Power supply for Duratrax ICE? >
Old 08-22-2007, 04:42 PM
hanzo3's Avatar
Trader Rating: 55 (100%+)
Default Power supply for Duratrax ICE?
Can anyone point me to a power supply that will work with the ICE? It has those jumper cable style connectors. How do they fit onto banana plug connections?
hanzo3 is offline
Old 08-22-2007, 04:55 PM
kuzo's Avatar
One DuraTrax IntelliPeak ICE charger w/ banana jacks on output lead, ** alligator clip charge leads, Tamiya style charge lead, input lead with pre-installed banana plugs, large alligator clips, and instruction manual
This is the description of the Ice from Tower and this is how mine is. Did someone replace the leads? Also the alligator clips that come with the Ice have handles that plug onto banana plugs. Check to see if your comes off.
kuzo is offline
Old 08-22-2007, 04:56 PM
Jam-ehz's Avatar
Chop the clamps off and put your own banana plugs on..
On each end of the clamp handle should be a bit of metal that can be crimpled to grip a wire, one end already being used for the wire you chopped off, and one free. I bent the free end into a small circle so it will allow a banana plug to be inserted snugly.
That way, you have the best of both worlds.. plugs for a PSU, and clamps if you need to use a battery.
--edit--
Or, what Kuzo said.. if Duratrax already provides those plug ends for the clamp, then you're already set...
Jam-ehz is offline
Old 08-22-2007, 05:26 PM
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
i used a hobbico power supply plugs rite in,also looking to sell it
20 SMOKE is offline
Old 08-22-2007, 05:34 PM
hanzo3's Avatar
How much are you selling it for?
hanzo3 is offline
20 SMOKE's Avatar
pm'd u
20 SMOKE is offline
Old 08-23-2007, 05:18 AM
CarlosG.'s Avatar
Sorry, but I am not bagging on your p/s , but to handle the motor break-in or motor run-in on the ICE will require a high current rating. Since it can easily spike over the 10 amp limit the ICe has for this procedure. You will need something like the Competition Electronics Power Supply that is 23 amps peak rated. That is what I have. If you don't plan on using the motor run-in feature then that p/s will work.
CarlosG. is offline
Old 08-23-2007, 04:40 PM
20 SMOKE's Avatar
when i had my ice i got a 30amp bulldog and it cut off and also the hoddico is what they have on there website as a power source
20 SMOKE is offline
Old 08-23-2007, 08:23 PM
R/C Tech Elite Member
EricW's Avatar
I thought I read somewhere it's recommended to use a power supply with at least 14 amps. Also, you should be able to pull the alligator connectors off the end of the cables and see the banana plugs already installed.
EricW is offline
Old 08-24-2007, 04:39 AM
hobbipro's Avatar
Trader Rating: 23 (100%+)
It also depends on how you use your ice. If you are running BL, you wont use the motor break in feature. If you are using lipo packs, you wont use the 10 amp discharge either (but this has nothing to do with the power supply). I'm using both BL and Lipo, so i just picked up a Much More 8amp mini power supply to reduce my track side clutter, before that was a large, integy 14amp supply. The mini allows me to plug into the supply with the bannana jacks.
Clarification, Had to add this in since some PP are picky.
hobbipro is offline
Old 08-24-2007, 04:57 AM
Trader Rating: 16 (94%+)
Originally Posted by hobbipro View Post
If you are using lipo packs, you wont use the 10 amp discharge either.
What does a 10amp discharge on the ICE have to do with the amperage capability of the power supply?
None... The charger only needs enough power to run the unit itself when running a discharge on a battery, as no charging is taking place to warrant any power drain from a power supply. The discharge is handled by the charger itself, this is why they get so darn hot when running a discharge.
You only need a power supply slightly higher than you intend to charge the battery at, or slightly higher than any feature you use on the charger that requires power/amperage. For Example, if you're charging a 6-cell 4200nimh pack at 6.0A, then you would do well with a 8.0-10.0A power supply.
There's nothing wrong with buying the Comptetion Electronics 23amp power supply if you got the money or have a real need, like running multiple items using the same power supply, but for most people the C.E. 23amp power supply would be overkill.
I bought the ICE from Tower, and bought the Ofna 18amp power supply for $95.
kn7671 is offline
Old 08-24-2007, 08:01 AM
Regional Moderator
CarbonJoe's Avatar
Just go to Radio Shack and get their 15 Amp 12V power supply. It is light, and can power two ICEs no problem, both charging NiMH packs @ 6 Amps. The local Radio Shack was closing, and I picked it up for $25. The normal price is $79.99.
The ICE already has banana plugs on the input wires, just pull the alligator clamps off.
CarbonJoe is offline
Old 08-24-2007, 09:37 AM
Mr. Shookie's Avatar
here is literally the cheapest PS and I have used it for three years now.
http://www.buyreliant.com/psupplies/psv200.htm
You can run your ICE, lathe and anything else.
Plus the Ice can sit right on top. That is what I do with my Checkpoint charger.
Hope that helps,
-Shookie <><
Mr. Shookie is offline
Old 08-25-2007, 04:18 AM
I picked up the Comp Electronic 23 amp PS. It works great. Little pricey though. The ICE banana clips plug into the back. Just tighten the screws on the PS. I also built a box that allows me to plug in my TC1030 charger and my GFX. Cost about 8 bucks and 20 minutes of my time.
Hunter is offline
Old 09-02-2007, 11:00 AM
hanzo3's Avatar
Will a pro peak power supply work?
http://www.hobbypeople.net/gallery/158300.asp
that one
hanzo3 is offline
