Old 02-06-2011, 03:41 PM   #2296
Ok I will give the variable dependant timing a try. Wat timing insert do you run in your x12? Martin have you got any ideas?
jameslucas is offline   Reply With Quote
Old 02-06-2011, 03:52 PM   #2297
Send a message via ICQ to MattW
With x12 motor you should always run minimum timing - insert no4, taking timing away. Even like this, it still has more static timing than GM motor. The X12 motor naturally runs hotter than the GM motor, and seems to be able to stand more temperature as well.
MattW is offline   Reply With Quote
Old 02-06-2011, 03:58 PM   #2298
V12
V12's Avatar
The X12 motors run much hotter than other motors as there is a lot of timing prebuilt from factory. I was told by LRP team driver using the insert which reduces the mechanical timing the most. From what I remember this was insert 0000.
V12 is offline   Reply With Quote
Old 02-06-2011, 03:59 PM   #2299
The x12 has loads of timing already built in so i use the four dot insert with the dots facing out. This should give you -10 degrees of timing which is actually still 30+ degrees and then some.
Like i said in the other post you basically want as little timing as possible round the slow bits keeping it cool ready for as much as you can down the straights. I think your gearing is about right, any thing from about 6.5 to 5.8 i've found is about right. Older speedos like the SPX s. spec i used to run it down to 7.5 but that was only to get timing to come in quicker. GM's work differently to that so no need to gear so low, so just be aware of tekin users, and sxx users telling you to gear lower with it. It will just cook.
YZFAndy is offline   Reply With Quote
Old 02-06-2011, 04:31 PM   #2300
Originally Posted by johnsen-dk View Post
Hi
we have some problems with one of our new genius 75 speedo's. Both is running 1s lipo and 1/12 scale. One is running a SP 4,5 turn , and 41,2mm roll out , have set fixed timing on 10 and the speedo is getting 85 degress C , no problems. But the other driver have BIG problems with heat in speedo , it's simply shutting down because off heat. Have tried a 3,5 turn GM , a 7 turn delta ,and last a Nosram 4 turn , with a rool out of 29,8mm. We have tried to race with no fixed and up to 12 , with absolut no result , he can only run about 4-8 laps of 100m , until it shuts down.
Both are running without heatsink and fan
Any ideas , maybe regarding fixed timing and/or roll out
thanks in advance
Michael
Denmark
I run a 7t delta on the 75 speedo, but no dynamic timing. I mistakenly ran it with my stock settings in a practise round and it shut down at 6 minutes. My Rollout for 7t is around 35mm if that helps.
CPD Racing
chris_dono is offline   Reply With Quote
Old 02-06-2011, 11:44 PM   #2301
Thanks for the replies guys. I'm using the 4dot insert so that's right I'll give the motor a good clean then just alter gearing to see how I fair
Will also look at the variable dependant timing to see what i can do with that
Cheers guys
Old 02-06-2011, 11:58 PM   #2302
It has bugs, those bugs get fixed and new ones make themselves apparent.Thanks for the replies guys. I'm using the 4dot insert so that's right I'll give the motor a good clean then just alter gearing to see how ..
axelstrong is offline   Reply With Quote
Old 02-07-2011, 02:29 AM   #2303
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Hi
thanks in advance
Michael
Denmark
please check if the speedo running hot is still properly glued into the case of if you can move it around a bit?
Originally Posted by jameslucas View Post
Hi people
I need help I'm running an x12 13.5 with my gm120 fw13.0 I have followed Martins stock how to for fw13 but i can't get the motor to run cool I'm lost for ideas I have geared harder and reduced the fixed timing but still runs very hot
Can anyone please help?
James
Hi.
I'm running 18 fixed timing after 5mins esc readout says 97c but come the summer when the weathers warmer the motor will be hotter. I ran at aldershot in the UK today fdr was 6.08 a couple of lads were running x12s with tekins and were coming off around 50c
James
97 degree INSIDE is around 50-60 outside! which is far from too hot!. The X12 can handle up to 130C INSIDE with ease!!
what temperature have you set the cut off to?
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 02-07-2011, 02:43 AM   #2304
Motor cut off is set to 110 I was sticking on the cautious side. However I did notice the motor was fading toward the end of the race.
Old 02-07-2011, 02:49 AM   #2305
I'd go for 130
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 02-07-2011, 03:31 AM   #2306
Thanks Martin. Also does my gearing sound about right?
Old 02-07-2011, 03:43 AM   #2307
yes seems about right.
usually we are able to run the same gearing lrp drivers to if you want to use that as a comparison. we are just able to run more power speedowise
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 02-07-2011, 04:32 AM   #2308
Thank you everyone for your comments.
I shall persist and let you know how it goes
Old 02-07-2011, 05:48 AM   #2309
For Martin:
How add timing in mode sensorless???, in the 1.6.3 (esc firmware V13)
Old parameter --> timing (without sensors)
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 02-07-2011, 06:34 AM   #2310
there is no timing sensorless, never was never will be. the speedo has a fixed programmed standard of 30 which is not variable and gets automatically selected as soon as the sensorewire gets removed
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
