Old 04-10-2010, 02:47 PM   #1501
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by Lutz View Post
For me it seems that std mod 9 is too much for a 10.5. You could try a lower powercurve maybe with a higher fdr. The most important thing is to check temps regulary while driving if the motor hasnīt a ntc build in. You should also set your rpm limit to 50.000 and activate timing with sensors +30 because in the manual it is said that the powercurves work only if its activated
Sorry to correct you but I think it's necessary to do so:
DON'T change timing with sensors to 30, leave it at 0
Powercurves are NOT USED AT ALL! with the new software. Mode 9 features powercurve 9 simply cause ral forgot to set it to 0 ... but it doesn'T matter anyway as it is unused...
rpm limit should be anything below 100.000 to make sure the magnet doesn't blow up
I personally have not tested with 10.5 but reports from teamdrivers showed that with a gm motor you can run about 22 - 24 of fixed timing
with the speedpassion c..., sorry motor, not featuring a NTC run 20 MAX! and temp every few minutes. Never run longer than 5 minutes (temp reasons)
as for gearing:
shorter gearing = hotter motor!
the gearing works totally different on the new speedo.
indoors you run approx 5.5 with the gm motor and 5.0 with the graupner #6564 (13.5)
so you will be aiming for approx 6.0 - 6.2 with a 10.5 indoors
if you gear it shorter it will just get hotter and slower
outdoors we will be running the grapner 13.5 with 4.0 or lower, or 4.0 - 4.5 with the gm motor
I think that should be ok
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 04-11-2010, 12:57 PM   #1502
hi martin
i have a new 2010 120 and have updated the firmware, could you reccomend a good starting point for 17.5 i have a choice of 2 motors a speed passion and a losi any help would be appreciated.
thanks
james
jameslucas is offline   Reply With Quote
Old 04-12-2010, 09:30 AM   #1503
no problem, just wanted to help but it seems I didnīt understand the new software till then Got my new esc on wedensday
I just had problems with the Graupner 13.5er so had to use my old combination at the championschip but I think it should work next time
Lutz is offline   Reply With Quote
Old 04-12-2010, 11:10 AM   #1504
Hi Martin,
I just bought a new gm 120 II.
I only drive modified and i dont have a laptop to bring to the track.
I would like to test with the new brake software because i think the difference between high speed and low speed is to big.
Is it possible to copy mode 3 to all 8 modes so ans then adjust the new brake software al littlle bit on al 8 modes?
This way i can just use another mode every time with my transmitter and i dont need a laptop at the track.
Grtzz.
sitting duck is offline   Reply With Quote
Old 04-12-2010, 09:14 PM   #1505
Would like to check with u guys, is there any rc online shop selling gm120 (GM97168); it's kinda difficult finding it on the net
as for firmware update is it posible to do it yourself over usb ?
Thanks & Regards,
Leonardi
leonardiw is offline   Reply With Quote
Old 04-13-2010, 01:43 AM   #1506
Graham Kenny's Avatar
Thanks & Regards,
Leonardi
Keep an eye on www.racing-cars.com and yes the new 2010 GM120 can be user updated.
Team Schumacher UK - GM Racing - TIR - Boultspeed RC Paint
Graham Kenny is offline   Reply With Quote
Old 04-13-2010, 04:17 AM   #1507
Thanks for the info, just curious what kind of usb cable being use to interface onto the esc ? is it included in the gm esc package ?
Old 04-13-2010, 05:10 AM   #1508
Nope its not included in the 2010 package. its avaiable seperatly at a reasonable price. Its a Standard USB cable but with a GM-sensor conversion so it is nessesary to PC program. again i got mine from Schuey direct
Old 04-13-2010, 08:50 AM   #1509
i have a 2009 gm 120 thats been updated to firmware 8
what software version do i use with this?
issac51 is offline   Reply With Quote
Old 04-13-2010, 09:44 AM   #1510
John_S's Avatar
you can use software 1.6.x for firmware 7.2 and above.
John_S is offline   Reply With Quote
Old 04-14-2010, 07:17 AM   #1511
Does anyone know who sells GM Genius 120 brushless ESC's in the USA
@Graham Kenny
Thanks for the info dude
Old 04-14-2010, 10:27 AM   #1512
John_S's Avatar
here is the us importer
Graupner Agent, Hobby Lobby International
5614 Franklin Pike Circle
Tennessee 37027 Brentwood
Tel.: +1 615 373 1444
Fax: +1 615 377 6948
Email: [email protected]
Homepage: www.hobby-lobby.com
hope this helps
Old 04-16-2010, 03:57 PM   #1513
Nope!:
use 1.4025 for V8.0 speedos and do a factory reset before using it
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 04-16-2010, 04:04 PM   #1514
Nope!:
How does that happen?...(factory reset)
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 04-16-2010, 04:44 PM   #1515
Questions??
Can anyone help, GM120 Gen2 2010 newbie!!!
I have managed to download all the progs from gm site in the correct order someone posted in this forum and got the setting software (Genius_Generation_II_Setup_01_06_03) to communicate with the esc and upload the settings from it, however I can't get the upgrade software ( GM_GENIUS_UPGRADER_1_0_3) to recognise a connection with the esc? I have made sure the tab is set to the same port as the set-up programme in my case com2 . Can anyone help? Also I get a red light not a yellow one on the usb board in the cable, is this correct?
I am wanting to install the 11.1 firmware for stock 10.5
Never had a gm before and getting a little frustrated! Martin or anyone Please help.
Steve UK is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
