Old 06-20-2011, 07:15 AM   #2551
defcone's Avatar
Trader Rating: 15 (100%+)
For Hofer's v13 how-to, what mode are you supposed to use for stock and mod respectively?
defcone is offline   Reply With Quote
Old 06-20-2011, 07:44 AM   #2552
Slideaway's Avatar
Like said in the PC software "MODE" instuctions (click on the "?" mark) :
Factory settings:
Modified modes:
- Mode 0 (forward, with brakes): modified low grip (PRO 10)
- Mode 1 (forward, with brakes): modified high grip
- Mode 2 (forward, with brakes): modified medium grip (THE MOST USEFUL)
- Mode 3 (forward, with brakes): modified low grip
- Mode 4 (forward with brakes, reverse mode 1 available)
- Mode 5 (forward with brakes, reverse mode 2 available)
Modes for stock racing with 9.5T...21.5T with variable timing with hall sensors
- Mode 6 (forward, with brakes): soft additional timing
- Mode 7 (forward, with brakes): medium additional timing
- Mode 8 (forward, with brakes): high additional timing
- Mode 9 (forward, with brakes): max. additional timing
For STOCK, It depends of the motor turns but mode 7 is a good start.
Ludo
Thai Ride Tech Support.
Slideaway is offline   Reply With Quote
Old 06-20-2011, 09:42 AM   #2553
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Hi guys could any of you help me out as ive got a problem ive just change from gm120 firmware 7.2 to an gm90 firmware 13.1 in last couple of week ive blow 2 sp v3 a 13.5t and 17.5t i race on 20 x 30mtr carpet track i dont know what im doing wrong but after 4minutes the motor goes up in smoke any ideas what im doing wrong.
Dont have this problem running gm 10.5t motor
Craig W is offline   Reply With Quote
Old 06-20-2011, 11:24 AM   #2554
I think with just these informations is kind a difficult to help. Give us more details. Like ESC setup, ratio, scale your running, etc.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 06-20-2011, 12:38 PM   #2555
Maybe
This comes across wrong, but just run the gm motor?
CPD Racing
chris_dono is offline   Reply With Quote
Old 06-20-2011, 01:48 PM   #2556
Craig W's Avatar
Originally Posted by chris_dono View Post
Maybe
I've just orded 13.5t gm to try
Old 06-20-2011, 01:51 PM   #2557
Craig W's Avatar
When the 13.5 and 17.5t blow both were running Martins v13 setup with fixed timing set at 25
just dont know why sp blow
ran x11 on same setting know problems
im total confused
Old 06-20-2011, 01:56 PM   #2558
Hi everybody,
I would to know something about the GM120
I have a 5.0T and i dont know how some adjustements are working...
fixed timing ?
Timing 1 ?
Timing 2 ?
Min. Timing Time ?
Max timing ?
It's for a 5.0T, could you give a good basic setup for it ?
Best Regards
Manu_05' is offline   Reply With Quote
Old 06-21-2011, 01:52 AM   #2559
daleburr's Avatar
You can use any mode, as you overwrite it with Martin's profile (attached to the v13 guide post).
Buy a temperature gun. Run for 2 minutes, check the temp. Run for 3 minutes, check the temp. Run for 4 minutes, check the temp.
If at any point the SP v3 is over 70degC then your settings are too agressive. Run less fixed timing, a lower amp limit or adjust your gearing.
Originally Posted by Manu_05' View Post
Hi everybody,
fixed timing ?
Timing 1 ?
Timing 2 ?
Min. Timing Time ?
Max timing ?
Best Regards
Read the v13 guide here:
http://www.rctech.net/forum/7908081-post1851.html
And ignore all the other settings, most of them don't do anything in the v13 software.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 06-21-2011, 03:13 AM   #2560
im total confused
this could be a silly question, but have you made the radio setup after sending the values of the V13 basic file?
What ratios are you on?
Team AME/ORCA
Old 06-21-2011, 03:23 AM   #2561
Craig W's Avatar
was running 7.4 on the 17.5t and had my tranny settings was quick for 4 minutes them slowed down and then loads of smoke
Old 06-21-2011, 03:59 AM   #2562
daleburr's Avatar
I think you're undergeared and the motor is revving its nuts off. I run on a track not much bigger than this and gear my 10.5 SP at about 6.5. I would think for 17.5 you'd be looking more in the 5.5 region, maybe less.
But as I said above, if you use a temp gauge and do short runs each time you change motor/gearing/profile/track you can try any settings you want and stop when it looks to be getting too hot.
A 20 tool can save you 100s on motors.
Team Xray
Old 06-21-2011, 04:25 AM   #2563
For sure undergeared. The motor will feel real fast but will be all the time on boost, wich lead to serious heat in the motor in a short period of time. I think Dale is right about ratio. Even better than a temp gauge is to use a motor with NTC, wich SPv3 motors doesn't have. With the GM PRO will be no problem because it has NTC and you can choose your temperature protection in the ESC.
Team AME/ORCA
Old 06-21-2011, 07:28 AM   #2564
Craig W's Avatar
When talking to guys in sp forum they are running 7.2 to 7.4 but thes with sp gt2.1
Old 06-21-2011, 09:55 AM   #2565
as Martin stated somewhere, GM esc doesn't need that.
Team AME/ORCA
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
