Old 10-01-2010, 01:28 PM   #1966
Send a message via ICQ to MattW
I can't remember what happens if you turn it on - but i'd suggest just leaving it switched off, and using a switch on the receiver pack to switch the car on/off. I used to just tuck my ESC switch out of the way so that it didn't ever get switched on.
MattW is offline   Reply With Quote
Old 10-01-2010, 04:38 PM   #1967
Before crisis lent me an rx pack at last years euros I ran it with the switch on. It worked... but the steering died at about 6 minutes, became REALLY sluggish
Joost, as Matt's said, when you plug a battery into the receiver it'll power the car up, leave the switch on the speedo off, that's all you need.
CPD Racing
chris_dono is offline   Reply With Quote
Old 10-01-2010, 04:48 PM   #1968
Joost K.'s Avatar
Okay guys, thanks for the info & advice... I don't have a switch on the receiver pack since I'm using a Spektrum receiver so I'll just plug in the RX pack en when the car is on the track I'll turn on the TX and I guess it will all work...
Thanks!!!
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 10-01-2010, 05:15 PM   #1969
Thanks!!!
That's what i do with my other rx pack, just plug it in when you're ready to go
CPD Racing
Old 10-02-2010, 07:22 AM   #1970
Okay, so the switch on the ESC is not used at all then? What I mean is that it doesn't matter if it's on or off? Still a strange thought between the ears I guess being used to old school ESC's. I have a gen2 GM120 in my Pro10 but this is the first time with such a ESC in 12th scale...
Ralf just wrote that: if switch on some power from RX or booster can back to main 1S packet, so better is set it OFF and don't cut red + wire.
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 10-04-2010, 02:21 AM   #1971
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by hana166 View Post
Anyone know the difference between, for example, 8kc with variable current limit and 8kc?
I guess if its fixed the Turbo cannot exceed the current limit but need clarification
wrong it's just a different way of limitation
simply ALWAYS use 4kc with variable current when running sensors and 8kc with var current when running sensorless
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-04-2010, 03:17 AM   #1972
m.
One question i had is: how can you get the telemetry to work when the switch is off ? I seem to remember that pressing the button didn't do anything when using an rx pack. Hopefully that's changed ?
CPD Racing
Old 10-04-2010, 06:18 AM   #1973
Hm.
Good question.
1st time when I have it ON it works.
Last time I have it OFF and I download data and it works
m.
Michal Abramowicz
Old 10-04-2010, 06:38 AM   #1974
Hm.
Good question.
m.
are you sure it wasn't just stored from the previous time ?
CPD Racing
Old 10-04-2010, 07:33 AM   #1975
*SBH*'s Avatar
It works fine, just remember to disconnect the batteries.
*SBH* is offline   Reply With Quote
Old 10-04-2010, 08:32 AM   #1976
If you disconnect the battery, how can you store the telemetry data ? The speedo is off remember.
CPD Racing
Old 10-04-2010, 03:50 PM   #1977
JonboyGB's Avatar
Hi all,
A top racer gave my car blast last weekend. He commented on how the car had loads of drag brake. I'm going for a good test day at my local this week, and wanted to reduce the drake brake effect and see how the car goes. Only problem I have is that I haven't got a clue what to change in the software. My current brake settings are:
Brake Min = 40
Brake Max = 100
Auto brake = 0
Full brake = 100
Time to full brake = 175
Soft brake = 100
ABS = Off
New brake software = On
Effect new brake software = 150
New brake software for autobrake = Off
Current limit for brake off = Off
Would someone mind letting me what to adjust?
FYI my speedo is a GM90 2010 with 12.4 firmware and I'm running a GM10.5.
Cheers Ears
www.zen-racing.co.uk
JonboyGB is offline   Reply With Quote
Old 10-04-2010, 05:12 PM   #1978
Originally Posted by JonboyGB View Post
Hi all,
Brake Min = 40
Brake Max = 100
Auto brake = 0
Full brake = 100
Soft brake = 100
ABS = Off
Cheers Ears
You haven't for any drag brake set there... (Auto brake)
have you checked the mesh isn't too tight or you're geared with a high FDR ? They could feel like you've got drag brake on..
CPD Racing
Old 10-04-2010, 05:29 PM   #1979
Hi all,
Brake Min = 40
Brake Max = 100
Auto brake = 0
Full brake = 100
Soft brake = 100
ABS = Off
Cheers Ears
Check your rotor, i think it cames with the 12,5mm rotor. Rotor is the most important tuning in the motor, buy the 12,3mm EFRA legal and you will be fine.
PS - I think also your brake min is a little high, try to put it down to 20.
And BTW put the v13 fw and follow "the how to" of martin and you also be surprised.
jorgesimes is offline   Reply With Quote
Old 10-05-2010, 01:11 AM   #1980
Hi
I do some tests.
Switch on, push button, then revs ~46k at max th.
But when I do test, at 1/3 th it shows only amps and no revs ... at switch off,
so I put max th and revs ~47k .
Another value, so it save data
Regards!
m.
Michal Abramowicz
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
