Old 04-29-2010, 09:35 AM   #1546
Originally Posted by Martin Hofer View Post
why is everybody messing around with softstart!???
I reckon it's with the Highspeedtiming enabled (reserved4=1)
in that case it starts off in HST mode already, the slight back and forth rocking is normal and you won't get that away
you could enable HST with switchpoint (reseved 4 = 3) but then you have a switchpoint which normally never feels really good.
11.6 runs more stable, issues of the speedo not starting once in launch control have been solved, and when no power program has been enabled, the leds flash in neutral
that's it
I stongly recommend updating!
Not sure the issues have been completely solved, still happened to one of the lads last weekend, even though he was running 11.6 ?
CPD Racing
chris_dono is offline   Reply With Quote
Old 04-30-2010, 05:19 AM   #1547
hana166's Avatar
In the software, if the switchpoint starting was updated to, say, 500 instead of 5000 this would cure the problem and give more flexibility for users. I would like the factory to do this.
hana166 is offline   Reply With Quote
Old 04-30-2010, 09:47 AM   #1548
hana166's Avatar
BTW I have experienced no rocking back and forth with the Graupner motors - its perfect
Old 04-30-2010, 09:53 AM   #1549
not using a switchpoint (HST set, but reserved4=1)
Both cars using GM motors (10.5 and 8t delta) and behaviour is similar on both on 11.1 and 11.6, the rocking back and forth is fine, but not leaving the line could cost you a race..
CPD Racing
Old 04-30-2010, 11:26 AM   #1550
hana166's Avatar
Agreed I guess this has got to be fixed immediately. #you might get rammed on the line which woud not be good. Mine has been spot on though..
The 7.2 addressed all the problems of the 4.9 but at least this time we won't have to buy a new speed controller lol
Old 04-30-2010, 01:50 PM   #1551
Trader Rating: 1 (60%+)
hi my esc fw is 4.9
no update to 11.6
cico is offline   Reply With Quote
Old 05-02-2010, 03:37 AM   #1552
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
sorry but there is absolutely no point! in having a switchpoint below 5000rpm!
as for the starting problem
11.1 speedo -> update to 11.6
11.6 speedo -> change receiver (which one is used?)
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 05-02-2010, 03:52 PM   #1553
We've seen it on spektrum's own 2.4 as well as Futaba 2.4 receivers (swapped futaba reciever today and still does it.
CPD Racing
Old 05-02-2010, 05:41 PM   #1554
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
11.6 Fading half way though a race....
Motor and ESC temp really good just seem to run out of puff half way though a race.
Anyone else having the same problem.. running GM 120 (2010)
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
Old 05-03-2010, 01:42 AM   #1555
Default GM 90 2009 updated firmware
Hi there was hoping for some advise, just sent my gm 90 2009 away and had the software updated, i must say im really disappointed.
Having spent the weekend at mendip, after 2 to 3 minutes the car would slow to a walking speed almost, motor temp 45 degrees c. Leave it for a few minutes and go out again and the same would happen.
Now i'm not experienced with this speedo so i spoke to chris grainger, chris kerswell and the rest of the team and they couldnt help me either. The eventually managed to load a different profile for me but it did the same and wasnt as fast before it went slow after a few minutes - temp was 50 degrees c this time.
Can anyone help? or know if i can send back to gm to put the original software back on, because at the moment its only suitable for the bin.
ben_cane is offline   Reply With Quote
Old 05-03-2010, 05:07 AM   #1556
it's not a gen2 speedo but a old one with firmware 8.0?
what temperature is the motor cut off set to? how about gearing/ which motor/ speedo settings?
I experienced that customers had the none starting issue even after I put a testing software on that was starting with a 100% security, we changed the receiver and cleaned up the wire mess and it worked!
so if 11.6 is still not starting and that on asphalt, check the other components, make sure everything is installed neatly and then it should work
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 05-03-2010, 05:58 AM   #1557
John_S's Avatar
I have had non start issues with spectrum with non gm speedos also. They seem to shut off if they have no activity for a set amount of time? Its strange and has caused me a few rear wishbones
John_S is offline   Reply With Quote
Old 05-03-2010, 08:51 AM   #1558
Default gm 90 2009 problems
correct me if i am wrong but i cannot see an option to adjust temp cut off on this speedo?? its not the same as the 2010.
yeah gen 1 gm 90.
Old 05-03-2010, 10:17 AM   #1559
John_S's Avatar
I think you can only set it to on or off on the gen1 speed controller.
Old 05-03-2010, 03:00 PM   #1560
jonny123's Avatar
Need a little help with speedo settings for modified racing outdoors. Open mod with lipo. I'm running the gm 6t delta and was really suprised how
driveable it is... I've been running mode 2 sensored on the gm 120 2010 esc. geared at 8.0. If i drive slightly too hard the car fades off toward the end of the run. I can't really understand why as the motor doesn't get very hot and I'm only taking about 3600mah out of a 5200 lipo. Chris kerswell, Chris Ashton, we're able to cruise up behind me on the straight and yet there cars wouldn't fade at all using the same motor.
Any help would be appriciated ;-) need to sort it for the national in 2 weeks at mendip!
Xray-Hudy-Ko Propo-RC DisCo Uk-Ardent Racing-Boultspeed
jonny123 is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
