Old 10-11-2010, 09:51 AM   #2011
Originally Posted by FLAT OUT View Post
Has any one run this combo, Im looking to get a new 13.5 motor and im looking at a GM or an Lrp X12. I will be racing indoors on carpet with an Xray T2 009.
I have used both and the GM (1600 guss rotor) is far superior to the LRP. It runs cooler, has a much smoother power delivery and has noticeably more power overall. The LRP is a quick motor but power comes in a big lump and it has too much timing built in to take advantage of the speeds timing advancing tricks. The LRP suffers a lot with loosing its punch when hot too.
YZFAndy is offline   Reply With Quote
Old 10-11-2010, 01:31 PM   #2012
Send a message via MSN to Sonter
Hi I am new with this thread, How do you compare this esc GM enius 120 brushless with other esc`s like tekin, speed passion, sxx. I will be runing a stock 13.5 x12 lrp and maybe I will get also a GM pro stock 13.5 motor to race 1/10 on road ona T3. I already have an sxx but it gets faulty too much but it is quite fast. Can you please help me?
does the esc comes with the usb programming set?
Ian
Sonter is offline   Reply With Quote
Old 10-11-2010, 03:22 PM   #2013
Originally Posted by S.A.W View Post
Hi,
Is the GM75 ok for 13.5 or should I go for the 90 ? Do you need a to run the fan on the speedo ?
What fdr do I need for GM75 or 90 on a T3 using the GM 13.5t, I have 1300 and 1600 rotor's. Track is outdoor with 45m straight mostly open with one chicane and an indoor track with a 30m straight mostly tight and technical.
Is program 9 the one to use ? I have the software lead but just want to set it, gear it, temp it and race no messing with settings please.
Thanks.
Martin, anyone ?
S.A.W is offline   Reply With Quote
Old 10-11-2010, 03:50 PM   #2014
tomracing's Avatar
Martin, anyone ?
gm75 is fine from 9.5T and up on 2s lipo
for 13.5 it won't need the fan according to gm.
read martin's genius2 tips for the settings you need:
http://www.rctech.net/forum/7908081-post1851.html
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 10-11-2010, 04:15 PM   #2015
Would I gain anything running the 90 ?
I don't really like the way the heatsink/fan mounts on the 75 but shouldn't need it, maybe in the summer.
Old 10-11-2010, 04:50 PM   #2016
tomracing's Avatar
the 90 is bigger and heavier than the 75
but the 90 can be used up to 5.5T motors.
Tom van den Brink
Old 10-11-2010, 05:28 PM   #2017
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
i ran the 75 yesterday, with 10.5 at Ardent, worked perfectly, no issues at all, with heat etc..
hth
luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 10-12-2010, 01:13 AM   #2018
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by chiottola View Post
Hello, can someone tell me which among these motors have the best overall performance? GM 8-9 delta gm pro 4.5-5.5 and graupner sport 6.5. using with 120 v2 controller. I see power is similar around 700 watt but different rpm. I mean which motor of these have best power in most situations or what are the difference about them?
Thanks and regards
chiottola
4.5 -> 8 -> 5.5 -> 9 -> 6.5
get a 5.5T that's by far more than you could ever use up.
Atsushi used a 5.5T most of the ETS race in Heemsteede as he found the 4.5 to actually have too much power!
The 5.5 still did 112km/h!!!!
The wind does not really matter anymore with the new speedo as you can get any motor up to a proper speed.
Graupner 10.5 did 104, Graupner 13.5 did 96 (in my car when i tested!)
So get a motor that is easy to drive and that is the 5.5T GM motor.
Use the graupner motors only if there is a winding limitation and when it's legal
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-12-2010, 01:21 AM   #2019
Originally Posted by hacker View Post
so I've put the start and amp limit to 20, and on the telemetry after pressing the esc button the 'max current' is 29.
How is this possible, as I had set it to 20?
turbo function
are you 100% on these temp figures?
they seem excessively high.
I have burnt novak/trinity/sp motors 20-30c less than your recommended cut off temps. I know the x12's can handle more temp, but 120c?
yes 100% sure, it's NTC measured temp, not case temp
Hi,
Thanks.
for 13.5 no heatsink/fan is required. It'll handle it without any additional cooling.
run approx 4.7-5.0 outdoors and 5.5-6.0 indoors
there i no need to temp it. the speedo will take car of the motor temp as long as you set the value according to my how-to.
basically follow the how to and you are ok. 24 fixed timing shouldbe good outdoors, 26 indoors for the gm motor (use a fan!)
yep I played around with it yesterday and set the speed control to cut out at 110, and the outside can temp was 80. I KNOW there is not a 30 degree difference between components on a brushless motor. How do I know?
well straight after a run once, I pulled apart the motor and tested the rotor, stator, endbell, all were within a few degrees of one another.
it would be better if the next software upgrade would have a temperature correction factor.
the temperature is correct!, it's just the case that you cannot take the motor apart as fast as it cools down.
And there are temperature differences of MORE than 30C within a motor.
The Magnet gets up to 150-160C! and that's just one part of the motor!
The temps I posted are absolutely correct and already on the save side.
If you are doing an important race you can actually go up 5 or 10C as the motor will not reach the cutoff temperature anyway.
BTW, when the LRP Speedo cuts out (which happens quite frequently) it measures 120C on the NTC ...
What timing does the Gm 13.5 come with as standard ???
30 is the middle drilling. Please do not change the motor timing but go with speedo settings
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-12-2010, 01:23 AM   #2020
Sorry that it took so long to answer but I was away testing
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-12-2010, 01:24 AM   #2021
hth
luke
Thanks, did you run it with the heatsink/fan ?
@Martin,
What fdr do I need for GM75 on a T3 using the GM 13.5t, I have 1300 and 1600 rotor's. Track is outdoor with 45m straight mostly open with one chicane and an indoor track with a 30m straight mostly tight and technical.
Thanks.
Old 10-12-2010, 01:27 AM   #2022
Thanks Martin, ignore the post above.
Which is the best rotor to use indoors and/or outdoors 1300 or 1600 ?
Old 10-12-2010, 01:46 AM   #2023
use the one with the red faceplate. if you experience big fading, go for purple
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-12-2010, 02:00 AM   #2024
Thanks, one other thing
I've installed V13 firmware, do I need to set it to mode 9 or leave it as it is and just set your settings you posted a few pages back ?
Old 10-12-2010, 02:24 AM   #2025
Ian
ANY HELP PLEASE?
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
