Old 10-05-2010, 01:30 PM   #1981
bzb
(o o here is the noob )
hey guys..
im getting a second hand gm 7168 ver. 7.2, i want to put it on my tekin sensored 10.5 motor.
im going to use it in a team associated sc10 ft, 2s lipo
wich mode i should use?
bzb is offline   Reply With Quote
Old 10-07-2010, 03:20 AM   #1982
hacker's Avatar
Trader Rating: 141 (100%+)
Default GM motor sensor
do not have experience on GM motors. Are they a regular sensor, or a special GM sensor like on the speed control?
hacker is offline   Reply With Quote
Old 10-07-2010, 03:25 AM   #1983
If you mean the plug on the sensor lead, then it's the same as other motors.
CPD Racing
chris_dono is offline   Reply With Quote
Old 10-07-2010, 03:28 AM   #1984
hacker's Avatar
yes, thanks, thought so as I have never seen a motor sensor lead just for GM esc to GM motor.
I'm at a loss however to understand why GM have a different sensor plug on the speed control side
Old 10-07-2010, 03:30 AM   #1985
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
cause we use the port for programming
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-07-2010, 03:48 AM   #1986
hacker's Avatar
couldnt the port be made compatible with current systems?
like tekin and lrp
Old 10-07-2010, 04:01 AM   #1987
Originally Posted by Martin Hofer View Post
wrong it's just a different way of limitation
simply ALWAYS use 4kc with variable current when running sensors and 8kc with var current when running sensorless
Martin, what does that setting alter actually?
Do you have a pretty decent basic setup for sensorless operation?
In case of running a GM 8T Delta sensorless, what should change in the setup?
I'm new to the GM120 and trying to grasp every possibility of it.
Running sensored with the v13 basic setup and changing it with your quick start guide worked pretty well this weekend. But for sensorless (rain car) I don't know how the get the most out of it.
Thanks,
Jonathan.
Jonathan P. is offline   Reply With Quote
Old 10-07-2010, 04:12 AM   #1988
Hi,
How does the GM75 compare to the Tekin in ease of use and programming ? I find the Tekin hard to understand but heard the GM's are even harder.
What are the pre programmed settings like for 13.5t ?
Thanks.
S.A.W is offline   Reply With Quote
Old 10-07-2010, 04:14 AM   #1989
Originally Posted by S.A.W View Post
Hi,
Thanks.
Very easy just follow this - Martin How-to
jorgesimes is offline   Reply With Quote
Old 10-07-2010, 04:16 AM   #1990
hacker's Avatar
Hi,
Thanks.
the GM has the most advanced settings of them all, however that does not mean its hard to program. You can make it as easy or as hard as you like, but for spec class's, all you will need to do is use mode 7, 8, 9.
Old 10-07-2010, 07:55 AM   #1991
hacker's Avatar
Default temp sensor
do the older novak ss pro series have the temp sensor?
Old 10-07-2010, 08:09 AM   #1992
that you should probably ask on the novak thread
as for sensorless ... just untick HST / HST wth switchpoint, Change the switchpoint rpm to 10000 (IMPORTANT) and go
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-07-2010, 08:26 AM   #1993
hacker's Avatar
I dont understand why anyone would want to run sensorless.
Old 10-07-2010, 10:56 AM   #1994
Hello, can someone tell me which among these motors have the best overall performance? GM 8-9 delta gm pro 4.5-5.5 and graupner sport 6.5. using with 120 v2 controller. I see power is similar around 700 watt but different rpm. I mean which motor of these have best power in most situations or what are the difference about them?
Thanks and regards
chiottola
chiottola is offline   Reply With Quote
Old 10-07-2010, 11:00 AM   #1995
V12
V12's Avatar
I think Novak motors had the temp sensor from the beginning.
V12 is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
