Decal paper
Old 08-29-2001, 12:41 PM
  #31
R/C Tech Founder
If you have a chance, send it to [email protected]
Hopefully the mail server will accept a file that large. I'll keep my fingers crossed.
I may eventually post some of this stuff somewhere on the home page in case people want to print their own R/C Tech decals. I'll let you know if I do. We need to spread the word, and what better way than on our cars?
futureal is offline
Old 08-29-2001, 12:44 PM
  #32
RCTech Member #2
TSR6's Avatar
Yeah, it looks cool on the cars... If i have extra $ before the indoor season i might run down to the local vinal shop. Maybe i can strike a deal... put "XXX-Vinal" sticker on the rear for some cheap decals
TSR6 is offline
Old 08-29-2001, 01:21 PM
  #33
Trips's Avatar
Trader Rating: 16 (100%+)
You've got mail...
Found a sign making supply shop here in town, picked up a roll of Avery 8003 clear vinyl, this stuff appears to be exactly the same as what Autographics uses for their stickers. I haven't printed anything on it yet, but I'll try some tonight and post results.
Trips
Trips is offline
Old 08-29-2001, 03:58 PM
  #34
Moderator
Speedo's Avatar
I have some of that static stick too. It is very transparent, but when you put the ink on it, the ink is trasparent also. I'm using a HP 970Cse, should I turn the ink volume up?
Speedo is offline
Old 08-29-2001, 05:11 PM
  #35
R/C Tech Founder
Thanks for the data Trips. More sticker varieties for the local racers here
When you say a roll of clear vinyl... what do you use to print that? Some sort of plotter? Or is it the printer you mentioned earlier?
futureal is offline
Old 08-29-2001, 05:52 PM
  #36
Trips's Avatar
THis particular vinyl only comes on rolls. I bought the smallest size they had, 15 inches by 10 yards long. I'ts got perforations on both sides, so it's really only 14 usable inches.
What I do is cut a 9 inch piece off the roll, then cut it in half and cut the perforations off. That leaves me with two 7*9 sheets to feed into the printer. Kind of a pain, but the material is great. It's transparent enough that it pretty much disappears when you stick it on, it's flexible enough to go around compund curves, and seems to stick really well. It also takes the color from my printer better than the other materials I tried, but I don't know how it will get along with an inkjet.
Trips
Trips is offline
Old 08-29-2001, 06:13 PM
  #37
R/C Tech Founder
Man I am really interested to know how that turns out. All of this talk makes me want to go out and buy a cheap plotter! I used to have access to some nice ones in a lab I worked in, and boy there was some cool stuff you could do with those.
futureal is offline
Old 08-31-2001, 10:49 PM
  #38
Trips's Avatar
Here are some results with the new Avery 8003 vinyl...
This stuff is very similar to what we're used to in the stickers we usually see, it's maybe a little thinner and a bit more flexible, which is okay so far. I painted up a body with a very simple paint scheme to see how the stickers would work.
Pretty much every sticker you see on this body with the exception of the headlights, taillights, grille, and "proline" is home made.
Sticker results here
Trips
Trips is offline
Old 09-01-2001, 09:37 AM
  #39
I have heard of people using a sticky film called Folex to print up stickers.
The article I read was from a guy who used it on Slot Car bodies so it may have an application for RC cars. He said it was no good for compound curves but a compound curve on Slot car is a lot tighter than the same thing on a 10th scale tourer so it might work.
Bosscat is offline
Old 09-01-2001, 10:59 AM
  #40
Moderator
Speedo's Avatar
Trips, where can you find this avery stuff? And did you do that with just an inkjet, or your special printer? They came out very nicely, well done!
Speedo is offline
Old 09-01-2001, 11:15 AM
  #41
drummer5's Avatar
Trips those decails look really cool man. Do u know of some vinal that I could buy at a regular store that would work with an inkjet?
drummer5 is offline
Old 09-01-2001, 02:51 PM
  #42
mike_Webb's Avatar
Can you print on the Vinal using a Laserjet..... I am ticked, thought it would be great to buy a nice Laserjet for at home and I got rid of my Canon Bublejet. I hope the Vinal can withstand the Laserjet
Mike Webb
mike_Webb is offline
Old 09-01-2001, 03:36 PM
  #43
Moderator
Speedo's Avatar
Sorry Mike, I don't think it will work I think the laser printer would heat up the stuff too much.
Speedo is offline
Old 09-01-2001, 06:55 PM
  #44
Jared Kirkwood's Avatar
mike_Webb - DON'T DO THAT. You will be out a good lazerject printer. Just get your files together, save them on a disk and go over to a friends house and print them out on a Inkjet.
Jared Kirkwood is offline
Old 09-01-2001, 07:04 PM
  #45
mike_Webb's Avatar
trust me... I wouldn't do that. We learned the hard way at work when someone bought the worng transparency paper and sent it through a really expensive Color Laserjet
