Old 03-17-2011, 11:11 AM   #2401
Originally Posted by Grindog001 View Post
I just like the yurbo coming in so early. .
The GM doesn't work like that. With the Gm the timing is controlled by throttle input not by a motor speed switch point.
YZFAndy is offline   Reply With Quote
Old 03-17-2011, 11:28 AM   #2402
John_S's Avatar
John_S is offline   Reply With Quote
Old 03-17-2011, 12:32 PM   #2403
Hi has anyone got a setup for the LRP X12 13.5 they are will to share and gearing rec. 30m straight?
008-Racer is offline   Reply With Quote
Old 03-17-2011, 04:07 PM   #2404
-10 degree four dot insert on motor. 18 degree timing on controller and geared at 6fdr. RPM swith point around 7500-10000 rpm helps keep things a lot cooler as does current limiting to about 80-90 amps.
Old 03-17-2011, 04:09 PM   #2405
Thank you so much
Never seen this combo together on track is it quick?
Old 03-17-2011, 04:39 PM   #2406
The GM and X12 do work well together and have very good top speed. Down side is the top end punch is a bit aggressive. Use the current limit function to tame it down a bit if you find it to aggressive. Also this setup was running at around 90-100c for me on a 25metre straight. Should run cooler for you and is still a perfectly safe limit for the x12. But if you want to be more cautious drop the main timing down on the controller a couple of degrees.
Old 03-17-2011, 04:42 PM   #2407
Thank you and really gear at 6 on a 25m - 30m straight seems pretty hard for the X12?
Old 03-17-2011, 05:07 PM   #2408
x12's seem very sensitive to gearing and heat. If you over gear they draw too much current and get hot. If you under gear and over rev they also get hot just as quickly. 6.2-5.9 seems to be the sweet spot for the 13.5 no matter what the layout is like. I have just stuck with 6fdr and used as much or as little timing as i could get away with (temperature wise) set on the controller. Always run the motor with -10 degree four dots facing out insert.
Old 03-27-2011, 02:38 PM   #2409
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
GM Broken in crash...
purchased from Schumacher UK, does anyone know how to get it repaired?
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
Old 03-27-2011, 02:49 PM   #2410
Send a message via ICQ to MattW
http://www.racing-cars.com/sitepage/...%20Centre.html
MattW is offline   Reply With Quote
Old 03-27-2011, 08:18 PM   #2411
Where can i get a 4.5 gm motor? The following site never has them in stock!!!
http://www.racing-cars.com/sp/catego...ss_Motors.html
dex410usa is offline   Reply With Quote
Old 03-28-2011, 01:22 AM   #2412
what have you done?
my friend in Warsaw have got really small hit, and speedo stop working, no sounds, no beeps, no nothing
he send it to GM/DE
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 03-28-2011, 02:34 AM   #2413
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
Originally Posted by housey View Post
Glad its going well. Any more help needed then just ask away
Can't say anyone has been giving me trouble on the straight recently, in fact this weekend I was told by a CML driver that mine was a rocketship
Anyway, its not all about having that extra foot on the straight, I'd sooner be a tiny bit slower on the straight than have to put up with a Tekin on the infield, feel on the GM is amazing.
here it comes i used it with an x11 13.5T on a carpet track geared 6.2fdr. however, next race will be on a large outdoor track with a 60meter straight and a demanding infield. wonder how low i can go with the gearing before cooking motor or esc!? 5.5? 5.0? anybody tried this?
vitomon is offline   Reply With Quote
Old 03-28-2011, 04:18 AM   #2414
housey's Avatar
I wait to be corrected but I think 5 would be just fine.
Chris Swallow - Team Yokomo - GM Racing - Ko Propo
Donny Racing - http://donnyracing.yolasite.com/forum.php
Poweeeeerrrrr!
housey is offline   Reply With Quote
Old 03-29-2011, 05:36 AM   #2415
Nope.
Start from FDR = 6.0 with X11/13.5T then take temp on can, then think what
you can improve
Regards!
m
ps: X11 is easy to cook, it doesn't have internal temp sensor so it sucks
I fired up 13.5T and 17.5T
Michal Abramowicz
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
