mod motor, I know it doesnt say so on the instructions but thought i might have seen something regarding one of the mod boys running a 75??
I doubt it can handle a 7.5T unless you run no timing at all, limit the current and have a throttle finger made of butter.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-26-2011, 12:35 AM   #2672
Originally Posted by Slick990 View Post
Martin did you get to see halifax and mendip.....those are proper uk straights
I have only seen West London and Aldershot. Prefered Aldershot :-) I know the other tracks are even bigger but on my quest to find the maximum speed down the straight succeeded when my car backflipped WITHOUT hitting the bump :-)
Originally Posted by kerb View Post
Thanx matt.
You don't have any other heat problem with this ratio ? I reach more the 120 degres on my esc with no timing and 7.5 ratio....
Is it possible to have the files of your setup by mail ?
My email : forumgratte(at)sfr.fr
Thanx !
120 internal is no heat issue. You are close to a heat issue when you reach 139. so long, just don't bother.
Solder the fan wires to battery + and -. This will give you an extra 10-15
As for setup. There'S a guide for V13.1. Use that and adjust the timing from 0 to 12 depending on the track as matt already wrote.
It's much better to develope a personal setup rather than just copying one.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-26-2011, 01:16 AM   #2673
Thanks for the reply Martin
I certainly don't have a throttle finger made of butter lol, so I have managed to find a GM 90 that should do the job?
008-Racer is offline   Reply With Quote
Old 09-26-2011, 01:45 AM   #2674
Thanks for your answer Martin.
Just one confirmation :
To apply 6 timing for example, "Fixed timing" = 6, "Max timing" = 7, "High speed timing checked".
Is it ok ?
kerb is offline   Reply With Quote
Old 09-26-2011, 11:17 AM   #2675
Send a message via ICQ to MattW
Kerb, As Martin has said, personally I wouldn't see 120 ESC temp (in the software) as an issue. If it's below 140, then I'm happy - and if it's above 140, it will soon let you know!!
I don't know what the timing values actually mean - not sure if 6 actually means 6 degrees. Hence I just talk about actual timing values.
MattW is offline   Reply With Quote
Old 09-27-2011, 12:31 AM   #2676
Is it ok ?
you have to have ticked Highspeed timing and highspeedtiming with switchpoint! you want a switchpoint
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-27-2011, 01:30 AM   #2677
defcone's Avatar
Trader Rating: 15 (100%+)
Anyone know why my GM 90 gen2 flashes red green yellow everytime I do a factory reset?
defcone is offline   Reply With Quote
Old 09-27-2011, 01:41 AM   #2678
When does it flash? when it's running in idle state -> 0-boost program ofcourse
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-27-2011, 01:48 AM   #2679
defcone's Avatar
Yeah I thought about that too, but I tried going to mode eight and it still does it.
Old 09-27-2011, 02:23 AM   #2680
Motor connected?
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-27-2011, 03:07 AM   #2681
defcone's Avatar
Motor connected?
Lol yes, battery in, transmitter on.
Old 09-27-2011, 03:44 AM   #2682
hacker's Avatar
Trader Rating: 141 (100%+)
haha you have the perfect blinky speedy
edit.....does it actually go into mode 8, and blink?
hacker is offline   Reply With Quote
Old 09-27-2011, 04:42 AM   #2683
defcone's Avatar
Yes I haven't thought about that
Old 09-28-2011, 03:27 AM   #2684
njsmurf's Avatar
Default motor cold but esc and lipo hot
Hi all i am new to the site so be nice!! I run a gm gen2 75 v13 1s lipo and i am trying a delta 8 in my 1/12 car at the moment and could do with some help i started with Martin set up guide and it works well cool motor and esc but i needed to find a little more top speed so I went up 2 teeth on the gearing now the esc and lipo are getting hot
so i have been reading some posts on here that say i should lower the frequency does this change the top end?? I will b trying 8 down to 4
And should i gear harder again??
Any help would be appreciated
1/12 CRC Xl 1s lipo
njsmurf is offline   Reply With Quote
Old 09-28-2011, 05:14 AM   #2685
Are you running any timing on it ?
gearing for 8delta last year for me was ~43-45mm with no timing. 4 on frequency
CPD Racing
chris_dono is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
