Old 07-28-2008, 01:27 PM   #1336
Originally Posted by TwoTone View Post
Need a little favor please.
I have EU spec with the updated pulleys. I'm running the USVTA series and needed a FDR of 4.2-4.3. Well that required a 34 pinion with the stock 84 spur 48 pitch- which doesn't fit.
Does anyone have 100 or 101 64 pitch spur that would post the diameter so I know it this will work without modification.
I would switch to 64pitch..sorry dont no the diameter...you would be alot better off in the long run....In my opinion....Nexus has a very good supply of spurs for the xray....
NUCRPTRACER is offline   Reply With Quote
Old 07-28-2008, 01:27 PM   #1337
drsfly's Avatar
Default 100 spur
A 100 t 64p spur with a 40 t 64p pinion and the 1.7 Internal will give you a 4.25 FDR.
Hope that helps,
Darrald
drsfly is offline   Reply With Quote
Old 07-28-2008, 01:33 PM   #1338
TwoTone's Avatar
Trader Rating: 12 (100%+)
Thanks, I knew the numbers I need, it's the physical size that I want to make sure will work.
With a diameter on the 101 or 100 spur I could compare that to what I have now and see if it will work without modding the motor mount.
TwoTone is offline   Reply With Quote
Old 07-28-2008, 01:47 PM   #1339
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Originally Posted by PitNamedGordie View Post
OK....
What is better...Using the asphalt upper deck to get more grip, or removing screws in the chassis to get more flex? Is one more consistant than the other?
I drive on a low to medium grip carpet track also and was thinking about the new upper deck too.
I wouldn't say that one is 'better' than the other. I have tried both ways that you are describing, and I preferred the optional top deck. For carpet, rubber, low-to-medium, I would recommend using both the optional top deck AND starting with most chassis flex and go from there...you might also want to try removing the two uppermost screws from your shock tower/bulkhead to get additional flex.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 07-28-2008, 01:48 PM   #1340
J.Filipow's Avatar
Originally Posted by ahsikes View Post
Well I'll pm you my address and you can send me one big money!!!
How's it going J?
hahhaha...I wish. I am just a little guy on a small U.S. team...I am not THAT factory!
Old 07-28-2008, 01:50 PM   #1341
drsfly's Avatar
I do not know the diameter.
A 100 will fit fine and give you the ratio you need if you are running 1.7 internal. If, as you said, you are running updated/upgraded pulley's.
If not and you are at 2.375 internal you will need like a 56 pinion & I have not tried that combo.
Darrald
Old 07-28-2008, 04:29 PM   #1342
adamge's Avatar
Outer diameter of my 100t spur is pretty much dead on 40mm, though it's tough to measure while mounted in my 008 US.
-Nietzsche
Old 07-28-2008, 08:13 PM   #1343
TwoTone's Avatar
Darrald
Thanks, in your last post I thought you were just telling me the numbers to use. I assume by this post you've actually fit a 100/40 combo in.
Old 07-29-2008, 04:50 PM   #1344
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default lipo
what Lipo/lipo's will fit the 008 the core 5000 will not I need to know for vegas
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 07-29-2008, 04:56 PM   #1345
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
The SMC 4000 is a great choice. The Trakpower 3200 will also and I believe most, if not alll of the Orions will fit.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 07-29-2008, 05:31 PM   #1346
yokemad's Avatar
Hi Kev
I use Trakpower 4900 but shrink wrap removed and 2x 0.3 mm shim under topdeck...
fits and works nice
hope that helps
yokemad is offline   Reply With Quote
Old 07-30-2008, 01:00 PM   #1347
Set up question...
I just started using the new Jaco Green wheels. These wheels are taller than RP30s. I had to lower my ride heigth by 1.5 mm to get back down to 5mm. By doing that my car now dives a little more in the corners. That is due to the roll center being raised by the new wheels....correct?
Old 07-30-2008, 01:03 PM   #1348
RBLove's Avatar
Trader Rating: 72 (100%+)
Set up question...
If you did not adjust your droop you now have 1.5mm more up travel front and rear causing the car to roll a lot more.
RBLove is offline   Reply With Quote
Old 07-30-2008, 02:12 PM   #1349
Ahhh. I'll look at that too. thx
Old 07-30-2008, 08:37 PM   #1350
t4m1y4niac's Avatar
guys,is there any news about the next Xray's Touring Car??? T2'009 or T3??? maybe.
on 17th Aug, i'll racing with my T2'007 in carpet track for the first time (foam tyre)....(i always run rubber-asphalt)...what should i change in my asphalt set up????
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
