Old 09-14-2011, 05:04 AM   #2641
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by M.Abramowicz View Post
Martin,
you test my file from speedo?
Also, http://hofaaa.files.wordpress.com/20...eg?w=640&h=478 this bag you take to plane as hand bag? No problems in airport?
Regards!
m
yes, it just is within the maximum size of easyjet!
As for your speedo file:
@everyone, please don't use the file previously posted.
@M. I can't believe you are suggesting such a setup to other drivers. I'm pretty sure you have never had a proper read through the V13 guide and I'm not sure you actually understood what you changed on your speedo settings when you did them. Best example is 90C for speedo and motor temp. This is the internal temp! 140 inside the speedo is 70 on the outside! so with 90 set, you can barely leave the line before it reaches this temperature. Even with a 17.5 it goes above 90.
When you will have a look at the file I am going to upload as attachment to this post, you will realize how much it differs to yours.
I really really suggest that you put it on your speedo, gear the motor somewhere between 7.0 and 8.0 depending on the track and run it with no modifications at all!
I'm sorry to be this direct but after having seen your setup I think it is necessary.
So see attachment (change the .zip ending to .gd2):
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-14-2011, 09:21 AM   #2642
Dear Martin,
I read your guide but how y can say that it is ONLY ONE PROPER WAY?
It is file from last run:
http://abram.eu.org/after-race-mode3.gd2
I know what is internal temp, I know even how to put ntc thermistor to older GM engine I reach only limit on 90C in speedo when I put 5 DELTA engine (GM made mistake and send is as STAR).
This setings are safe for my friends and me, especially when I put 5 delta engine . Maybe we race too slow in modified to get higher internal temps
Also me and my friend said that using HST and HST with switching point sucks, it drive fast and start drivin faster when use max th and hold it.
On short track it sucks, no place for this feature.
Also just try move with GM engine (I know that y use it) from 0 to 30 deg with sensor. It drasticaly change behavior of engine, it starts working.
I was looking for better performace, it is some ways to do it, but when y think that your way is only way to go, I will switch to hobby wing, simple stupid working fast without too much features speedo.
I saw on track that my car on same gearing, with normal mode 3 (after reset) and 5.5T was slow. Then only change from 0 to 30 with sensor, start drivin faster, when I add power curve 1 (soft additional timing to modified ble ble) it start drivin much faster. On 8T delta, same gearing, same settings was much faster
I try HST but it sucks, it broke my skils, because car drive fast and sudenly start driving faster.
I prefer it like driving normal car, add some th, some speed, at more th, more speed, at max th, max speed, which was faster then my friend on 4.5T.
Anyway, thank you for your time.
Good luck.
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 09-15-2011, 02:05 AM   #2643
daleburr's Avatar
Yeah but then you'll have to read the endless drivel posted on the Hobbywing threads. It's just not worth it, I'd rather push the car round.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 09-16-2011, 01:54 PM   #2644
Sorry to ask a silly question again!!
Running 13.1 and cannot for the life of me remember how to get the GM into blinky mode??
And how do you do a factory reset?
008-Racer is offline   Reply With Quote
Old 09-16-2011, 04:01 PM   #2645
Factory reset:
Hold setup button down to go into "mode picker" release button, then hold again until you get the long beep
Blinky: Standard Mode 2
CPD Racing
chris_dono is offline   Reply With Quote
Old 09-16-2011, 04:42 PM   #2646
Thank you
Originally Posted by chris_dono View Post
Factory reset:
Old 09-18-2011, 03:48 AM   #2647
scoyle's Avatar
I have been offered a GM 90 speedo - can I ask how many versions there have been (I see the latest one is 2010) and also what is the latest software that can be installed on it?
scoyle is offline   Reply With Quote
Old 09-18-2011, 12:39 PM   #2648
daleburr's Avatar
Basically if it's not a 2010 don't buy it.
The 2010 introduced user-updatable firmware, so you can install the latest 13.1 firmware on it. Previous models had to be sent back to the factory for upgrades and can only go upto something like v8 firmware which won't be quick enough for any kind of boosted classes.
Team Xray
Old 09-19-2011, 03:07 AM   #2649
scoyle's Avatar
It is the 2010 version... so I just follow the instructions here to set it up to the latest software?; http://www.rctech.net/forum/7908081-post1851.html
Old 09-19-2011, 09:45 AM   #2650
There's one better than that now, again thanks to Martin H. Clicky Here
YZFAndy is offline   Reply With Quote
Old 09-21-2011, 05:29 AM   #2651
Ah yes I was wondering when it would be available.
Hope you like it
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-21-2011, 08:27 AM   #2652
defcone's Avatar
Trader Rating: 15 (100%+)
Hope you like it
Do You know why Marc Fisher used a low FDR like 6 for a 5t motor?
defcone is offline   Reply With Quote
Old 09-22-2011, 02:59 AM   #2653
Because he likes to do full throttle out of every corner and he found that the super low gearing enabled him to use full throttle out of corners as the motor was bogged down a bit. But it got so hot, that he broke one even though he used 2 fans to cool the motor down! so not suggestable.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-22-2011, 06:16 AM   #2654
It is possible to get Marc's speedo setup file?
m.
Michal Abramowicz
Old 09-22-2011, 06:49 AM   #2655
Very easy:
Do a factory reset. Pick mode 2. Done.
Marc always uses factory mode 2 with no changes at all.
Actually he used an old version 1 firmware 4.6 speedo until Sunday because he runs sensorless a lot and the old speedo is better off the line sensorless. But the wires where no good anymore and instead of changing them he used a v2 speedo in factory mode 2 then.
You see no magic.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
