Old 06-22-2008, 07:02 PM   #1186
BDK
Hey guys, my dad and I have started racing a few months ago, and we're ready to step up to a competative car. Does anyone here have any pro's and con's to till me about the car listed in this thread? Any help would be very much appreciated. Thanks.
BDK is offline   Reply With Quote
Old 06-22-2008, 08:51 PM   #1187
RobS's Avatar
Just out of curiosity, does anybody know what is the biggest pinion you can fit on the 008 US with a 112 spur gear?
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 06-23-2008, 12:01 PM   #1188
With you saying a 112 spur is it a 64dp ?
If so a 40 pinion is the biggest to fit.
Steve B is offline   Reply With Quote
Old 06-23-2008, 03:09 PM   #1189
RobS's Avatar
Thanks! And yes I was referring to a 64dp gear...
Rob Say
Old 06-25-2008, 02:55 PM   #1190
Trader Rating: 11 (100%+)
hi guys, i am new to xray scene. been using tamiya cars previously. is it worth it to buy the T2 008 new or get a very good condition T2 007? i ask coz after reading several pages from this thread, seems like there is not much difference and there are mixed feelings about the two cars. this buy will be my first xray car. tks in advance for any future replies.
sammz_987 is offline   Reply With Quote
Old 06-25-2008, 03:05 PM   #1191
Customworksking's Avatar
Trader Rating: 73 (100%+)
Thumbs up t2
if ur a pro then yes U will see the 008 is a better car.. if I were you I would get the 008..I was told they put a lot of time 500+hrs in the 008 and it will not change anytime soon..008 4 sure..
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 06-25-2008, 03:11 PM   #1192
Johnny Wishbone's Avatar
From a distance the cars look very similar, BUT, when you do a side by side, in depth comparison, the 008 has so many little changes and refinements over the 007. The 008 is by far the best of the best choice.
Johnny Wishbone is offline   Reply With Quote
Old 06-25-2008, 03:28 PM   #1193
but the 008 came out like only after less than a year after the 007. then the changes/improvements might not be that great i believe. just like the trf-415,415MSX,415MSXX and whatever all the way to TRF-416! these cars are released at a mad, obscene pace i tell you. and the improvements/changes are only by a little bit here & a little bit there. so i was thinking of getting a cheap but in very good condition T2 007 rather than an expensive T2 008 for now and wait another 12 months or so and xray will come out with another new car. i believe that way, i will see and feel a greater improvements in the changes. what do you think?
Old 06-25-2008, 03:57 PM   #1194
Trader Rating: 16 (94%+)
Lets put this in more simple terms. The '007 is a more "user friendly " car, while the '008 is a better "racing" car.
Here are a few examples:
- Fitting a LiPo securely is easier in the '007, but the '008 moved the battery towards the middle of the car for better balance.
- The pinion can be changed on the '007 without having to loosen the 4-rear screws on the top deck, as their is more room to position the pinion on the wider area of the top deck on the '007.
- The shocks on the '008 are shorter along with lowered shock towers, and if the piston/shock shaft are not positioned correctly within the shock body, you will have droop and ride height adjustment issues until corrected.
kn7671 is offline   Reply With Quote
Old 06-25-2008, 04:02 PM   #1195
justin lessard's Avatar
Send a message via AIM to justin lessard
ROAR nats winning setup http://forum.teamxray.com/xform/inde...0&setup=t2_008
justin lessard is offline   Reply With Quote
Old 06-25-2008, 06:01 PM   #1196
Trader Rating: 198 (100%+)
Originally Posted by justin lessard View Post
You had some great racing this past weekend Justin. Your car looked really good. Congratulation's on your win.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 06-26-2008, 11:09 PM   #1197
RCknight's Avatar
Default Anyone know where I can get Nexus spurs?
They are out of everything on their website. Also I'm new to the Vintage class. Can anyone point me in the direction of a good set up using a Camaro body? I can't find anything for an 008, 21t brushless and lipo. I noticed lots of side to side play with my lipo 3800. Is there any fix?
RCknight is offline   Reply With Quote
Old 06-28-2008, 03:18 AM   #1198
academygaz's Avatar
Hi guys, I'm looking to get an FDR of 5.9 with the Speed Passion Ultra 13.5, and I need a spur gear in the 70's range (48dp, 1.7 ratio).
The Xray gear chart I have is great, but it lists all possible ratios, whether you can fit them in the car or not. Is there a chart or something that'll show just the ratios that'll fit the car?
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 06-28-2008, 06:34 AM   #1199
going to try the setup on the weekend justin, good work!
commander is offline   Reply With Quote
Old 06-28-2008, 03:36 PM   #1200
Nexus Racing's Avatar
R/C Tech Elite Subscriber
Originally Posted by RCknight View Post
Anyone know where I can get Nexus spurs? They are out of everything on their website.
Since the black RW "XRAY" gears have not been available for a while, we have been using the white RW "Supalite" gears around here. They will work fine if you sand the black spur/pulley spacer thinner. I just laid some sandpaper on a flat surface and moved the spacer back and forth on it to sand it thinner.
Sizes 102+ of the RW white gears have holes around the outside of the gear for motor mount access (the picture on our website is of the old 102 and 104 gears that did not have those holes.)
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
