Old 09-10-2010, 11:36 AM   #1876
Default Rotor change
Hey guys
I was wondering how much more torque I would get if I changed the standard 12,4 rotor with a 12,5 rotor in the GM Pro 17.5T motor? Is it possible to get a 13 mm rotor. I can't seem to find one on graupner.de
Is the additional torque anything I would notice on the track, or does one mm not change anything?
Best regards from Denmark
Søren
ssoslot is offline   Reply With Quote
Old 09-11-2010, 05:00 AM   #1877
hana166's Avatar
Originally Posted by ssoslot View Post
Hey guys
Søren
Get the red one much more punch and brake if you need that 97286.3
hana166 is offline   Reply With Quote
Old 09-11-2010, 08:17 AM   #1878
Thanks for the advise.
Old 09-11-2010, 01:51 PM   #1879
Martin,
do you know someone who use gm V2 with 1S lipo and 13.5T or 10.5T for
spec/stock racing E12 class?
I need advice how to set it ...
I'm changing from gm v1 to v2 and I worry to mess my settings
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 09-12-2010, 08:56 AM   #1880
Speed passion V3 chucked its rotor today, Only 4/5 meetings old. So looking for best recommendation for this speedo on carpet mostly, 13.5t?
YZFAndy is offline   Reply With Quote
Old 09-12-2010, 02:17 PM   #1881
hana166's Avatar
GM, Graupner and Corally motors are best, each with different characteristics, and have temp sensor so you can make best use of telemetry and protect the motor. Melted 8 last year, none this year
Old 09-13-2010, 01:21 AM   #1882
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by M.Abramowicz View Post
Martin,
Regards!
m.
See V13.0 how-to one page back !!!...
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-13-2010, 03:57 AM   #1883
Martin,
Yes I read this, but you check this for 2S racing.
Anyway, this file from Ralf is OK, I got it from some
DHI cup or something ... I only change lipo cut off to 2.5V and
values for radio.
Btw, this file gives (car with tires, a little dirty bearings, standing on
table):
- 13.5T/X11 lrp engine, 2S lipo -> 89krpm, tires looks like tires from buggy 1/8
on full th,
- 17.5T/X11 lrp engine, 2S -> 86krpm.
Total fdr: 6.25, weight of car 1410g, on track car is too fast hehehe
Don't ask me what this values do, I only use them in 2WD racing last
weekend, car with 1S lipo, 13.5T/X11 now is fast like 13.5T/2S lipo (F1 racing).
m.
Warning: THIS FILE IS FOR X11 LRP Engine (taken from DE event, X11/13.5T) file: dmwiesbaden.txt
Michal Abramowicz
Old 09-13-2010, 12:17 PM   #1884
Hi Martin, or anyone else that can help.
I was playing around with the AMP limit at the weekend after reading the new setup guide you posted. Thing is even after setting it down to 70 Amp limit, in the telemetry function its still telling me that i'm pulling 107Amp.
Is that accurate and why would it be letting the amp go higher? I'm quite sure the "correction factor current limit" setting is close to being right but the "actual battery voltage" and "max voltage" section seem quite far off. Would this have anything to do with it?
Old 09-14-2010, 01:11 AM   #1885
Martin,
values for radio.
table):
on full th,
m.
file: Attachment 641662
1, the setup guide works for any kind of voltage as, as I have written before the winding is far more important than the voltage you use it with!
so the guide is what you should be using
2, the file you have uploaded is ONLY SUITABLE for lrp X11 motor and very smooth drivers. Any other motor or hard driving style will make the motor blow up in smoke! I know it cause it is a setting I made via phone :-)
3, NEVER let the motor rev up without load as you will make the rotorshafts bend and in the end break!
4, again, the how-to works for any kind of voltage
this is cause you are using the turbo function which gives you 1A more, every 4ms you are on full throttle, so you are using 70A through the infield which makes the car easy and consistant to drive and keeps the motor from getting too hot and down the straightaway the amp limit opens up (cause you are on full throttle) and you get the maximum topspeed
this is why I keep saying that 80A is more than enough for any stock racing class!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-14-2010, 01:49 AM   #1886
Hi,
Martin, again, thanks for advice.
I don't have time at Sunday morning, only 30min to change speedo, do
solder job and put some settings.
Again, your howto is very nice!
I will try use it
Regards!
m,
Michal Abramowicz
Old 09-14-2010, 12:46 PM   #1887
Thanks Martin, help always appreciated.
Just after one more bit of advice.
After exploding rotor on the speed passion i want to set the rev limit (it went airbone). I've just got the GM 97294 13.5T star wind 1300Gauss motor so what would be a recommended rev limit for that? Also any advice on that motor with regards to where i should start with the fixed timing and gearing? I know thats a very difficult one to answer but the track is tight infield going down to some very slow hairpins to a med/long indoor straight.
Old 09-14-2010, 01:19 PM   #1888
tomracing's Avatar
you can easilly set it to 65k rpm modified motors go to this rpm and the rotor takes it so should be okay.
BUT my main advice would be never ever EVER let your motor free rev without load.
so only when the car is on the track with.
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 09-15-2010, 01:49 AM   #1889
factory setting is 100000 rpm and this is what the magnets can easily stand if they not have to rev in this area too long
if the magnet breaks it has most likely been damaged already
see the how-to as I mentioned the gm motor aswell...
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-16-2010, 02:00 AM   #1890
GENIUS 75 #97173 IS NOW AVAILABLE!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
