Old 08-11-2010, 01:25 AM   #1726
Slideaway's Avatar
Originally Posted by YZFAndy View Post
Hi all.
Just got this speedo and looking for some help with brake settings.
I've read about 60 pages of this thread but can't find a decent explanation of the terms for the braking and the manule being a direct translation doesn't seem to work.
can anyone explain or point me to a previous post of these setting?
BrakeMin. I'm guess the minimum that the brakes will come in at. If set to 100% they would work like an on/off switch?
BrakeMax. Guess you can limit the total amount of braking power available?
Autobrake. = Drag brake
Full brake. not a clue
Time to full brake. Guess a build up to full power
SoftBrake. Not a clue
What i'm after more than anything is a build up of brake from say 25% to 95% over half a second. Is that possible with this controller, if so what would the setting be?
Greatfull for any help.
With the AS Genius Tool (PC Interface), there's a clickable question mark where the function is tried to be explained. I agree it's not that clear at the first read cuz' it's tranlated from German and we may loose a bit of quick understandability in the translation process.
Ludo
Thai Ride Tech Support.
Slideaway is offline   Reply With Quote
Old 08-11-2010, 01:56 AM   #1727
Wrote some pages before
With V8.0 in old gm120/90 is problem with cutt off voltage.
Set it a little lover then 6.0V for 2S
Regards!
m.
ps: very similar shit with gm95 for E12 and 1S racing
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 08-11-2010, 02:32 AM   #1728
Slideaway's Avatar
To me, if you choose value 30 (for ex), then you have 30% of the maximum braking action right after the neutral. Which make the brake more delicate to control.
Yep something like that. The maximum amount of brake proportionnaly distributed on 95% of the transmitter brake travel, before the red LED flashes.
Correct
It's the value of brake action when the red led is about to flash. You can use this function like this: for ex, let's say you need only 80% of the max brake you can adjust an additionnal braking action (emmergency brake) only when you reach the very end of the transmitter brake travel.
Yes, it delays the full brake point...
Kind of delay too.
Once again this is how I understand things. I'm discovering the material and that's what makes sense to me. But it may not be the truth!
Ludo
Old 08-11-2010, 04:59 AM   #1729
Below is how i understand it.
That's how i understand it too.
This is how much brake at full stick travel
Correct
The amount of brake when you hit full stick travel quickly (think off road where you dab full brakes to change the attitude of the car in the air)
Kind of delay too.
How sharp the brakes are, I have mine over to the right on the slider (the minimum delay setting) but it's more a feel thing rather than changing the amount of brakes.
CPD Racing
chris_dono is offline   Reply With Quote
Old 08-11-2010, 05:11 AM   #1730
Slideaway's Avatar
Glad to hear it !
Ludo
Old 08-11-2010, 05:16 AM   #1731
Slideaway's Avatar
Any constructive/objective comments about these settings are warm welcome.
I used these parameters in Mod Class, lipo 2S, 4.5 Star, rubber tires, 7.5 FR, at RC Addict (same track as the late TITC in Bangkok, Thailand).
GM Brushless-ludo2-1.jpg   GM Brushless-ludo2-2.jpg   GM Brushless-ludo2-3.jpg   GM Brushless-ludo2-4.jpg   GM Brushless-ludo2-5.jpg
Ludo
Old 08-11-2010, 06:02 AM   #1732
tomracing's Avatar
after reading the manual again i must change my view on the brake settings!
regarding the brake settings
I thought:
max brake is indeed the brake level at max stick travel.
wrong max brake is the limit brake level available before full stick travel
full brake level is initiated after the time to full brake delay.
according to the help file used for coming to a full stop in the pits or correcting the flight of the off road vehicle in a jump. and possibly as emergency brake for onroad.
very wrong!
full brake is the brake power available at full stick travel
so if you limited max brake to 80 but set full brake at 90 you will have a step up from max brake to full brake as soon as you reach the full brake stick position.
the reason the example uses full brake at 90 is because the last feature time to full brake is actually a last step of the controller
it activates full brake power (100%) after the time delay
so full brake would only make a difference if you set it higher then the max brake. other way round i guess or a bit the same
sorry for the confusion but i hardly set other values for the two brake settings.
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 08-11-2010, 06:09 AM   #1733
Slideaway's Avatar
Got it !
Ludo
Old 08-11-2010, 09:35 AM   #1734
I have things slightly different (start amps lower, frequency lower)
Lipo discharge is set to 4000, is that the capacity of your battery or have you just not changed it ?
CPD Racing
Old 08-11-2010, 03:55 PM   #1735
Slideaway's Avatar
Ok about the Start Amp and Frequency, will give it a try.
About the 4000mAh, nope, it is not the capacity of my batteries (I run 5400).
I didn't set this value. Actually, after a 5 or 6 minutes run, when I recharge the batteriy, it takes around 2400mAh to be full again. Anyway, I never run more than 6 minutes for safety reason.
Ludo
Old 08-12-2010, 06:31 AM   #1736
JonboyGB's Avatar
Hi all,
Some of the clubs here in the UK are starting to run 'Truestock' classes in 13.5 and 17.5. ie, no advanced timing or turbo effects allowed.
On my GM90 2010 the last four modes are for timing (6-9), is mode 5 then with no timing? If not, is it possible to run my GM in these classes or am I going to have to find an alternative?
Cheers ears.
www.zen-racing.co.uk
JonboyGB is offline   Reply With Quote
Old 08-12-2010, 06:39 AM   #1737
*SBH*'s Avatar
Hi Jonboy
If You update the software to the newest version 12,4 there is a setting without advanced timing and the LED in the speedo will blink. (It was installed in version 11,9)
Mode 4 and 5 should be without timing as far as I read
*SBH* is offline   Reply With Quote
Old 08-12-2010, 07:48 AM   #1738
tomracing's Avatar
as far as zero timing i'd say
reserved = 0
reserved2 = 0
reserved4= 0
then all timing options are off.
with the new software the led should blink in neutral.
careful with modes 4 and 5 as the default settings have a reverse activated!
Tom van den Brink
Old 08-12-2010, 03:21 PM   #1739
JonboyGB's Avatar
Cool, cheers SBH and Tomracing.
Old 08-13-2010, 05:00 PM   #1740
JonboyGB's Avatar
Originally Posted by MMMRC/KevinK View Post
Hi I am a member of Mendip(Weston Supermare,UK) which is a large out door asphalt track with a main straight of about 70 meters long and I need some help on what settings I should be using with my GM 90 2010 PRO speed controller as Iam new to electric raceing as i normaly race 1/10th nitro touring.
I am running a GM 10.5 motor and am running with standard internal gearing(1.9) on a Xray T3 and the problems I am getting is that the motor is fine for about two minutes of a five minute run (good acceleration and good top speed) them the motor seems to loose a bit of power. The motor dose seem a little warm when it comes off track after five minutes. I have tried different 64dp gear ratios and cannot get the motor to run consistently for full five minutes could anyone give any advice on what settings for speed controller and what gearing would be a good starting point to try and solve my problem.
Hiya, I race at Kemble, similar-ish size track to Mendip I think (not raced at your track yet). I've got a GM90 2010 with this years GM 10.5 motor. Settings are on standard mode 9 only. Not played with anything else. Gearing is on 6.8. Car absolutely flies and the motor comes off between 60 and 70 degrees C whixh is fine. Never had any drop off in power - I use Demon Power 5000 40C lipo's.
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
