Xray T2'008
#1261
#1262
#1263
Whats that all about
#1264
#1265
Trakpower 4900 Lipo won't fit under 008 topdeck If I shim the top deck .5 all around Is that create a kind of disadvantage over standard car?
#1266
should be fine.
#1267
hello xray racers! I am tinking bout update my car. I think xray is good but where can i perceive one of thsese automobiles? Y is 008 so good many do good but what bout car makes it amazing i need a update car i want to win if u know what i mean any help would be great hello bye
#1268
You can get a 008 @nexus racing or on ebay for that matter you need to decide if you are going to run rubber tire or foam...Engineering or flawless engineering I should say is what makes any xray standout...However it really comes down to preference there are a few good cars out right now. But in my and everyone elses opinion on this thread XRAY is the only way to go. I used to not beleieve this as I used to run the TC5 so I bought an xray and now I dont own a TC5 anymore and wont be buying anything else...hope that helps...
#1269
#1270
LOL - I too had a TC5 for about 4-months. I traded my TC5 for a used T2 '007, and immediately started driving better and better from there. Xray's quality and durability are hands down the best I've ever experienced. I've never caught myself thinking, WTF about Xray. With the TC5 there are so many things that I kept on thinking WTF the entire time I had the car. Anyway, I know Xray is expensive up front, but I always suggest people try to find an Xray for their first car, this way they won't be discouraged from continuing to race from a broken car all the time.
#1271
Justin you have a PM
#1272
Hi dudes
I'm looking for a good Rubber Carpet setup for Low-Medium Grip Small Technical TRack
Any setup tips also Welcome
Thanx in advance
Thanx in advance
#1273
#1274
Thanx Mate
Have tried that setup?
It says medium Traction but that track should be High traction...Also Huge also Not Carpet Lol
I know Asphalt and Carpet Setups Not far away for rubber spec but not sure
#1275
Here is my setup Idea
Front
One-way diff
40W oil
C2.6
Tamiya Shocks
.5 toe out
1.5 Camber
1.4 A-roll bar
Servo saver:2
roll centre 0-0
Caster 4
5mm droop
5mm ride height
upper shock 3
3 hols piston
25%rebound
REAR
35W oil
C2.4 springs
No A-roll bar
3 degree Toe-in
Tamiya shocks
upper shock 4
roll centre 0-0
4mm Droop
5mm ride height
1.5 D Camber
3 holes piston
25% rebound
Medium Flex Chassis
Short wheelbase
Front
One-way diff
40W oil
C2.6
Tamiya Shocks
.5 toe out
1.5 Camber
1.4 A-roll bar
Servo saver:2
roll centre 0-0
Caster 4
5mm droop
5mm ride height
upper shock 3
3 hols piston
25%rebound
REAR
35W oil
C2.4 springs
No A-roll bar
3 degree Toe-in
Tamiya shocks
upper shock 4
roll centre 0-0
4mm Droop
5mm ride height
1.5 D Camber
3 holes piston
25% rebound
Medium Flex Chassis
Short wheelbase
