Old 04-25-2011, 04:00 AM   #2461
housey's Avatar
Well the cap will help to keep a steady and constant in voltage to the speedo, I think the main purpose is to stop them overheating. But like you said I'm sure they give you a fair amount of punch as well because the caps help stop voltage drop to the speedo when you suddenly draw current from the battery (accelerate).
So yea based on all that chat, I'd say try some new caps. After that........eerr give mystic meg a ring? Or maybe the Fosters guys, they seem to have an answer for everything...
hth dude
Chris Swallow - Team Yokomo - GM Racing - Ko Propo
Donny Racing - http://donnyracing.yolasite.com/forum.php
Poweeeeerrrrr!
housey is offline   Reply With Quote
Old 04-25-2011, 04:04 AM   #2462
Originally Posted by adri-13 View Post
When you have finished your PC set-up, you can re-calibrate your mode to be sure your speedo can work good.
Sorry mate, can you say that another way? It doesn't translate well, not sure what you mean.
But yes install is the same because i installed his. Should add as well its not going to be all my driving style either because his still stays cooler even when i drive it.
YZFAndy is offline   Reply With Quote
Old 04-25-2011, 04:14 AM   #2463
housey's Avatar
Caps
Poweeeeerrrrr!
Old 04-25-2011, 04:21 AM   #2464
adri-13's Avatar
sorry, I'm not so good in English
When you have finished your speedo's set-up on the computer, try to make an another time your speedo mode with your transmitter.
For example, you drive with the mode 9. You change your speedo's setup with your computer, you disconnect your speedo and you make an other time the mode 9 with your transmitter to be sure your speedo is really calibrate with your transmitter.
An other question for you: You drive with a lot of brake?
PETITrc driver
www.PETITRC.com
http://rcracereportsigm-racing.blogspot.com/
adri-13 is offline   Reply With Quote
Old 04-25-2011, 04:26 AM   #2465
locked's Avatar
Maybe your friend has less friction in his drivetrain? You might have a bearing or two that needs replacing or to be cleaned and oiled at least or there might be some other area binding a bit. A little resistance in the drivetrain can definitely raise motor temps.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 04-25-2011, 04:45 AM   #2466
HOW DARE YOU,. get out . After every meet my car is stripped, every ceramic bearing oils and every drive shaft lubed. Not going to be anything like that.
Yes transmitter is defiantly calibrated correctly. And yes i brake a lot harder than most. But still don't overheat my friend car which is basically identical to mine.
Old 04-25-2011, 05:21 AM   #2467
housey's Avatar
Caps......
Poweeeeerrrrr!
Old 04-25-2011, 05:44 AM   #2468
housey's Avatar
Error
Poweeeeerrrrr!
Old 04-25-2011, 07:01 AM   #2469
hana166's Avatar
I assume drive frequency is also same as your friend
hana166 is offline   Reply With Quote
Old 04-25-2011, 10:59 AM   #2470
Yes, same frequency, profile copied exactly.
Old 04-26-2011, 02:23 AM   #2471
hana166's Avatar
It can be driving style/brake. Try a spare speedo, same model to be sure
Old 04-26-2011, 02:30 AM   #2472
I use GM PROstock 10.5 motor with 12.5mm rotor. I have tested it without the booster/rx battery but the speedo switch on. My GM 95 have the v4.8 .
I have a GM 75 but I use this on my Xray T3'11 and I want to drive with my 1/12 chassis too but my touring car season is not finished...
Get pc software 1.1.5, set mode 8 by tx, then copy 8 to 3, set cutt off to lower value that you can. Set amp limit 90-100A max, start 70A, turbo 1.
Also choose (if it has) new software for break and autobreak, you can tick abs option.
It is max what you can push from this speedo.
Keep cool, drive fast!
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 04-26-2011, 10:23 AM   #2473
Originally Posted by housey View Post
Caps......
From what i'm reading with regards to all the capacitor upgrades that are available for various controllers it does lean towards maybe one of the has gone. Found some of the same spec on the ebay so have them on the way. Does anyone know if i'll be able to add an extra one?
Old 04-26-2011, 11:19 AM   #2474
housey's Avatar
I think the capacitor farad and voltage rating is tuned to each speedo and application, ie, 2s or 1s. So I would just get a new set of identical caps and replace the old ones like for like. Thats the only way to really know if the old caps are to blame for your troubles, by removing them from the system all together and replacing with identical new items.
Poweeeeerrrrr!
Old 05-02-2011, 03:15 AM   #2475
Default Blinky mode
Hey All
Does any one have a good speedo setup for blinky mode? In Denmark we're supposed to run blinky in super stock.
Will be running a 13,5 T motor and a GM 90 V2 speedo. I know mode 2 is a good starting point but was wondering if any one has been able to crank a little more speed out of the speedo???
Best regards from Denmark
ssoslot is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
