Old 09-20-2010, 09:16 AM   #1906
Glorykid's Avatar
so would the 13mm works team rotor be my best option?
Nemo Racing~Agama~Bullitt~Beta~Piranha~Racer
Glorykid is offline   Reply With Quote
Old 09-20-2010, 11:04 AM   #1907
Originally Posted by Martin Hofer View Post
don't bother about the motor manual. stick to the how-to posted beore
Do you mean firmware 13.0 how to martin? I'm set to your recommend settings posted on that but its still doing it. Is There a how to further back?
Originally Posted by hana166 View Post
I noticed that with the weaker magnets (purple)
Give this a try. Next time out click on 'high speed timing with switching point' and set to 5000rpm
Thanks hana166 Thats helped quite a bit as in it doesn't rock before you get going and full throttle straight away is fine but it is still a little stuttery if you put the throttle in gently from standstill!
Rolling the cat backwards on half brake shows the sensors are being picked up ok. Is there anything obvious i may have missed or un-checked in the A.S software?
YZFAndy is offline   Reply With Quote
Old 09-20-2010, 12:29 PM   #1908
THE LRP X12 FEATUERS 40 HARDWARE TIMING EVEN AT THE MINIMUM TIMING SETTING!
THIS IS 10 MORE! THAN ANY OTHER BRAND OF MOTOR USED IN RACING ATM
DO NOT RUN TIMING VALUES ABOVE 20 WITH THIS MOTOR! AS 20 WITH X12 EQUALS 30 WITH REGULAR MOTORS! AND THIS IS AS LOT!!!
Martin....What is the funtion reserved 4?
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 09-20-2010, 05:24 PM   #1909
Hi martin,
do you use rotors with or without fan?
jorgesimes is offline   Reply With Quote
Old 09-21-2010, 02:05 AM   #1910
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
if you have sticked to the how-to, updated your speedo to V13.0 and used my setting with your transmitter values it should be fine
ifyou got the feeling of the speedo having a slight hesitation from the start (which is normal depending on how clean the sensors and how strong the magnet is) when you go off with very little timing you should enable the switchpoint or variable depence timing
res4=1 HST without switchpoint
res4=3 HST with switchpoint
or new brakes set to 5 or 7 for HST without / with switchpoint (written that in the how-to already!
Originally Posted by jorgesimes View Post
Hi martin,
without
just use the standard rotor! the optional rotors are meant for modified racing!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-21-2010, 05:23 AM   #1911
housey's Avatar
How safely could my GM 90 run a 5.5 star? Im guessing it would be a little too nearly the limit. Would I be better off with a 6.5?
housey is offline   Reply With Quote
Old 09-21-2010, 06:14 AM   #1912
*SBH*'s Avatar
Hi Housey
Thats not a problem at all.
I have been running 4t and 4,5t without any problems with this speedo
You have the temp protection in the software, just use it. According to Martin, 120'C is the limit for the speedo. You can adjust the limit to 105'C with 60Amps, so if Your speedo get that temperature, it will not turn off, but just turn down the amps. You can continue, with a slower car, but nothing will happen with the speedo.
*SBH* is offline   Reply With Quote
Old 09-21-2010, 06:15 AM   #1913
Glorykid's Avatar
Think i have done it right, GM90 LRP X12 13.5 Standard rotor, Tamiya 416 with a FDR of 5.7
Detect Firmware >= 6.1 : 13.0
0) Receive First Byte : 21/09/2010 13:13:10
1) AMP Limit : 80; TimeDiff : 0.1278 s
2) Turbo : 1; TimeDiff : 0.1294 s
3) BrakeMin : 20; TimeDiff : 0.1304 s
4) BrakeMax : 100; TimeDiff : 0.1294 s
5) Start Amp : 0; TimeDiff : 0.1294 s
6) Auto Brake : 0; TimeDiff : 0.1294 s
7) Frequency : 5; TimeDiff : 0.1304 s
8) PowerCurve : 0; TimeDiff : 0.1294 s
9) Autogas : 0; TimeDiff : 0.1294 s
10) FullBrake : 100; TimeDiff : 0.1303 s
11) MaxReverse : 0; TimeDiff : 0.1294 s
12) Switch : 134; TimeDiff : 0.1293 s
13) ABS : 0; TimeDiff : 0.1294 s
14) RPMLimit : 13; TimeDiff : 0.1304 s
15) Reserved : 16; TimeDiff : 0.1294 s
16) Timing : 0; TimeDiff : 0.1294 s
17) Softgas : 50; TimeDiff : 0.1304 s
18) Reserved1 : 148; TimeDiff : 0.1285 s
19) Softbrake : 2; TimeDiff : 0.1287 s
20) FullThrottle : 89; TimeDiff : 0.1292 s (HighByte)
