whats the diffrence between brushed engines and brushless? >
Old 08-18-2007, 06:53 PM
needhelpPLZ?'s Avatar
the question is in the title
needhelpPLZ? is offline
Old 08-18-2007, 07:20 PM
UN4RACING's Avatar
Trader Rating: 22 (100%+)
One sparks the other doesn't.
UN4RACING is offline
adamge's Avatar
so is the answer
adamge is offline
Old 08-18-2007, 07:22 PM
what i ment can yall give me some pros and cons of both?
Old 08-18-2007, 07:23 PM
UN4RACING's Avatar
The brushless is more efficient and a lot less maintenance.
Cost more to purchase yet will out last a brush 10 times.
Old 08-18-2007, 07:27 PM
where is a good place to buy just the brushless engine?
ray3619's Avatar
brusched = old school , bruschless = the future , ray , seriously , go to team associated or team novak and read all about it
ray3619 is offline
Old 08-18-2007, 07:28 PM
ray3619's Avatar
my spelling sucks
ray3619 is offline
Old 08-18-2007, 07:29 PM
UN4RACING's Avatar
Also aside from Mod racing there is some problems mixing different manufacturers is stock racing. It seems to please most you would have to run one brand or the other from club to club.
Old 08-18-2007, 07:32 PM
UN4RACING's Avatar
Start at the track. Then the hobby shop. And if all fails.? The net.
www.novak.com
Old 08-18-2007, 07:38 PM
UN4RACING's Avatar
Heres a good site.
http://www.aveox.com/home.html
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Electric "engines" are called motors for one
A normal speedo CANT run a brushless motor, The brushless can run bolth, And thats the cost in BL (brushless) is the speedo, there about 200 bucks, motors are 70-100 bucks
BL motors RULE!!! There SOOO smooth, no maintenance, No heat fade given it has a sintered rotor.. ETC
BlackedOutREVO is offline
Old 08-18-2007, 08:29 PM
this may sound stupid, but will a BL motor work if you used an on/off switch, or does the ESC have to do anything special? Like the old dragsters that used a micro switch to turn the low turn motors on.
parnelli97 is offline
Old 08-18-2007, 08:35 PM
UN4RACING's Avatar
Edit.
Now that I think about it more. There is no spark, so the speed control may be converting the DC power in some way.??
{Since brushless motors are essentially 3-phase AC motors that are commutated electronically, a brushed motor speed controller cannot be used. Each brushless motor has 3 power wires instead of the 2 found in a brushed motor, along with five sensor wires, that allow the motor to tell the controller where it is. These sensor wires take the place of the commutator in a brushed motor, and do the same job. The advantage to a brushless controller is that there must be a minimum of 6 mosfets (Aveox controllers use 12) to commutate the motor. This makes the effective ON resistance lower than a typical brushed contoller and therefore it will stay cooler at high power levels. }
I got this off that aveox site.
Old 08-18-2007, 08:48 PM
It almost sounds more like a stepper motor, it sends feedback to the ESC as to it's position and that allows the ESC to respond... I don't know much about BL but I'm trying to learn, because I'm building a few drag cars and I want SPEED!!! The catch is even BL isn't fast enough stock.
