Balancing plug? Premium Power 4700 >
Old 08-22-2007, 02:02 AM
LOSI123's Avatar
Trader Rating: 63 (100%+)
Default Balancing plug? Premium Power 4700
I have a Premium Power 4700mah Li-Po
i was wondering if anyone knows where i can get the plug to suit the white balancing port that hangs off the pack it has 3 pins and looks like ones ive seen on motherboards of PC's before?
i will upload a photo shortly
thanks.....
LOSI123 is offline
Old 08-22-2007, 02:07 AM
pdungadamo's Avatar
the plug should come with the balancer. otherwise tower has them
http://www2.towerhobbies.com/cgi-bin...?&I=LXNGC4&P=V
pdungadamo is offline
Old 08-22-2007, 02:19 AM
LOSI123's Avatar
Picture.
LOSI123 is offline
Old 08-22-2007, 02:32 AM
LOSI123's Avatar
does not look like it will fit?
LOSI123 is offline
Old 08-22-2007, 08:47 PM
tpczx6's Avatar
do you have a balancer??
if not what kind of charger do you have?
you can buy an Equinox inline balancer. check with your LHS on the airplane and Heli side of the shop they should have some to look over.
if you need more info click on mikes in my tag line and give us a call we can get you hook up.
tpczx6 is offline
Old 08-23-2007, 12:44 AM
LOSI123's Avatar
i dont have a balancer, but i dont need one, as i have an ice, which can be set to one cell and as long as you can correctly work out the conections, then i will charge each cell then it will be balanced.
all i want is the plug to fit it with some wires hanging off...
LOSI123 is offline
Old 08-23-2007, 07:50 AM
MrUnlimited's Avatar
thanks.....
some charger has a balancer. I have a e-station charger which has a balancer. Nice sister you have (avatar)
MrUnlimited is offline
Old 08-24-2007, 01:58 PM
Scroll down to the middle of the page.
http://www.commonsenserc.com/index.php?cPath=32_39
gezer2u is offline
Old 08-27-2007, 04:24 AM
JevUK's Avatar
How are you getting on with this pack?
If they are working well they are the bargain of the century for 54$!
JevUK is offline
Old 08-27-2007, 12:00 PM
padailey's Avatar
So has anyone figured out what kind of balancing plug PP uses. PolyQuest/Hyperion or Equinox or something else. I hate all these different balancing plugs and so few places tell you what kind they use! Grrrrr!
padailey is offline
Old 08-27-2007, 03:12 PM
JevUK's Avatar
They look like PQ plugs.
If a pack does not have the plug you need on it it's easy to covert them. 1 pin is the + one is the - and one is the connection between the 2 cells. Use a tester to find out which is which, always worth checking before you hook up a new type of pack to existing equipment anyway.
JevUK is offline