20) FullThrottle : 247; TimeDiff : 0.1304 s (LowByte)
20) FullThrottle : 23031; TimeDiff : 0.1304 s
21) NeutralPoint : 65; TimeDiff : 0.1294 s (HighByte)
21) NeutralPoint : 172; TimeDiff : 0.1294 s (LowByte)
21) NeutralPoint : 16812; TimeDiff : 0.1294 s
22) FullBrakePoint : 49; TimeDiff : 0.1294 s (HighByte)
22) FullBrakePoint : 57; TimeDiff : 0.1302 s (LowByte)
22) FullBrakePoint : 12601; TimeDiff : 0.1302 s
23) Neutral Point Width : 80; TimeDiff : 0.1294 s
24) Controller Mode : 1; TimeDiff : 0.1294 s
25) VoltageCutOff : 30; TimeDiff : 0.1302 s
26) PWMStartNoSensor : 128; TimeDiff : 0.1291 s
27) LimStartNoSensor [A] : 30; TimeDiff : 0.1294 s
28) EffectNewBrake : 75; TimeDiff : 0.1304 s
29) Reserved2 : 1; TimeDiff : 0.1294 s
30) SwitchPointRPM : 250; TimeDiff : 0.1294 s
31) MaxTiming : 20; TimeDiff : 0.1294 s
32) FixTiming : 19; TimeDiff : 0.1303 s (HighByte)
32) FixTiming : 4; TimeDiff : 0.1293 s (LowByte)
32) FixTiming : 4868; TimeDiff : 0.1293 s
33) Timing2 : 150; TimeDiff : 0.1287 s
34) Timing1 : 70; TimeDiff : 0.1305 s
35) CutOffTempContr : 125; TimeDiff : 0.1294 s
36) MaxRPM : 255; TimeDiff : 0.1295 s
37) Firmware : 130; TimeDiff : 0.1295 s
38) MaxCurrent : 0; TimeDiff : 0.1303 s (HighByte)
38) MaxCurrent : 0; TimeDiff : 0.1294 s (LowByte)
39) CutOffTempMotor : 120; TimeDiff : 0.1295 s
40) MaxESCTemp : 31; TimeDiff : 0.1295 s
41) MaxMotorTemp : 27; TimeDiff : 0.1295 s
42) ActESCTemp : 26; TimeDiff : 0.1295 s
43) ActMotorTemp : 0; TimeDiff : 0.1294 s
44) EEProm : 0; TimeDiff : 0.1305 s (HighByte)
44) EEProm : 70; TimeDiff : 0.1293 s (LowByte)
45) ActVoltage : 0; TimeDiff : 0.1295 s
46) CurrentOffset : 12; TimeDiff : 0.1305 s
47) MaxTempContr : 74; TimeDiff : 0.1295 s
48) MaxTempMotor : 93; TimeDiff : 0.1305 s
49) AbsMaxCurrent : 0; TimeDiff : 0.1295 s (HighByte)
49) AbsMaxCurrent : 113; TimeDiff : 0.1304 s (LowByte)
50) DisCapacity : 0; TimeDiff : 0.1295 s (HighByte)
50) DisCapacity : 9; TimeDiff : 0.1293 s (LowByte)
51) CurLimit_Temp : 40; TimeDiff : 0.1305 s
52) TimeToFull : 140; TimeDiff : 0.1290 s
53) CorrectCurLimit : 65; TimeDiff : 0.1295 s
54) MaxCapacity : 253; TimeDiff : 0.1295 s (HighByte)
54) MaxCapacity : 232; TimeDiff : 0.1305 s (LowByte)
54) MaxCapacity : 65000; TimeDiff : 0.1305 s
55) VoltageCorrect : 180; TimeDiff : 0.1292 s
56) MaxVoltage : 0; TimeDiff : 0.1295 s (HighByte)
56) MaxVoltage : 162; TimeDiff : 0.1305 s (LowByte)
57) Telemetry : 1; TimeDiff : 0.1295 s
58) Poles : 2; TimeDiff : 0.1293 s
59) Pinion : 36; TimeDiff : 0.1295 s
60) MainGear : 100; TimeDiff : 0.1305 s
61) TireDiam : 62; TimeDiff : 0.1295 s
62) InternGear : 21; TimeDiff : 0.1285 s
63) OverallGear : 19; TimeDiff : 0.1304 s (HighByte)
63) OverallGear : 127; TimeDiff : 0.1147 s (LowByte)
63) OverallGear : 4991; TimeDiff : 0.1147 s
64) Reserved4 : 3; TimeDiff : 0.0001 s
65) HighByteParity : 18; TimeDiff : 0.0873 s
66) LowByteParity : 126; TimeDiff : 0.1293 s
Old 09-21-2010, 07:19 AM   #1914
that's correct but set reserved 4 to 7!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-21-2010, 07:33 AM   #1915
Glorykid's Avatar
Done thx!!
Old 09-21-2010, 10:41 AM   #1916
housey's Avatar
Originally Posted by *SBH* View Post
Hi Housey
Thanks for that, need to get myself the usb lead and then I can sort it all out.
Old 09-21-2010, 10:56 AM   #1917
Glorykid's Avatar
Housey where are you based fella, i maybe going to moto arena tommorow
Old 09-21-2010, 11:04 AM   #1918
housey's Avatar
Afraid I'm a bit too up north for that mate, I live near Sheffield. Ardent is somewhere I go a fair bit though. I've seen pics of moto and it looks awesome, but a little far away!
If I get a new job I have an interview for I'll be moving down that way so could well be a regular at silverstone. I take it your from round there then?
Old 09-21-2010, 11:09 AM   #1919
Glorykid's Avatar
Aye im from that area, i may be up at ardent in the next few weeks though, i'll pm you
Old 09-21-2010, 11:37 AM   #1920
housey's Avatar
You should come all the time man, its an ace facility, mind you, if moto is your regular place then I suppose anywhere else will be like a crap hole
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
