Old 02-27-2008, 01:29 PM   #166
Send a message via MSN to mark34 Send a message via Yahoo to mark34
Originally Posted by Martin Hofer View Post
make sure you set you servo travel to 100 on the tx in both directions forward/rearward
and you have to gear the motor much much longer than as if you would use the nosram esc
Can anyone explain why you have to gear the GM speedo so differently to other manufacturers ESC
Mark
Yokomo BD
CEFX C12
Powered By Demon Batteries and GM Brushless and 2 thumbs
Mark Ashby
mark34 is offline   Reply With Quote
Old 02-27-2008, 01:44 PM   #167
Mark
When running sensorless the motor makes less RPM so more gear is needed to compensate for the loss of speed.
Dan Hughes is offline   Reply With Quote
Old 02-27-2008, 02:22 PM   #168
So thats why my car has felt like an on off switch need to lenghten gearing to attain top speed and regain feeling of control
Mark
Yokomo BD
CEFX C12
Mark Ashby
Old 02-28-2008, 04:33 AM   #169
The gearing with the GM-Speedo is only longer compare to the LRP/Nosram.
The GM-Speedo does run the motor in the best efficiency, that's why our drivers do have more power and run time.
Also this is on of the reasons you feel nearly no difference between using sensors or not.
habicht is offline   Reply With Quote
Old 03-09-2008, 06:52 AM   #170
Could any one give me a an easy eaxplanation of how to use the hand hold progrramer cos all i managed to do when setting the speedo last night was completly confuse the gm 100 and had to do a reset to get it working again lol
I just find the the instructions a little confusing.
Mark
Yokomo BD
CEFX C12
Mark Ashby
Old 03-09-2008, 09:19 AM   #171
The programming wire must be connected.
The programmer must be in the receive mode with pushing the middle button in the right menu.
Push the set-button on the speed and hold it and plug in the drive battery at the same time. Hold the button, until you can hear the first beeps of the IDA-mode.
During receiving the datas on the programmer, the programmer LED does flash.
After receiving, you get a message on the programmer. Now you can modify the values and you can send them back in the send mode with the middle button again. The LED is flashing again and the speedo will make the confirmation beeps.
Make this several times and check all values, so you get used to it.
We are doing a new PC software at the moment, which does the programming more easy. I think we will do it to the web page next week.
Old 03-09-2008, 02:24 PM   #172
Hi
Thanks for the reply followed your instructions did no problems, you would not believe how many times I have tried to follow the instructions in the manual and got no were
Mark
Yokomo BD
CEFX C12
Mark Ashby
Old 03-09-2008, 02:29 PM   #173
Perfect. Should be the same as in the instruction, just the instruction is longer, maybe to long.
But it's good, that it works now.
Old 03-15-2008, 02:42 AM   #174
alan1467's Avatar
I have a friend with a 95 speedo that has a problem. Brushed works fine, sensorless if fine but add a sensor lead and any motor coggs bad or will not start until you push the car? any ideas
I have 2 95's and no problems
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 03-15-2008, 01:12 PM   #175
Maybe a bended sensor plug pin or a broken sensor wire.
I recommend driving without sensors anyway. Our drivers do not feel a difference. Driving without sensors is most times more efficient.
But check for bended pins, because this may cause other trouble, too.
Old 03-16-2008, 09:51 AM   #176
JevUK's Avatar
Can anyone tell me if the 100 is fully sealed from water? If you dunked it in a bucket would it still work?
MRT, Novak, Spektrum, Sanwa, Tamiya, Alleven RC, Maxamps, CheapBatteryPacks, Duratrax Ice, Pro Peak PSU, Nuova Faor, McLarney Racing, Futaba, KO Propo, Team Associated, Enerland.
JevUK is offline   Reply With Quote
Old 03-22-2008, 08:03 AM   #177
alan1467's Avatar
Hi I'm putting a GM95 in both my TRF501X buggy and TRF416 TC do I need to run a fan/heatsink on either? It's a 5.5 in the 501X on 6 cell and 4.5 or 3.5 in the TC on 5 cell
Thanks Alan
Tamiya TRF - Tekin
Old 03-22-2008, 08:38 AM   #178
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
maybe adding the additional top heatsink would be quite good for both classes. it weighs only a few grams and brings down the temps quite good
this is what i use in the tc (no fan) with 3,5T and less.
the genius 100 is splash proof ... you may not worry too much about making it waterproof if the track is only a little wet, but playing "cruiseship" is not what it has been developed for :-)
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 03-22-2008, 08:48 AM   #179
alan1467's Avatar
Many thanks for the reply, how do you stick the heatsink to the speedo? I have a GM heatsink
Alan
Tamiya TRF - Tekin
Old 03-22-2008, 12:26 PM   #180
Slideaway's Avatar
Hi Martin,
I recently get a Genius 100, and God, the genuine heat sink casing is so big !
I was wondering if it was possible (and easy) to change it for the Genius 80 Purple case (2894.2). Of course I will install the optional heat sink over and also a fan to balance with the thermal exchange loss.
Do you think it's reasonable?
Hope I will have one of your "Fast as Lightning" reply !
Cheers
Slide
Ludo
Thai Ride Tech Support.
Slideaway is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
