Old 06-10-2008, 09:57 PM   #1171
adamge's Avatar
plam, just put a successful EU asphalt setup on the car. You'll be able to run the same suspension geometry, shocks, springs, sway bars, ackerman. Don't use any standoff posts.
Last year I was found a asphalt setup that worked great on my 007 US. This year I'm running a rubber/carpet setup on my 008 US, and it is also working great.
-Nietzsche
Old 06-10-2008, 10:12 PM   #1172
Mini Toink's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Mini Toink Send a message via Yahoo to Mini Toink Send a message via Skype™ to Mini Toink
Hey guys, just want to ask what do you usually gear your Orion 13.5 on an indoor asphalt with approximately 48meters straight aways?
Thanks in advance!!
Toink
Xray T2'008 EU 6Cell
Hudy Pro Tools
AE 12R5
LRP : Orion : Sanwa (Airtronics) : Ko Propo : Spektrum
Mini Toink is offline   Reply With Quote
Old 06-11-2008, 07:11 AM   #1173
NOOB-SMOKE's Avatar
Default gearing
Thanks in advance!!
Toink
hey mate, round 38mm rollout
get motor temp 155 to165 at end of run ands thats your gearing
thats what i find best
cheers noob
CUSTOM MODEL CARS AUSTRALIA,TEAM XRAY,HUDY,FERAL,SOREX,UFRA,
NOOB-SMOKE is offline   Reply With Quote
Old 06-11-2008, 09:00 AM   #1174
Mini Toink's Avatar
Thanks NOOB!
Sorry but I honestly dont know anything about rollout.
We run rubber tires on indoor asphalt.
Thanks again in advance!
Toink
Hudy Pro Tools
AE 12R5
Old 06-11-2008, 11:16 AM   #1175
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Thanks NOOB!
Toink
For 13.5 you'll run an FDR in the mid 4's. Then check your temps and try to keep them under 170.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 06-12-2008, 03:00 AM   #1176
Mini Toink's Avatar
That's great! Thanks Steve!
Toink
Hudy Pro Tools
AE 12R5
Old 06-18-2008, 09:18 AM   #1177
Hello.
How you get this "FDR in the mid 4's".At the Xray chart there aren't that low numbers. Can you help me how to calculate this?
Losi 8ight/EL8 Electric buggy + RC Product Design kit
Mamba Max ESC custom heat sink and 2 Fans
MaxAmps 2x2s6000mah,6v BEC
NEU 1512/1.5d
plamski is offline   Reply With Quote
Old 06-18-2008, 09:29 AM   #1178
Customworksking's Avatar
Trader Rating: 73 (100%+)
Originally Posted by plamski View Post
Hello.
34T/20T Pulleyes = ratio 1.77
64 pitch
spurs 100-111 with 38 pinion
will get u 4.47-4.97
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 06-18-2008, 09:38 AM   #1179
Thumbs up How
How to do it is: if u have pulleyes 34/20='s 1.7 so all u need to do is take ur spur say u have a 100spur 38 pinion 100/by/38 ='s2.6315789 X 1.7 ='s 4.74 FRD
Old 06-22-2008, 09:46 AM   #1180
Hide's Avatar
XRA300011 - XRAY T2 '008 - EU Rubber-Spec 6 Cell Competition 1/10 Electric Touring Car - $459.99 $459.99
Castle Creations Mamba Max 1/10th Scale Brushless Car Package (6900kV) - $199.99
Spektrum DX2.0 DSM 2CH Surface Radio System w/Servos - $154.99
Hyperion EOS 0610i Net Li/NiMH/A123 Balancing Charger (6S/10A/250W) HP-EOS610I - $169.99
Deans Ultra Plug - $2.79
Deans Female Pigtail - $3.59
Team Orion Carbon Edition 3200mAh Li-Poly Battery - $84.99
=$1,076.33
Is this everything I would need to run the T2'008 I have chosen? All I think I need is a servo but I dont want to choose a very expensive one, what would be a good choice?
Losi 8ight-E 2.0, LRP Shark, Xray M18T custom extended, Traxxas VXL Revo
Hide is offline   Reply With Quote
Old 06-22-2008, 10:26 AM   #1181
adamge's Avatar
Hide, it depends what you mean by everything. You'll need tires, body shell, tire sauce, tools, pinions, ride height gauge, paint, body reamer.
Also, that charger is way overkill. You can save $50+ there.
http://www.fmadirect.com/Products.htm?cat=32&nid=24
Get three spare pairs of Deans connectors. You'll use them eventually.
If you are doing serious racing, I think you'll regret the Mamba Max decision. I did, and the guy I sold my used Mamba Max to did as well. Use the money you save on the charger to get an LRP TC Spec + LRP motor.
I'm also a fairly big believer in buying car chassis used. You can get that same chassis, used, for $300; and it'll probably come with $100 worth of spare parts in addition.
-Adam
-Nietzsche
Old 06-22-2008, 10:41 AM   #1182
Hide's Avatar
Thanks for your help
Okay, so the MM isn't a good choice for racing, and I'll need a better ESC + Motor. The charger is really expensive but it was the first one I saw which matched what I needed, so I'll looking into that one you have linked to. I'm going to need more plugs anyway for my brothers car so I'll buy loads.
Are the Xray pinions good choices like they are with their 1/18 cars?
The reason I have chosen to buy a new one is because so far all of the cars I have bought were RTR because they were used or not for racing. If I bought a used one I wouldn't easily be able to fix & replace parts as quickly.
What tires and body are good choices for racing on asphalt?
Because of the lack of tracks here in the UK I will need to find one which I could race on but I'd have to travel quite a way so I want to make it worth it. Might try asking my LHS if they know of a track nearby.
Old 06-22-2008, 11:57 AM   #1183
racer x 1's Avatar
Trader Rating: 27 (100%+)
Default t2r
does anyone know if the t2r is still available? thanks
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 06-22-2008, 01:46 PM   #1184
Trader Rating: 16 (94%+)
I don't think so, but you might find a few sitting on a shelf somewhere, or an online shop that happened to find some. Everything on Xray's website points that it is superceded and replaced with the T2'007, then the T2'008.
kn7671 is offline   Reply With Quote
Old 06-22-2008, 04:03 PM   #1185
Default Outdoor Nat's
I want to say good JOB to all team XRAY guy's @ the Nat's
