Old 06-29-2008, 07:59 PM   #1201
yokemad's Avatar
Hi guys I'm just wondering Do you upgrade your cars plastic shock bodies to alloy ?
If so is that the right part no: 308321
Cheers
yokemad is offline   Reply With Quote
Old 06-29-2008, 08:07 PM   #1202
RBLove's Avatar
Trader Rating: 72 (100%+)
308306 - T2'008 Alu Shock Absorber (complete)
308322 - Alu T2'008 Shock (body only)
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 06-29-2008, 08:10 PM   #1203
Trader Rating: 16 (94%+)
Cheers
Not sure about just the body, but the part number for the Aluminum '008 Shock set (pair) is 308306. These were just announced from Xray, as the '008 shock bodies are shorter than the '007 and previous.
here is a link:
http://www.teamxray.com/teamxray/news/newsdesc.php?news_id=738&kategoria=738&catName=New %20T2'008%20Alu%20Shock%20Absorber%20Set
kn7671 is offline   Reply With Quote
Old 06-30-2008, 01:00 AM   #1204
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
Originally Posted by academygaz View Post
Hi guys, I'm looking to get an FDR of 5.9 with the Speed Passion Ultra 13.5, and I need a spur gear in the 70's range (48dp, 1.7 ratio).
The Xray gear chart I have is great, but it lists all possible ratios, whether you can fit them in the car or not. Is there a chart or something that'll show just the ratios that'll fit the car?
Had this same issue when I firstgot the car. I run 64 so I cant help you really but for 64 I found that a 140 tooth combo (spur + pinion) put the motor about center and I can go about three or for teeth bigger and smaller from that. So if I run a 102 and 38 thats a 4.5 and can go bigger and small from that! LMK if you have any question.
Bryan
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 06-30-2008, 06:01 AM   #1205
yokemad's Avatar
does anybody here tried tamiya shocks on 008?
Old 06-30-2008, 06:25 AM   #1206
academygaz's Avatar
Bryan
Thanks Bryan, I've taken the highly technical route of completely guessing and hoping a 76/25 ratio fits.
yokemad, I know someone with Tamiya shocks on his 008 as he couldn't build 4 indentical Xray shocks. If you need pics or something I can get some.
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 06-30-2008, 07:40 AM   #1207
yokemad's Avatar
that would be great also could you please ask him his thought about them if you compare against xray plastic ones
Cheers
Old 06-30-2008, 05:19 PM   #1208
yokemad's Avatar
007 with tamiya shocks
Old 06-30-2008, 11:13 PM   #1209
ottoman's Avatar
R/C Tech Charter Subscriber
Trader Rating: 13 (100%+)
I never could understand why you would want to run Tamiya shocks on a XRay
Now when I ran for Schumacher I ran Tamiya shocks because they were better and easier to work on (older Schuie shocks)
But I find Xray shocks easy to build and easy to get all the same. The best part is the ability to change the piston settings in 30 seconds with out opening up your shocks... I use this feature every time I race and it can make a huge difference in how your car works.
Heck when I ran a PHI last year I put XRay shocks on it because I like the tunability so much.
I just dont see any advantage in changing from XRay shocks
ottoman is offline   Reply With Quote
Old 06-30-2008, 11:56 PM   #1210
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
wat model of tamiya r he using ?
Give the best while u can !
kschu is offline   Reply With Quote
Old 07-01-2008, 05:13 AM   #1211
yokemad's Avatar
@Ottoman
R u talking about usual Plastic or optional alloy xray shocks also some people has some difficulty to built all 4 shocks perfectly...
also technically FL coated alloy shocks should be better than Plastic
Old 07-01-2008, 07:08 AM   #1212
academygaz's Avatar
Pics as promised, according to him the only reason he uses them is to be able to build 4 identical shocks with the same amount of rebound, which is really hard to do with the standard plastic shocks. They do make the car more predictable when racing on asphalt according to him though.
Old 07-01-2008, 07:13 AM   #1213
yokemad's Avatar
Top man ...Mi3 shocks vs tamiya I go for Schumacher ones ,much easier to build and almost identically same shocks but I'll go for tamiya shocks on 008
Thanx pal
Old 07-01-2008, 09:39 AM   #1214
Trader Rating: 198 (100%+)
I ran the T2 a few years ago with Tamyia shocks after I broke a couple shock bodies, and they leaked. Fast forward a few years to the 008 I have. The shocks are much better. I liken the plastic shocks. They are easy to build and bleed. Plus the clicker pistons make it really easy to change dampening. I would be a little concerned in the length of any other shock on the 008.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 07-01-2008, 10:27 AM   #1215
ottoman's Avatar
@Ottoman
I only use plastic bodies... why waste $$ on aluminum? I broke 2 shock bodies in the last 4 years.... both were huge hits that broke more than the shock.
If you are having problems getting all four shocks equal your not following or dont understand the instructions.
FL coating doesnt make you faster
