Old 09-22-2011, 07:54 AM   #2656
Yes, no magics.
Low power mode2 with fdr around 6, it could works
Regards.
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 09-22-2011, 08:45 AM   #2657
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
No it doesn't. The motors blew up and the speedo kept desoldering itself.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-22-2011, 11:54 AM   #2658
Send a message via ICQ to MattW
It kind of works, but there is no point as the newer ways are much better.
I tested it last year a few times with a 8 turn delta running sensorless and 6.0 gearing. The feel was nice, but it wasn't as fast as a 4.5 with timing around 10. You can smell the heat in the motor as well!! So I wouldn't recommend it either.
MattW is offline   Reply With Quote
Old 09-22-2011, 04:55 PM   #2659
Maybe Marc should read Martin's readme
Michal Abramowicz
Old 09-23-2011, 12:04 AM   #2660
hacker's Avatar
Trader Rating: 141 (100%+)
you use timing with a 4.5 motor ?
hacker is offline   Reply With Quote
Old 09-23-2011, 12:22 AM   #2661
He knows it. But the track was super super tiny. I not used any timing with a 5.5 aswell. Just pointless.
On UK tracks yes. You need timing. The straights are HUGE!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-23-2011, 12:28 AM   #2662
hacker's Avatar
just use a 3.5 or 4.0
Old 09-23-2011, 12:54 AM   #2663
No.
It's far more unefficient and I guarantee, you will not be able to finish a run with a 3.5T motor. Unless you are going slower than you did with the 4.5!
It's the same reason why the new BMW M5 uses a V8 biturbo instead of the mighty V10. Simply because it's a far better way to achieve proper performance.
A 4.5 will be fast enough. And it won't cause any major heat problems.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-23-2011, 02:47 AM   #2664
Most people were running 4/4.5 (7/8/9 delta) maximum for this year in modified here in the UK, Martin knows how long our straights are
CPD Racing
chris_dono is offline   Reply With Quote
Old 09-23-2011, 12:21 PM   #2665
Martin did you get to see halifax and mendip.....those are proper uk straights
Craig Morgan - Tamiya 417
Slick990 is offline   Reply With Quote
Old 09-24-2011, 07:10 AM   #2666
Yes I have run 4.5 all year on every UK national track, and actually on the same gear ratio all year as well - just adjust the amount of timing. I used none at the smallest track of the year, and up to 12 on the bigger tracks.
Old 09-24-2011, 07:18 AM   #2667
Can you give me the constant gear ratio you use with 4.5t motor and timing ?
You use only 'fixed timing' ?
Thanx a lot.
kerb is offline   Reply With Quote
Old 09-24-2011, 09:54 AM   #2668
Looking to do a little 2WD buggy racing soon and i was hoping to use my spare GM75
Can it be used with a 7.5 Turn mod motor, I know it doesnt say so on the instructions but thought i might have seen something regarding one of the mod boys running a 75??
008-Racer is offline   Reply With Quote
Old 09-25-2011, 10:53 AM   #2669
kerb, I've run 7.33 ratio all year. Fixed timing has ranged from 0 for small track, and 12 for big track. Max timing 1 point higher.
Old 09-25-2011, 11:12 AM   #2670
Thanx matt.
You don't have any other heat problem with this ratio ? I reach more the 120 degres on my esc with no timing and 7.5 ratio....
Is it possible to have the files of your setup by mail ?
My email : forumgratte(at)sfr.fr
Thanx !
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
