Old 05-25-2008, 11:45 AM   #241
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
lower fdr approx. 0.5
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 05-25-2008, 01:57 PM   #242
Send a message via MSN to mark34 Send a message via Yahoo to mark34
Thanks for the reply btw what speedo is that in your yokomo
Yokomo BD
CEFX C12
Powered By Demon Batteries and GM Brushless and 2 thumbs
Mark Ashby
mark34 is offline   Reply With Quote
Old 05-26-2008, 03:56 AM   #243
it's a genius 95
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 05-26-2008, 04:02 AM   #244
How did you get the blue caseing and the fan kit
Mark
Yokomo BD
CEFX C12
Mark Ashby
Old 05-28-2008, 10:54 PM   #245
there was a blue batch beeing sold a while ago.
the very last batch is black again.
the "fan kit" is actually only the additional top heatsink with a fan mounted (muchmore 25mm seems to work fine)
but i only use a fan for safety when i run 5T delta.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 05-28-2008, 11:04 PM   #246
Where can the delta motors be purchased?
And do they run with speedies other than the GM unit? or odes it need to be a sensoreless
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 05-29-2008, 10:04 AM   #247
can be bought in any shop carrying gm products
the lrp esc is not capable of powering a 6 or 5T delta. It just will blow up.
7T is the limit.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 05-29-2008, 10:08 AM   #248
As far as i know delta wound are know as easier to drive for sensorless system. It's still a slotted design (not 100 % reliable for startup) but it should work properly with any sensorless system, SP GT, Tekin R1 and RS, CC Mamba Max and sidewinder
Mister-T is offline   Reply With Quote
Old 05-29-2008, 10:18 AM   #249
7T is the limit.
Others okay with 6T? SP? Tekin?
The Crack Fox is offline   Reply With Quote
Old 05-29-2008, 02:44 PM   #250
burito's Avatar
7T is the limit.
Sorry Martin, but you're wrong on that! With correct timing setting on motor, a 6t Delta will work flawlessly with LRP TC-Spec. This we tried last year, but for us it worked the same as regular 3.5t (Star) and therefore there was no point in running 6t Delta's. 5t Delta we never tried, but I would not think it would damage anything on our speedo.
Try focusing on giving advise for GM products and not badmouthing ours...
Reto Koenig
burito is offline   Reply With Quote
Old 05-29-2008, 03:21 PM   #251
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
Send a message via AIM to DENNIS STORTI
DENNIS STORTI is offline   Reply With Quote
Old 05-29-2008, 03:24 PM   #252
Holmenkollen's Avatar
Wich is the correct timing?
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 05-29-2008, 03:45 PM   #253
Dear Reto.
I know that you tested 6T Deltas during perperation for the german nationals last year.
But as you might know this threat is about the GM Brushless.
And the GM Pro 6T delta does not have an adjustable timing, therefore it cannot be adjusted towards your ESCs needs. The Evo 3 6T can be timed but not enough either.
I am not willing to recommend any user to go and buy a motor and then wreck his esc just because I said it should or may work.
I am sorry for this missunderstanding.
I never wanted to say your ESC is not capable of powering any delta windings. It just cannot deal with our 6Ts, as timing is not correctly set.
Regards.
Martin.
@ all others:
I do not know of the tekin's timing but I know of the SP esc. Set the timing to 0 running sensors or 30 (29,something i think it is right?) running without.
If the Tekin can be set to those values too, it should be fine.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 05-29-2008, 04:14 PM   #254
Thankyou sir!
Old 05-31-2008, 01:52 PM   #255
Default Full Power Issue
Can someone help me out.
For some reason from time to time the throttle settings on my GM100 seem to wonder. Today when i can to use it i couldnt get full power but as soon as i reset it, it works fine.
i have had this 3 or 4 times now and cant work out why its happening?
It isnt anything obvious like the trim on the transmitter moving so i can only think its a fault in the speedo - is this likely?
stuartb is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
