GM Brushless
Old 03-12-2011, 06:45 AM
  #2371
Trader Rating: 10 (92%+)
here is my brake profile
captain stacker is offline
Old 03-12-2011, 08:07 AM
  #2372
I would probably reduce your max brake and your full brake. I have experienced the same problems, where I thougt the brakes didn't work. It was all down to the fact that the speedo locked up the wheels so I was sliding into the corners, resulting in understeer.
I run rubber tires, and uses around 70% - 85% based on the traction of the specific track I race at.
Regards
Søren
ssoslot is offline
Old 03-12-2011, 08:27 AM
  #2373
Regards
Søren
definitely not locking up, I mark my rims purposely for this reason to see if the wheels locks up.
Old 03-12-2011, 08:52 AM
  #2374
Reduce "effect new brake software" down to 50. Remove current limit off brake, box checked.
YZFAndy is offline
Old 03-13-2011, 03:43 AM
  #2375
2wdrive's Avatar
this is offtopic kinda but it is still related to GM so i put it here in this thread instead of making a new one. I am looking for some new saddle packs and saw on the GM website the 5600mAh 60C saddlepacks. In the specification it says:
Capacity @10 A typ. 5300 mAh
What does that mean? Does it mean that when under load the capacity drops off from 5600mAh to 5300mAh? Why would that be? I never saw this in other descriptions so it made me wonder. When looking at other GM lipo's it is stated as well in the descriptions.
Could it be that other brands lipo's have that as well and that gm is the only one putting that in the specifications?
2wdrive is offline
Old 03-13-2011, 04:29 AM
  #2376
hacker's Avatar
Trader Rating: 141 (100%+)
need a new GM software update, getting motored by HW's now. The 119/211 software is just insane.
hacker is offline
Old 03-13-2011, 08:13 AM
  #2377
got there before me "effect new brake software" is the one to reduce
chris_dono is offline
Old 03-13-2011, 08:44 AM
  #2378
ok, will try this down to 50. So I just assume if I put it to 0, it will become even better.
remove it or select it? I will assume you mean select it, but I'm not sure why you said 'remove'.
Old 03-13-2011, 08:46 AM
  #2379
actually, come to think of it, I have done the above, as I messaged Ralf from GM, and he gave me this setting below to try, however it was not any better braking. Although he did not tell me to use 'new brake software'.
however I will try all the above again, one at at time.
and yes, we need an update soon as I also came up against some hobbywings today and was not able to keep up in straight line speed.
Old 03-13-2011, 10:46 AM
  #2380
You remove the current limit by ticking the box. A limit on the brakes can make them feel soft.
I can't say if 0 will disable it or make it better. It will definitely be more like an on/off switch the lower the number you use. What "effect new brake software" does is to make the brakes come in more gentile the faster the motor is revving. This stops sudden lock-up, transmission stress and will help to transfer load on to the front tyres and ultimately give you more braking grip. You just need to find the right level for your needs. Most of the time just locking up all four wheels isn't going to be the quickest way of stopping.
YZFAndy is offline
Old 03-13-2011, 03:09 PM
  #2381
John_S's Avatar
Hello can i please ask what your reserved 4 is set to on the telemetery page. Thanks
John_S is offline
Old 03-13-2011, 11:11 PM
  #2382
I have heard with the lrp x11 motors changing this to 7 is better, I'm not sure what it's at but I think I saw it was 1 the last time I checked. I'm not using x11's however. Generally epic and novak motors
Old 03-14-2011, 01:17 AM
  #2383
hana166's Avatar
Oh yeah ? I've been racing against the new hobbywing quite a bit. Its really, really quick for sure but my car quicker still
I reckon its all getting pretty even now in the brushless war
Whoever understands set up best will have greatest straight line speed
But one will still lose to a driver with a better set up car. Always
Powerrrrr !
hana166 is offline
Old 03-14-2011, 02:01 AM
  #2384
hi guys,
thx guys for the help with gearing. i used martins program with an x11 13.5T motor and 1:6,1 FDR. MAN THIS THING FLYS!!! no break problems what so ever. i even had to reduce breaking power on the transmitter to 70%. great torque and great top speed. lap times were roughly 15.4s. managed to lay down a 15.0 many times whereas tekins, HWs, lrp's etc did 15.2 best.
cheers
vito
vitomon is offline
Old 03-14-2011, 10:48 AM
  #2385
housey's Avatar
Originally Posted by vitomon View Post
hi guys,
cheers
vito
Glad its going well. Any more help needed then just ask away
Can't say anyone has been giving me trouble on the straight recently, in fact this weekend I was told by a CML driver that mine was a rocketship
Anyway, its not all about having that extra foot on the straight, I'd sooner be a tiny bit slower on the straight than have to put up with a Tekin on the infield, feel on the GM is amazing.
housey is offline
