Old 10-12-2010, 02:58 AM   #2026
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by Sonter View Post
ANY HELP PLEASE?
you need to order the usb wire seperately
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-12-2010, 03:14 AM   #2027
Hi Martin,
I'm thinking on testing a 9T delta. What do you think about the diferences for 5.5T star? Could i use the same setings as for 5.5T?
Thanks in advance.
jorgesimes is offline   Reply With Quote
Old 10-12-2010, 03:15 AM   #2028
5.5 gives a more linear throttle response
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-12-2010, 03:16 AM   #2029
Fast service. Thanks Martin.
Old 10-12-2010, 03:34 AM   #2030
hana166's Avatar
Hi I am new with this thread, How do you compare this esc GM enius 120 brushless with other esc`s like tekin, speed passion, sxx. I will be runing a stock 13.5 x12 lrp and maybe I will get also a GM pro stock 13.5 motor to race 1/10 on road ona T3. I already have an sxx but it gets faulty too much but it is quite fast. Can you please help me?
does the esc comes with the usb programming set?
Ian
I have good experience of other ESCs but I admit am biased to GM
Believe me there will be no shortage of power
Very smooth
Overall very reliable and quality feel with metal case
If you are running stock get the 75, its lighter
USB set you must buy separately unfortunately
Ditch the LRP motor. When you get the GM speedo you probably won't want the Sxx either lol.
Tell everyone at your club its no good so they don't get one
hana166 is offline   Reply With Quote
Old 10-12-2010, 04:53 AM   #2031
Ian
Hi,
I've not run my GM75 yet but I've had a SP which I liked fast and easy to set up. I've got a Tekin in another car which is just as fast as the SP but run's alot cooler and pretty easy to set up with the Hotwire.
I've ran a SXX Stock Spec at the weekend and it's slow, to get it fast my motor ran hot (X12) so pulled it all out and I'll sell both and will be putting the GM in this car. The LRP's are esy to set up but there definatley not as fast as the Tekin's, GM's etc.
You need to buy the usb seperatley for the GM.
HTH.
S.A.W is offline   Reply With Quote
Old 10-12-2010, 06:11 AM   #2032
@ Martin,
One other thing
I've installed V13 firmware, do I need to set it to mode 9 or leave it as it is and just set your settings you posted a few pages back ?
I'm assuming that when setting the Mode it is also how it calibrates your radio, full throttle, neutral and brake ?
Old 10-12-2010, 06:41 AM   #2033
Send a message via MSN to Sonter
Very smooth
Do you know from where I could get the GM75 and usb set? Does the esc comes updated with the latest version? And is it easy to set the speedo? This is going to be the first speedo which can be updated with usb so I am kinda new to all of this.
Sonter is offline   Reply With Quote
Old 10-12-2010, 08:03 AM   #2034
hana166's Avatar
I bought my GM120s from CMC Versand in Wolfsburg
Good service
Old 10-12-2010, 08:05 AM   #2035
hana166's Avatar
You will have to learn the speedo, its not too difficult, read the 'how to' elsewhere on this thread
Old 10-12-2010, 08:22 AM   #2036
Originally Posted by Martin Hofer View Post
4.5 -> 8 -> 5.5 -> 9 -> 6.5
get a 5.5T that's by far more than you could ever use up.
Atsushi used a 5.5T most of the ETS race in Heemsteede as he found the 4.5 to actually have too much power!
The 5.5 still did 112km/h!!!!
The wind does not really matter anymore with the new speedo as you can get any motor up to a proper speed.
Graupner 10.5 did 104, Graupner 13.5 did 96 (in my car when i tested!)
So get a motor that is easy to drive and that is the 5.5T GM motor.
Use the graupner motors only if there is a winding limitation and when it's legal
thanks for the suggestion Martin, yes I have a 7 delta and its a lot of power...too much, does a 6 delta with 6.6 volt battery keep with the 5.5 motor? which speed is attained with 17.5 for you experience?
chiottola
chiottola is offline   Reply With Quote
Old 10-12-2010, 01:16 PM   #2037
So Which is the best for 13.5t motor? gm genius 75 or the 90? and if I buy one how would I know if it is updated with the latest software?
Old 10-12-2010, 02:36 PM   #2038
Default GM 13.5 with a Tekin rs Pro
Has any one got a setup for the 1600 gause version of this motor. I will be racing on carpet with an Xray 009 with rubber tyres. Thanks
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 10-13-2010, 02:03 AM   #2039
Hi,
I've got my GM75 and GM13.5t in my T3 now running 5.0fdr for outdoors.
What mode should I be setting it too ?
I've set my 'Amp Limit to 80A'
What is 'Reserved 4=1' and 'Reserved 4=3' ? I've set 10000rpm but can't find or don't know what 'Reserved' means ?
I've set 'Fixed Timing too 24' and 'Max timing too 25' is that correct, I left 'Timing with Sensors' at 0 ?
The only other thing I've changed is 'Motor Cutt Off Temp too 115'
Anything I've missed ?
Thanks.
Old 10-13-2010, 02:27 AM   #2040
Originally Posted by S.A.W View Post
@ Martin,
One other thing
Correct!
Just put my file on your speedo and pick the mode that is saved in the file (under mode and transmitter data tab).
I think it was 2 or 3. Basically the mode does not matter. You could have the same profile in any of the 10 modes and it will work. I just ever since used mode 2 and 3 :-)
so put that on the speedo and pick whatever mode is set in the transmitter data tab with your transmitter and then the speedo will save full throttle, neutral and full brake
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
