Old 07-04-2008, 08:26 AM   #1246
I am getting a popping growling noise off and on power when turning right...I took apart my axle and cleaned and light sanded to clean and reassembled and I still have the noise...my end point is only at 80%...any of you guys had this happen?
NUCRPTRACER is offline   Reply With Quote
Old 07-04-2008, 08:36 AM   #1247
Trader Rating: 16 (94%+)
There is only so many things it can be, but it's probably the Driveshaft Coupling.
Blade/dogbone: Is worn, has too much play inside the diff outdrive
Diff Bearings: When turning all the diff bearings get a workout
Wheel/Axle Bearings: Again, when turning, the bearings are under load
Driveshaft Coupling and/or Driveshaft: Badly worn from excessive use, excessive turning, and/or poor maintenance. The coupling can wear and decrease in size, causing play inside the driveshaft, as well as casuing wear the inside of the driveshaft, thus enlarging the hole inside the driveshaft. If this happens, a new coupling piece will only help a little in reducing the chatter here.
kn7671 is offline   Reply With Quote
Old 07-04-2008, 11:26 AM   #1248
Thanks....I have ordered new parts from nexus...
Old 07-05-2008, 02:12 AM   #1249
nitro neil's Avatar
Trader Rating: 73 (100%+)
I'm looking to get an xray this comming fall and i was just wondering if they made a us spec rubber tire car or do they only make eu rubber spec car
nitro neil is offline   Reply With Quote
Old 07-05-2008, 05:00 AM   #1250
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
The EU is the only rubber car they make.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 07-06-2008, 07:20 PM   #1251
dlarry's Avatar
Is there any where to get an on line manual for this car?
David Larry
Shepherd Velox V8, Serpent 411 Eryx 4.0, Novarossi, Bryons Fuel, Airtronics
dlarry is offline   Reply With Quote
Old 07-06-2008, 07:44 PM   #1252
http://forum.teamxray.com/viewtopic.php?p=60589
Old 07-06-2008, 07:45 PM   #1253
dodo's Avatar
Send a message via Yahoo to dodo
you can get it here
http://www.teamxray.com/teamxray/sho...p?file_id=4188
http://www.teamxray.com/teamxray/pro...ria=0&catName=
dodo is offline   Reply With Quote
Old 07-06-2008, 07:55 PM   #1254
m3ndo5a's Avatar
BYE BYE RAY008 FS
http://www.rctech.net/forum/showthread.php?t=230510
http://www.rctech.net/forum/showthread.php?t=230602
m3ndo5a is offline   Reply With Quote
Old 07-07-2008, 05:43 AM   #1255
dlarry's Avatar
Thanks for the help.
David Larry
Old 07-07-2008, 05:40 PM   #1256
TwoTone's Avatar
Trader Rating: 12 (100%+)
Looking at perhaps picking up a new T2 008 EU spec.
The two tracks I would run at are both indoor, one carpet and one is asphalt.
What would most of you say would be necessary hop ups?
TwoTone is offline   Reply With Quote
Old 07-07-2008, 08:41 PM   #1257
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
strangely enough, mainly crash parts, car out of the box is great. Springs one up one down from stock, same with swaybars. Shock oil, spool outdrives, half shafts, cvd coupler, spur gears to get to the ratio for your class, and the lil washers for adjusting toe, and track width, maybe some different roll center spacers. Most tracks its pretty close. alot closer than the t2007. well thats for asphalt, haven't run the car on carpet yet.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 07-09-2008, 12:10 PM   #1258
yokemad's Avatar
Hi guys
What LB is C2.6 and C2.8 Kit Springs?
Cheers
yokemad is offline   Reply With Quote
Old 07-09-2008, 12:23 PM   #1259
RBLove's Avatar
Trader Rating: 72 (100%+)
Originally Posted by yokemad View Post
Hi guys
Cheers
http://www.nexusracing.com/product_i...oducts_id=1572
RBLove is offline   Reply With Quote
Old 07-09-2008, 02:00 PM   #1260
yokemad's Avatar
Thanx mate
they are around 16lb and 17.5 Lb on most of the setup sheets C2.6 only ticked is that means C2.6 all around?
Cheers
