Old 07-17-2010, 02:40 PM   #1711
Send a message via ICQ to MattW
Well, 75 isn't available yet, so 90 would be the obvious choice.
MattW is offline   Reply With Quote
Old 07-22-2010, 08:46 AM   #1712
Default GM in E12
anyone?
which one?
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 07-27-2010, 06:05 AM   #1713
Default GM 90 2010 Settings
Hi I am a member of Mendip(Weston Supermare,UK) which is a large out door asphalt track with a main straight of about 70 meters long and I need some help on what settings I should be using with my GM 90 2010 PRO speed controller as Iam new to electric raceing as i normaly race 1/10th nitro touring.
I am running a GM 10.5 motor and am running with standard internal gearing(1.9) on a Xray T3 and the problems I am getting is that the motor is fine for about two minutes of a five minute run (good acceleration and good top speed) them the motor seems to loose a bit of power. The motor dose seem a little warm when it comes off track after five minutes. I have tried different 64dp gear ratios and cannot get the motor to run consistently for full five minutes could anyone give any advice on what settings for speed controller and what gearing would be a good starting point to try and solve my problem.
MMMRC/KevinK is offline   Reply With Quote
Old 07-27-2010, 06:44 AM   #1714
tomracing's Avatar
have you tried increasing the value of min timing time?
to between 20 and 25
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 07-27-2010, 04:10 PM   #1715
I checked and was set at 8 so have set it at 23 and will have to give it a go .
What should the Max Timing be set at with Minimum set at 23?
Old 07-28-2010, 09:04 AM   #1716
tomracing's Avatar
In previous software i would have kept the fixed timing the same or lowered it a bit to keep the temp down and give it a min timing time of about 20 to see what it would gain to lower the temperature then.
but in GII software i am not 100% sure min timing time still has the same function of lowering motor temp on over revs.
the text about fw>11.1 says keep the temperature/power is set with fixed timing 12-25
it may also work to lower the fixed timing and lower the fdr to regain some of the speed lost as long as the motor temp is happy.
Tom van den Brink
Old 08-03-2010, 05:01 AM   #1717
It looks from GM site that there is a new firmware 12.4, can anyone confirm this because my german is not so good.
jorgesimes is offline   Reply With Quote
Old 08-03-2010, 06:49 AM   #1718
Trader Rating: 10 (92%+)
looks like drag brake issue has been fixed in 12.4
captain stacker is offline   Reply With Quote
Old 08-03-2010, 04:27 PM   #1719
hana166's Avatar
Yay!
In the meantime I have learned to drive without it and to brake only when necessary..
..as a result I have become a better driver..and my laptimes have improved quite a bit
hana166 is offline   Reply With Quote
Old 08-05-2010, 06:02 AM   #1720
cyclone's Avatar
Default Motor temps
Hi guys,
Has anybody experimented with the settings on the latest version speed controls in order to reduce the temperature of the motor?
If putting less strain on the motor was the primary aim, which settings might you suggest reducing?
Cheers
Andy
cyclone is offline   Reply With Quote
Old 08-05-2010, 08:30 AM   #1721
Default Gen I Genius 120 V8.0 issues
Hi
I've got a Gen I Genius 120 that's been updated to V8.0 firmware and I'm having real problems with it and am stuggling to find info on how to tune the ESC.
My main problems is that the ESC looses it's top end speed after about 2 mins of running. For the first 2 mins it's awsome down the striaghts and keeps up with the lastest speedos like the Tekin RS, but after 2 mins I can not keep up. I've changed my battery to a new speed power 5300 30C 2S lipo and this has made no difference. My current gearing is around 6.7:1
I'm wondering if I can increase the min timing parameter a bit to reduce the top end, and then gear the car up a bit. But info on V8.0 is sketchy and I don't want to risk damaging the ESC by changing things.
Has anybody got experince of V8.0 and can give me some pointers, as I don't want to replace this speedo as I'm sure it's very capable
Mark
Markeo is offline   Reply With Quote
Old 08-06-2010, 03:37 AM   #1722
PizzaDude's Avatar
Originally Posted by Markeo View Post
Hi
Mark
The v8.0 update has a bug in it.
Set the cut-off voltage way lower.
This should solve it.
You can also search in this thread. It has been explained before.
Good luck.
PizzaDude is offline   Reply With Quote
Old 08-06-2010, 03:57 AM   #1723
Thanks for the reply, I forgot to mention in my first post that I already have the cut off voltage set to the minimum value possible of 2.1V. This seems to give it more speed than the Lipo mode after 2-3 mins of running but it still slows down a lot.
Also I didn;t mention that my motor is a speed passion V3.0 13.5T and after 5 mins it comes off around 55 degrees, which is cooler than when I had V7.2 running on my ESC.
Has anybody has got a good GDA file for a 13.5T motor that works well that they could send me to try?
Old 08-07-2010, 02:40 PM   #1724
Hi all.
Just got this speedo and looking for some help with brake settings.
I've read about 60 pages of this thread but can't find a decent explanation of the terms for the braking and the manule being a direct translation doesn't seem to work.
can anyone explain or point me to a previous post of these setting?
BrakeMin. I'm guess the minimum that the brakes will come in at. If set to 100% they would work like an on/off switch?
BrakeMax. Guess you can limit the total amount of braking power available?
Autobrake. = Drag brake
Full brake. not a clue
Time to full brake. Guess a build up to full power
SoftBrake. Not a clue
What i'm after more than anything is a build up of brake from say 25% to 95% over half a second. Is that possible with this controller, if so what would the setting be?
Greatfull for any help.
YZFAndy is offline   Reply With Quote
Old 08-11-2010, 01:19 AM   #1725
Slideaway's Avatar
Hi
Mark
Just wondering if you really have Speed Power 5300 30C battery when you tried. Is it really 30C ? With 30C only, I think it's kind of normal than the power is good at the begining and fade a bit during the run.
I experimented about the same thing in Mod class with some 40C batteries. Once you put a SMC 50C, things get quite improved.
Ludo
Thai Ride Tech Support.
Slideaway is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
