GM Brushless
Old 02-23-2011, 07:50 AM
  #2341
housey's Avatar
Originally Posted by Jonathan P. View Post
Housey, you should look around page 133 in this thread.
My rain car is running an GM 8T Delta. The tips from Martin in this thread, gave the car similar speed as a 4.5t in normal sensored mode.
Which is fast enough for a rain car
J.
I don't really understand why unticking the hst and changing the switchpoint etc will make a difference. I thought that as soon as you unplugged the sensor cable the speedo went into a standard sensorless mode with 30 degrees fixed timing and that was it. I'm sure when I asked about sensors not so long ago that Martin himself said that. He said there isn't (obviously) any dynamic timing in sensorless so why the need to untick stuff and change switchpoints?
How are you gearing your 8T Jonathan? I'm wanting after an indoor gearing now with it sensorless, I was thinking around 8-8.5ish?
I know Martin's how to would suggest that with it sensored you should run timing at around 12ish right? How does that change the gearing, how many teeth am I going to drop once I have it sensored and timed?
Thank the lord for everyone on rctech, dunno where I'd be without all this info!
housey is offline
Old 02-24-2011, 09:10 AM
  #2342
No idea, I believe it's better to be safe than sorry.
On an outdoor asphalt track which was really wide open, I ran it with 2 more teeth on the pinion than I did with a 4.5 on an LRP SXX TC.
Jonathan P. is offline
Old 02-24-2011, 12:00 PM
  #2343
I actually liked it this way outdoors, I did plan to re test it at the end of the year, but didn't get round to it. Very smooth and easy to drive.
At Ardent, I run 7.9 with 8t and no timing. Sometimes I run 12mm rotor indoors as well, to smooth the power at the bottom end.
MattW is offline
Old 02-24-2011, 12:22 PM
  #2344
housey's Avatar
Thanks Matt, I just popped the motor in yesterday and guessed the gearing at 8, but that sounds bout right so I'll leave it there. Its in mode 3 so thats no timing isn't it.
housey is offline
Old 02-28-2011, 04:38 AM
  #2345
Hi!
Can anyone download data from speedo and tell me what is in
Armature of poles: 2 or 4? from V13.0 or V13.1?
Regards!
m
M.Abramowicz is offline
Old 02-28-2011, 04:48 AM
  #2346
Originally Posted by M.Abramowicz View Post
Hi!
Regards!
m
haven't seen that box before, but mine is set to 2
chris_dono is offline
Old 02-28-2011, 05:44 AM
  #2347
Thanks!
m.
Old 03-01-2011, 06:31 AM
  #2348
Tell me chris_dono, do you update to V13.1 or still have 13?
And pc software is 1.6.3 or the new one 1.6.5?
Regards!
Old 03-01-2011, 06:45 AM
  #2349
Regards!
v13.1 on 1.6.3 software
Old 03-01-2011, 07:02 AM
  #2350
Regards!
1.6.5?? Where i can find it?
jorgesimes is offline
Old 03-01-2011, 08:09 AM
  #2351
http://www.graupner.de/fileadmin/dow...n_II_1_6_5.zip
at DE version of site: http://shop.graupner.de/webuerp/servlet/AI?ARTN=97164
regards!
Old 03-01-2011, 09:05 AM
  #2352
Thanks mate.
BTW - will be joining Associated soon we will have to talk again.
Old 03-01-2011, 10:03 AM
  #2353
Thanks mate.
seems like 1.6.5 isn't finished yet
Old 03-03-2011, 05:09 AM
  #2354
Originally Posted by Martin Hofer View Post
you can solder a NTC tempsensor on Speedpassion sensor pcbs aswell, if you want to have the saftey option at say ETS races
not going to do Warsaw ..
Hi again!
Martin do you know part number for NTC tempsensor?
Or maybe you know what it is exactly
Regards!
m
Old 03-06-2011, 06:27 AM
  #2355
Trader Rating: 10 (92%+)
Default GM ciao
As far as onroad goes, my GM is dead. The brakes are crap! I am speaking from someone who has been using GM for 2 years, so I know pretty much the ins and outs with this speedy.
So many times I crawl my car slowly, like less than walking pace and I cannot even stop on the grid without overshooting. Yes, I have played with ALL brake settings. In a high speed section on our track, braking to nearly a complete stop, I am giving up 0.5sec on 1 corner alone, as I need to brake alot earlier than others, and even then I'm overshooting turns.
I also cannot use a setting on mode 9, unless its less than 20c ambient temperature, otherwise the motor will overheat. Yes, I have played with all the different FDR's, swithpoint, frequency etc. I can then put my tekin esc back in, and my motors come off 20c less!!
offroad, this esc is perfect, the smoothest speed control I have ever used. But onroad, brakes are not efficient, motors are running hot.
captain stacker is offline
