Old 08-24-2011, 04:52 AM   #2611
daleburr's Avatar
Originally Posted by jorgesimes View Post
What?
Lol, just edited my post as it looked like I meant 90deg timing. Man that would be fast
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 08-24-2011, 05:01 AM   #2612
LOL.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 08-25-2011, 06:51 AM   #2613
Mário Ribeiro's Avatar
Send a message via MSN to Mário Ribeiro
I´m looking for a starting setup for GM120 Gen2 (v13.1) with GM Pro 5.5T for 1/10 4WD buggy, for indoor carpet and astroturf.
Can anyone help me ?
Viper R/C Solutions | Gens Ace | UMDEZ
http://www.viper-rc.com | http://www.umdez.com | http://www.gensace.com
Mário Ribeiro is offline   Reply With Quote
Old 08-26-2011, 02:31 AM   #2614
1. do factory reset, choose mode 3 and Y are set
2. if want little more power just see this files:
http://abram.eu.org/files/GM_V13.1/
Regards!
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 08-26-2011, 04:15 PM   #2615
Hi!
GM 90v2, V13.1.
Did someone get problem like that:
- connect accu,
- switch put to ON,
- esc made some sounds like usually.
Then put trigger and no revs
Must again choose mode by tx before race and it works to next time.
I always have switch set to ON, just connect accu.
Don't know where is problem.
My file there:
http://abram.eu.org/files/GM_V13.1/m...t-gray-pro.gd2
Always have Switch = 0 ....
Anyone?
Regards!
m
Michal Abramowicz
Old 08-27-2011, 12:11 AM   #2616
Hi all,
I just ordered a GM75 and USB programmer, after checking out the software it appears to me I also need to pay 10euro's for use of the software!
I expect there will be a registration key with the programming interface, but can anyone confirm this?
Else, can the CS program be used with the ESC?
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 08-27-2011, 03:24 AM   #2617
housey's Avatar
Originally Posted by Quante View Post
Hi all,
You don't need to pay to register the software, it works anyway.
Chris Swallow - Team Yokomo - GM Racing - Ko Propo
Donny Racing - http://donnyracing.yolasite.com/forum.php
Poweeeeerrrrr!
housey is offline   Reply With Quote
Old 08-28-2011, 06:39 AM   #2618
Anyone?
Originally Posted by M.Abramowicz View Post
Hi!
GM 90v2, V13.1.
- connect accu,
- switch put to ON,
My file there:
Anyone?
Regards!
m
Michal Abramowicz
Old 08-29-2011, 02:06 AM   #2619
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Why don't you just use the V13 basic file altered towards the motor you are running? I so far know noone who has had any trouble with it.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 08-29-2011, 03:27 AM   #2620
Hi Martin,
because standard mode 3 has less power then little updated
Also on standard mode 3 problem is not solved
With sensor or without sensor wire ...
Crap
m.
Michal Abramowicz
Old 08-29-2011, 03:31 AM   #2621
I have with no word said use standard mode 3, but stick to the V13 guide. Then this will be as fast as the speedo will go.
If this doesn't help the problem is elsewhere. Maybe you should think about using the switch as a switch
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 08-29-2011, 03:38 AM   #2622
Martin.
I read many times your post.
It works for stock/spec racing, but when I stop racing cheaters class, I start
play with modified engines and power
Why I should use less power settings when I can drive faster???
Anyway, will try find wtf is wrong
Michal Abramowicz
Old 08-29-2011, 05:15 AM   #2623
it works perfectly for modified racing aswell.
Because in Modified the balance of feeling and pure power has to be found. Even though GM is still the fastest with exactly the profile used for the V13 guide.
I will have a look at your setupfile later today when I get back home.
There are many ways to get a Modified car go fast but there's only one efficient way that doesn't kill either tires, motor, speedos or feel!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 08-29-2011, 05:25 AM   #2624
Hi Martin!
I work on this setup.
I found for me sweet point for gearing, engine, temp on engine.
Throttle feel, low speed acceleration and top end on stright.
Belive to me, it drive fast, engine is cool (70C max what I get).
When Y look to file and find "problem" tell me.
Engine is gm pro 5.5T (new gray can with ntc thermistor).
Regards!
m.
Michal Abramowicz
Old 09-03-2011, 12:47 AM   #2625
Hi,
I'm looking for a good setup. I just ordered GM-Genius 75 (97163) and
BRUSHLESS GM PRO 17,5T motor (97357), LiPo 7,4
I also looking for setup for GM90 [97164] with Robitronic Platinium 9.5T [R03007] and LiFe 6,6V.
Track: carpet, indoor, technical, medium traction, 25m straight.
thanks for any advice!!!
air88 is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
