Old 09-03-2010, 11:07 AM   #1816
hana166's Avatar
Question for Martin,
If I click 'Highspeed Timing from Switching point RPM' and also click 'Variable dependent timing' which one takes over?
If I exit a hairpin onto a straight, and go immediately to full throttle will I get full timing, or will this happen as soon as the switchingpoint is reached?
I prefer the feel of variable dependent timing but I don't want it to come in too early in order to control temps.
hana166 is offline   Reply With Quote
Old 09-03-2010, 11:37 AM   #1817
Send a message via ICQ to MattW
If you set the switch point option, then it will wait until that point is hit before and additional timing is added.
MattW is offline   Reply With Quote
Old 09-03-2010, 12:54 PM   #1818
Someone can make an outline of how work the timings in the GM?
Of style:
Star --> timing 1.......full thotle add timig 2.....
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 09-03-2010, 05:10 PM   #1819
housey's Avatar
Hey guys,
Was thinking about getting the 120, but now thinking that a 90 might do me just as well. I just have a few questions.
Does the software update/programming differ between the two models?
What turn brushless can the 90 handle?
Is the 120 going to give me any extra performance doing 13.5 or 10.5?
So I suppose the big question is, what are the important differences between the two models?
Thanks!
housey is offline   Reply With Quote
Old 09-04-2010, 02:40 AM   #1820
tomracing's Avatar
Originally Posted by housey View Post
Hey guys,
no, the software is the same
>=5.5T star on 2s should be safe. people have run 4.5T but you need to be a real easy driver to keep it cool
for these motors it should be no difference
constant current 90A v.s 120A
max peak current 600A v.s 800A
Thanks!
see answers in red
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 09-04-2010, 06:43 AM   #1821
housey's Avatar
Originally Posted by tomracing View Post
see answers in red
Thanks Tom, I think the 90 will be fine for the sort of racing I'll be doing for the foreseeable future. So I'll save myself a few pennies and get that one. Cheers again!
Old 09-04-2010, 11:33 AM   #1822
housey's Avatar
Now I'm just after one more thing, a starting FDR.
I'll be at this track,
http://www.ardentracing.com/raceway/
running a 13.5 and to start with will just be using the standard mode 9 setting to get me going.
Any ideas where to start? need any more info? Cheers guys.
Old 09-04-2010, 06:56 PM   #1823
hacker's Avatar
Trader Rating: 141 (100%+)
5
hacker is offline   Reply With Quote
Old 09-05-2010, 12:39 AM   #1824
housey's Avatar
Cheers hacker, I'll give that a go today.
Old 09-06-2010, 01:05 AM   #1825
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Which motor are you planning to run? cause it depends a lot on that
you could also adjust mode 9 at home so it works perfectly with your motor and just set like a pretty high timing
and then just copy it to mode 8 and set a little less
copy into 7 and set a little less
copy into 6 and set a little less and so on and so on
you can switch the modes via your transmitter which is really easy actually and you can adjust your speedo to the track conditions within 30 seconds.
as for 90 vs 120, i think for stock racing the 75 is by far the best speedo as you won't loose any performance up to 10.5T but get a lot! of room as the 75 is I think the smallest speedo out there.
as or speedo timing:
the gm speedo does not only do one timing. It can actually do any timing you would ever want it to do
- it can start with full timing right from the start
- it can start with no timing and add extra timing at some rpm
- it can start with 1 timing, then ramp until a second timing
- it can start with no timing and then do 1 timing and then ramp until 2 timing
- it can add timing at full throttle only
- it can add timing according to your throttle stick position, with and without a switch-rpm
- it can do a zero timing mode so it meets all stock class rules if necessary
you see, you can do ANYTHING you'd imagine with that speedo with some clicks
but actually after some testing i found settings that you just use 1 slider for bottom end and 1 slider for top end, and the switchpoint to go with the motor
13.5/17.5 you even only use 1 value to change and nothing else so it's really easy
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-06-2010, 01:58 AM   #1826
Very interesting post !
The two sliders are timing 1 and timing 2 ?
XRay T3 - GM 120 / XRay NT1 RB / Mini Z
pierred is offline   Reply With Quote
Old 09-06-2010, 02:04 AM   #1827
No, the new software does not even use timing 1 and 2 anymore (but that's been written before)
amplimit is for bottom end (modified mainly, something between 140 and 180A is where you want to be) and fixed timing is for topend (for modified again between 5 and 12)
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-06-2010, 04:32 AM   #1828
housey's Avatar
Well I got the genius 90 and 13.5 motor and ran it on sunday, wow!
It was geared at 8.2 with standard mode 9 after some advice from a guy who has been running gm a while there and it was super fast!
One little thing though, does the speedo turn down the timing if it sees the moor is getting too hot? I ask because I did lose some punch towards the end of each race, but it was still very fast, so only a slight loss of performance.
I guess once I get the usb link I can set it all up properly, perhaps a slight decrease in timing would mean more consistent power throughout the run?
Old 09-06-2010, 05:05 AM   #1829
Which motor did you use?
8.2 is really wrong ... the gm can produce the revs to make it fast but you motor will be happier with a harder gearing (I'd guess 5.8 on that track you race on!)
you will get more bottom end rip and more straight line speed! even though it sounds weird
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-06-2010, 05:31 AM   #1830
housey's Avatar
Right I see. It is the GM 13.5 with the 12.3 rotor that I am using.
So going down to around 6 is going to be faster, but what about the temps? As I said before it was definitely slowing a bit towards the end of the run, is that because of the heat? And then does the speedo turn down the timing because of the heat?
Cheers for your help Martin.
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
