Old 09-26-2010, 02:43 PM   #1936
Originally Posted by M.Abramowicz View Post
Question is from WHICH software you update to V13?
If from 11* or something under 12, just update to 12 and then to 13.
That was my case ...
good luck!
m.
Hey Abramowicz
Im updating from 12,4.
I've just gotten it back from the GM factory from and update to the bootloader. Don't know if that changes the procedure i'm supposed to use?
Søren
ssoslot is offline   Reply With Quote
Old 09-26-2010, 02:52 PM   #1937
Originally Posted by ssoslot View Post
Thanks for the fast reply, Andy. It doesn't work yet, alltough it did do something. The upgrade program gives some feedback but I don't understand it. Maybe somebody can help:
It is exactly the same as i was getting. Are you sure you are following exactly what was said?
open upgrader
browse for firmware
make sure comport is correct
connect usb wire to speedo
push and hold the set button on the speedo AND DON'T LET GO UNTIL
click program
push the button on the usb dongle
see the program doing it's job NOW
when it's doing "flash programming xx%" you can release the set button of the speedo
YZFAndy is offline   Reply With Quote
Old 09-27-2010, 02:14 AM   #1938
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
you need to make sure you push and hole the set-button on the speedo and that the battery is not connected and the caps are empty
you need to push and hold the set button before doing anything else
if the reset button on your programming cable does not work simply push and hold the set button, click program and plug the usb wire into your speedo
Originally Posted by Glorykid View Post
feck me my car was fast, scary fast compared with the stock settings i was running.
Now using the stock settings Martin suggested, how do i slow it down a touch and make the throttle a bit smoother.
And my brakes were not that great either.
if you want the throttle to be smoother then lower the current limiter
please check if your transmitter values have been saved correctly (red led only when you do full throttle and full brakes, red/yellow in neutral)
could you further explain what was wrong with the brakes?
Thanks for replay!
Now maybe my friend will save some money and this winter season drive
on old speedo and learn how to set tc car (driving truggy 1/8).
Now Martin, this sport engines are outlaw?
On gm site is that they are DMC/EFRA legal, so why you Martin wrote
that you can use them when track/event rules are not restricted?
What is the problem ?
Regards!
m.
the dimensions of the motor itself (not case dimensions) are outlaw in most of the international rules but for germany it's legal
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-27-2010, 02:41 AM   #1939
Glorykid's Avatar
Thanks Martin, will check the TX
Brakes seemed really soft
Nemo Racing~Agama~Bullitt~Beta~Piranha~Racer
Glorykid is offline   Reply With Quote
Old 09-27-2010, 02:50 AM   #1940
you updated to V13 and used the "new -new brakes" set with reserved4?
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-27-2010, 03:51 AM   #1941
Glorykid's Avatar
It was setup as previous data on the page before Martin, then i did what you told me
Old 09-27-2010, 06:00 AM   #1942
so you changed reserved 4 to 7? then you should really check your transmitter settings as that should brake properly with an X12
the x12 ain't got the strongest brakes anyway but it should be ok
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-27-2010, 09:01 AM   #1943
Default V13 upgrade
Thanks everybody it works now.
Old 09-27-2010, 09:15 AM   #1944
Bishop's Avatar
You know I got to say, been looking around at other dynamic timing esc's since I got my HW, curiosity and all that, but the GM Genius series looks super cool, uncommon over here as I don't know anyone using them, but all those features, and data logging.
Don't know if I was imagining it or not, but I could have sworn one version said it had regenerative braking?, if I can get my head round all the features I want one as my next esc.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 09-28-2010, 12:57 AM   #1945
if you mean recharging the battery when braking, then yeah the speedo does that
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-28-2010, 12:58 AM   #1946
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
lol, that does not seem like it would work with lipo batteries.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 09-28-2010, 01:27 AM   #1947
Bishop's Avatar
Full sized electric and hybrids have been doing it with other lithium cells, I was just surprised when I saw the GM esc does it, and impressed, of course I have no idea how well it works, but I'd love to see data on how much mah it could save during an race, even if it's bugger all I'd love it as a bragging factor trackside.
QRCCRA
www.qrccra.org.au
Old 09-28-2010, 05:51 AM   #1948
Glorykid's Avatar
ok will check this week
Old 09-28-2010, 04:04 PM   #1949
Hm.
Very very interesting.
Martin, how to turn it off?
Maybe I don't want this feature and want only:
- accelereate,
- braking from speedo ?
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 09-29-2010, 12:27 AM   #1950
hacker's Avatar
Trader Rating: 141 (100%+)
regenerative braking is not new technology as I remember tekin and some other company had them in the late 80's-early 90's. But I am surprised the GM has it as its not mentioned anywhere about it. Not that its needed as we have all the battery power we ever need with the 5600 lipos.
hacker is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
