Old 07-14-2008, 08:50 AM   #1291
yokemad's Avatar
hi guys
I've measured rear toe-in and it's uneven with 1.5 shims 3 degree one side 2.5 degree on the other side What causes that ?
Bended pivot pin ??
yokemad is offline   Reply With Quote
Old 07-14-2008, 09:25 AM   #1292
Trader Rating: 16 (94%+)
Originally Posted by yokemad View Post
hi guys
Bended pivot pin ??
I've found the same thing. Unless you have a tool that can measure toe-in specific to a single side of the chassis parallel to the centerline of the chassis front to rear, not left compared to right as the Hudy and Integy tools, than several items can affect the readings.
kn7671 is offline   Reply With Quote
Old 07-14-2008, 09:26 AM   #1293
Send a message via MSN to mark34 Send a message via Yahoo to mark34
Could be a bent hin pin more likely down to play in the suspension system as it cos quite hard to bend those pins
Yokomo BD
CEFX C12
Powered By Demon Batteries and GM Brushless and 2 thumbs
Mark Ashby
mark34 is offline   Reply With Quote
Old 07-14-2008, 09:50 AM   #1294
yokemad's Avatar
I've got TM HARD Setup station It's Quite decent one like Hudy setup station with all bearings and all...
Pivot pins rolls ok on setup board looks ok to me so it should be something common on 008s and like 0.3 difference between each side It's a bit annoying but I don't think you can even notice that with any other simple setup solutions ...
Old 07-14-2008, 10:34 AM   #1295
mok
mok's Avatar
R/C Tech Elite Subscriber
Send a message via MSN to mok Send a message via Skype™ to mok
the stand is alright, but not if the wheel axle gauge adapter isnt screwed on tightly.. i've noticed mine comes loose once in a while and can skew the results
-mark
mok is offline   Reply With Quote
Old 07-15-2008, 04:57 PM   #1296
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
How much clearance does the T2 008 have for a battery pack under the bulkheads/top deck? I am wondering if a Core RC lipo 5000 pack will fit.
Chirag Patel (San Diego, CA)
1/10 2WD Buggy: TLR 22 4.0 SR 17.5
1/10 4WD Buggy: TBD
cpatel529 is offline   Reply With Quote
Old 07-15-2008, 06:40 PM   #1297
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
It wont but if you look back a couple pages you can see where EA posted some picks where you just add a couple shims under the top deck...hope this helps
Bryan
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 07-15-2008, 06:56 PM   #1298
Without any mods, still fitting under the top deck, max height is 22.5mm.
Old 07-16-2008, 02:08 PM   #1299
strahler's Avatar
Default foams
i am new to 1/10 riding. i will buy a t2 008 us foam spec in the next days. what shores are used on carpet and what wheels (complete with rim and foam) can you guys recommend for carpet driving?
thnx
some cars...
strahler is offline   Reply With Quote
Old 07-16-2008, 02:21 PM   #1300
mickrcarver's Avatar
Trader Rating: 99 (99%+)
Jaco double pink rear Jaco double pink/orange front
www.ovrccc.com
www.speedybillsrc.com
mickrcarver is online now   Reply With Quote
Old 07-16-2008, 02:43 PM   #1301
.. or .. Jaco Double Pinks on all 4-corners.
Old 07-16-2008, 02:53 PM   #1302
justin lessard's Avatar
Send a message via AIM to justin lessard
Parma magenta rear and cyan front easy to drive. and the most forgiving combo
justin lessard is offline   Reply With Quote
Old 07-16-2008, 05:00 PM   #1303
stanislow's Avatar
Send a message via MSN to stanislow
jaco pinks up front and magentas in the rear
or
jaco magentas all around
for GQ
grey/blacks front greys rear
red/tan up front tans in the rear
greys up front tans in rear
Speedpassion, Team Trinity, AVID bearings, Titanium Racing
Eastridge Hobbies
RC Canwest Xray Jaco SMC
Mad Scientist Motors
stanislow is offline   Reply With Quote
Old 07-16-2008, 05:14 PM   #1304
Send a message via AIM to goop
thnx
so iguess this means that you have never raced foam before. if that is the case i would go with parma cyan front and magenta rear on the pro 53 rims. this tire combo is very smooth on steering but if it is too smooth for you than i would go with the parma magentas all around on the pro 53 rims. hope this helps
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 07-18-2008, 10:25 PM   #1305
TwoTone's Avatar
Trader Rating: 12 (100%+)
Putting electronics in my new T2 008 EU spec.
Got a question.
First, the manual say the steering linkage and server arm should form a 90 degree angle.
After mounting my servo, there is no way that is happening. I have it mounted in the rear most hole and the link is as short as it can be. When I rotate the arm to make a 90 angle, the servo output shaft would have to be almost at the mounting post.
Anyone mind posting pics of their electronics mounted please.
TwoTone is offline   Reply With Quote
